you lost me already when the greek letterings went past alpha and beta
Can anyone enlighten me why the following happens for me?
Sony AG9 Oled TV and Nvidia shield 2019
When playing profile7 mkv files from makemkv, that also contain TrueHD audio, i only get HDR
If i change audiotrack to normal ac3 track, i get dolby vision
Im using the TV builtin speakers to eliminate any compability issues with AVR etc.
Anyone can help?
edit: im using the plex app
Anyone can help?
If you're playing on the Plex app, you need to be direct playing both video and audio. If TrueHD has to be transcoded, the video changes to direct streaming which does not trigger Dolby Vision.userr wrote: ↑Tue Nov 10, 2020 6:45 pmCan anyone enlighten me why the following happens for me?
Anyone can help?
Thank you, how do i make sure its direct playing and not "direct streaming"?quietvoid wrote: ↑Tue Nov 10, 2020 6:53 pmIf you're playing on the Plex app, you need to be direct playing both video and audio. If TrueHD has to be transcoded, the video changes to direct streaming which does not trigger Dolby Vision.userr wrote: ↑Tue Nov 10, 2020 6:45 pmCan anyone enlighten me why the following happens for me?
Anyone can help?
By connecting the Shield to a device that can handle TrueHD, so it has to be your AVR and not the TV. If your AVR cannot handle TrueHD, then unfortunately you're out of luck.userr wrote: ↑Tue Nov 10, 2020 7:39 pmThank you, how do i make sure its direct playing and not "direct streaming"?quietvoid wrote: ↑Tue Nov 10, 2020 6:53 pmIf you're playing on the Plex app, you need to be direct playing both video and audio. If TrueHD has to be transcoded, the video changes to direct streaming which does not trigger Dolby Vision.userr wrote: ↑Tue Nov 10, 2020 6:45 pmCan anyone enlighten me why the following happens for me?
Anyone can help?
So i would need a capable AVR and use eARC from TV and it should work?shawnc22 wrote: ↑Tue Nov 10, 2020 8:04 pmBy connecting the Shield to a device that can handle TrueHD, so it has to be your AVR and not the TV. If your AVR cannot handle TrueHD, then unfortunately you're out of luck.
No just get a capable AVR and connect it straight to the AVR.
I’m trying to make a dual track mp4 file of watchmen with the old version of mp4muxer which worked fine for many movies (at least 20). The issue I’m having with Watchmen is that mp4muxer stops immediately without any error message, it juste creates a 0mb mp4 file and stops instantly.
DaMacFunkin
I really think I had this problem, is it because of all the branches?4knewbie wrote: ↑Wed Nov 11, 2020 12:25 pmI’m trying to make a dual track mp4 file of watchmen with the old version of mp4muxer which worked fine for many movies (at least 20). The issue I’m having with Watchmen is that mp4muxer stops immediately without any error message, it juste creates a 0mb mp4 file and stops instantly.
I think I ripped the playlist with TS muxer first then used the output from TS muxer.
DaMacFunkin
Hi Yusesope,yusesope wrote: ↑Sat Nov 07, 2020 2:20 pmI have no idea. Owners of other devices do not complain about this problem. When I have time and you are available maybe we could do some tests together to understand where the problem lies.DaMacFunkin wrote: ↑Sat Nov 07, 2020 7:57 amHi Yusesope.
It would seem that MKV FEL converted to 8.1 with Beta 004 triggers Dolby Vision on the new Zidoo products. MKV FEL to 8.1 with Gamma doesn't trigger Dolby Vision on the new ZIdoo products.
Is there a reason for this, what is the difference?
Thank you.
But first I have to extend GAMMA support to Linux too, fix the creation of the mp4 DTDL files, add chapter support ...![]()
You need to have a bit of patience...![]()
A couple of People on the Zidoo forum are claiming that if you run the patched 8.1 file your software creates through Makemkv 1.1.53 it will then trigger DV on the new Zidoo products.
I'm going to try it now, do you need samples?
So what about the LG OLED series 6 up to the latest CX series?
Will the Gamma MKV's trigger DV on all of them using profile 7? (either MEL of FEL)
Seems like Plex is getting somewhere with nvidia:
https://forums.plex.tv/t/newest-beta-do ... 640693/232
https://forums.plex.tv/t/newest-beta-do ... 640693/234
But they don’t seem to be aware of the colour issuesWe’ve been working with NVIDIA and have found the cause of a crash which would cause Dolby Vision files to fail to direct play and fallback to a direct stream which only supports HDR10. The fix will be released in the next SHIELD OS update (8.2.1).
Do you have a sample for the colour problem? I’ve tried the batch I have (mostly from this thread) and the files all seem to be playing with the correct colours on 8.2.1 of the SHIELD OS.
Slightly off topic, but will the new Xbox series X and S playback these STDL DV MKVs? AFAIK, they support DV for streaming apps but not UHD disks. Just like many TVs and Firestick 4k DV implementation. I'm planning on getting the series S if they do support these files.
I honestly don't know because I used a mkv remux for this one that I demuxed. So did you get it to work in the end ?DaMacFunkin wrote: ↑Thu Nov 12, 2020 6:41 amI really think I had this problem, is it because of all the branches?4knewbie wrote: ↑Wed Nov 11, 2020 12:25 pmI’m trying to make a dual track mp4 file of watchmen with the old version of mp4muxer which worked fine for many movies (at least 20). The issue I’m having with Watchmen is that mp4muxer stops immediately without any error message, it juste creates a 0mb mp4 file and stops instantly.
