Problematic HD-DVDs
madpoet
Re: Problematic HD-DVDs
Dreamgirls is now fixed
davidimas
Hi There,
I am new to this technology but stumbled across Makemkv and am trying to make it work for me.
I have extracted an NEC HD DVD drive from my original Toshiba HD DVD player and inserted it into my Windows PC in the hope of being able to scan my 100 HD DVD discs and store them on my NAS drive for playback.
The Drive works fine with DVD's in it, but every time I try a HD DVD, no luck...
I understand that Makemkv can read HD DVD discs but I keep getting an error , every time I try.. ( see Below )
can anyone advise how to resolve please... many thanks David
MakeMKV v1.6.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\David/MakeMKV_log.txt
DEBUG: Code 101027584 at :<H&8WQ'qx`F=Y~p#0:29395839
DEBUG: Code 101027584 at :<H&8WQ'qx`F=Y~p#0:121261727
Error 'Scsi error - ILLEGAL REQUEST:8F00' occurred while reading 'HD-DVD-ROM _NEC HDDVD HR-1100A 2.0S' at offset '524288'
Error 'Scsi error - ILLEGAL REQUEST:8F00' occurred while reading 'HD-DVD-ROM _NEC HDDVD HR-1100A 2.0S' at offset '1048576'
DEBUG: Code 101027584 at :<H&8WQ'qx`F=Y~p#0:121264579
Error 'Scsi error - ILLEGAL REQUEST:8F00' occurred while reading 'HD-DVD-ROM _NEC HDDVD HR-1100A 2.0S' at offset '32768'
DEBUG: Code 0 at HnRz|%TgM^sfC$PfJr{:29393447
cozzmo
If it happens with all discs i think you have a problem with the drive as MakeMKV definintely works with more discs than it has issues with for HD-DVD. I still have some discs with issues and i will update my previous reports in the coming week or so as some of those discs are fine now.
setarip_old
@davidimas
Hi!
Depending on your PC's O/S, you may have to install a UDF 2.50 driver...
Hi!
davidimas
Hi ,
I have two computers , one vista and one win 7. I have tried installing the HD DVD drive in both machines without success... I have read on the internet that removing the NEC drive from my old Toshiba HD DVD player and installing in a windows computer should work, unfortunaely not for me . ( as yet ) can you please explain what the driver you mentioned is and where I could find one ... many thx David
setarip_old
Only systems with XP or older operating systems require the installation f a UDF 2.50 driver in order to process HD-DVDs and Blu-ray discs - therefore, you don't have to install it on either of your machines, as its already installed...
MakeMKV has a built-in UDF parser and works without UDF driver.setarip_old wrote:Only systems with XP or older operating systems require the installation f a UDF 2.50 driver in order to process HD-DVDs and Blu-ray discs - therefore, you don't have to install it on either of your machines, as its already installed...
cozzmo
Mike, are the issues reported in this thread for some discs fixable or is it a major rework to sort it out? If fixable, do you have an ETA on when a newer version would be released that addresses the issues?
Cheers.
EDIT: I have updated a few of the discs that are now working in my original posts (edits in RED), and the ones i have not added an update i will try to do so tonight. Cheers!
Cheers.
billy the fish
hi guys iam getting this with PHANTOM OF THE OPERA anyone know why ???
cheers
AACS directory not present, assuming unencrypted disc
Saving 1 titles into directory D:/ PHANTOM OF THE OPERA HD-DVD
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT' occurred while reading '/HVDVD_TS/PEVOB_1.EVO' at offset '10735919104'
Failed to save title 0 to file D:/ PHANTOM OF THE OPERA HD-DVD/t00_Feature_Presentation.mkv
0 titles saved, 1 failed
cheers
setarip_old
@billy the fish
Hi!
Try using your original, commercial HD-DVD as the source you load into MakeMKV...
Hi!
cozzmo
I also have problems, but different trying to open the Phantom of the Opera Disc. Might be that my original disc is bad though as i don't even get to open it and select the title feature.
Debug logging enabled, log will be saved as C:\Users\******/MakeMKV_log.txt
DEBUG: Code 100864144 at :<H&8WQ'qx`F=Y~p#0:29395839
DEBUG: Code 100864144 at :<H&8WQ'qx`F=Y~p#0:121261727
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/HVDVD_TS/HVA00001.VTI' at offset '0'
DEBUG: Code 0 at w>K9;6z_M%1|?:213131065
DEBUG: Code 0 at w>K9;6z_M%1|?:121261773
billy the fish
hisetarip_old wrote:@billy the fishAACS directory not present, assuming unencrypted disc
Hi!
this was from the original disk m8
setarip_old
Did you have either AnyDVDHD or DVDFab Passkey while ripping with MakeMKV?
tickett
Just tried with 1.6.4 (Windows 7 Ultimate x64) and get the same error:madpoet wrote:Lucky Number Slevin still errors:
Saving 1 titles into directory C:/Video/LUCKY_NUMBER_SLEVIN
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file C:/Video/LUCKY_NUMBER_SLEVIN/t00_Main_Movie.mkv
Failed to save title 0 to file //oldnas/homeraid/movies/t00_Main_Movie.mkv
