DaMacFunkin
Post by DaMacFunkin »
yusesope wrote:
Sat Nov 07, 2020 2:20 pm
kws53 wrote:
Fri Nov 06, 2020 3:10 pm
How does that process work with GAMMA?
Now the -exp switch also accepts the path of a BluRay folder as input (the address of the folder that contains the BDMV folder).
Download the new version from the original GAMMA post
I also added the -playlist switch to be able to select the playlist of interest (how do I know which playlist to choose? Use an app like BDinfo).
Specify the playlist number only without the .mpls extension.
If no playlist is indicated, the longer one will be chosen.
The -playlist value is ignored if the -exp input is not a BluRay folder.
If in the second command line you choose to use the same folder and playlist used in the first (as "donor of audio and subs"), then, for consistency, you must indicate to FFmpeg the same folder and the same playlist. FFmpeg also uses the -playlist switch and the bluray keyword.
EXAMPLE (more info in the original GAMMA post):
python-3.7.6.amd64\python.exe src\app.py -mux -exp \path\to\bluray -playlist 00222
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -playlist 00222 -i bluray:\path\to\bluray -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Movie Title_________________________________________________________________________" \path\to\your\output\file.mkv
I remind everyone that this is an experimental version and there is always the possibility that something is wrong.
Many of the topics and aspects covered are new to me :wink: .
Even adding a simple function takes some time :( .
Be patient and follow the instructions.
NOTE
  • In FFmpeg (second command line) the -playlist switch, if used, must necessarily precede the input one ("-i")
  • Ignore WARNINGS and ERRORS related to the "libbluray" library that may appear in the first Command Prompt window.
PlatypusW wrote:
Fri Nov 06, 2020 8:38 pm
The speed of Gamma is also really nice. Hopefully with some more automation/script improvements the whole FEL to MEL process etc will become really easy 8)
Not that the current method is particular hard, just lots of processes to kick off :P
I need some time to simplify the procedure. That's okay for now :mrgreen:
DaMacFunkin wrote:
Sat Nov 07, 2020 7:57 am
Hi Yusesope.
It would seem that MKV FEL converted to 8.1 with Beta 004 triggers Dolby Vision on the new Zidoo products. MKV FEL to 8.1 with Gamma doesn't trigger Dolby Vision on the new ZIdoo products.
Is there a reason for this, what is the difference?
Thank you.
I have no idea. Owners of other devices do not complain about this problem. When I have time and you are available maybe we could do some tests together to understand where the problem lies.
But first I have to extend GAMMA support to Linux too, fix the creation of the mp4 DTDL files, add chapter support ... :shock:
You need to have a bit of patience... :lol:
No worries, thank you.
ragico
Post by ragico »
@Yusesope
Tested your latest creation (Gamma tool revised) and it works perfectly.
Made 2 films very quickly.
Thanks again Maestro Yusesope.
4knewbie
Post by 4knewbie »
Hi everyone !
Could anybody update me on the methods to make dv files ? I made a first batch back in march and haven’t made any since then as there were barely any new releases. I used to do it the regular way as described in the original post with dv profile 7 which seems to be the best for Plex on lg c9. Do you guys still use the original method or is there something simpler now ?
Thank you all
Post by shawnc22 »
4knewbie wrote:
Sun Nov 08, 2020 3:24 pm
Hi everyone !
Thank you all
if you're just playing them off your tv's internal player, then no, stick to what you've been doing
whiplash1
Post by whiplash1 »
TheChief wrote:
Sat Oct 17, 2020 7:20 am
Smthng gone wrong:
Traceback (most recent call last):
  File "S:\_Out\MKV_DV\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 833, in _initialise
    init_without_length_or_offset[k](self, v)
KeyError: 'uint'
During handling of the above exception, another exception occurred:
  File "src\MKV_patcher.py", line 233, in <module>
    patched_data = mkv_patcher.inject_dolby_vision(dolby_vision_data)
  File "src\MKV_patcher.py", line 207, in inject_dolby_vision
    self.init_elements()
  File "src\MKV_patcher.py", line 149, in init_elements
    el_property["size"] = self.read_variable_size_int()
  File "src\MKV_patcher.py", line 128, in read_variable_size_int
    parsedValue = BitArray(uint=(self.mkv_data[pos:pos + 8] & (~self.get_len_mark(length))).uint,length=length)
  File "src\MKV_patcher.py", line 117, in get_len_mark
    return BitArray(uint=1 << (8 - int(length / 8)),length=8)
  File "S:\_Out\MKV_DV\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 3059, in __new__
    y = Bits.__new__(BitArray, auto, length, offset, **kwargs)
  File "S:\_Out\MKV_DV\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 812, in __new__
    x._initialise(auto, length, offset, **kwargs)
  File "S:\_Out\MKV_DV\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 838, in _initialise
    init_with_length_only[k](self, v, length)
  File "S:\_Out\MKV_DV\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 1388, in _setuint
    raise CreationError(msg, uint, length, (1 << length) - 1)
bitstring.CreationError: 256 is too large an unsigned integer for a bitstring of length 8. The allowed range is [0, 255].
Facing the exact same issue with Back to the Future Part 1. Haven't tried the other two. This message shows up in mkvpatcher. Accompanied by some errors in the 2nd command window. MKV generates properly but can't be patched successfully. I'm using the -fel_to_mel switch. Tried once with skiphdr10plus switch along with it as well. Same error.
Update - I tried creating the mkv without mapping any audio streams. The resulting mkv appears to have patched successfully. Currently muxing in the audio and commentary tracks and pgs subs using MKVtoolNix. Let's hope it works without any further errors.
Update 2 - Everything works like a charm! Even with the HDR10+ metadata. Next up are Parts 2 & 3 and then 1917.
ghostshadow
Post by ghostshadow »
Hello would it be possible to make a list on this Topic of players reading mkv DV:
player X ---> mkv dv profil X --> TV pana X
thank
kws53
Post by kws53 »
I also added the -playlist switch to be able to select the playlist of interest.
Playlist works perfectly - just waiting for the Chapter support!
Amazing work @Yusesope!
kws53
Post by kws53 »
ghostshadow wrote:
Mon Nov 09, 2020 5:11 pm
thank
Shield 2019 Pro (PLEX client) ----> GAMMA Profile 7 ----> LG CX
Post by shawnc22 »
kws53 wrote:
Mon Nov 09, 2020 8:46 pm
thank
If you have the Shield, why are you going through all this trouble to generate a DV mkv? Just use makemkv 1.15.3 and call it a day.
ghostshadow
thank
thank kws53
yusesope
Post by yusesope »
shawnc22 wrote:
Mon Nov 09, 2020 8:56 pm
Because it's fun :lol: !
Want your MKV, @shawnc22?
And a balloon? And there’s cotton candy...
Epedemic
Post by Epedemic »
Sorry to be "that guy", but is there a method to convert a DV .mp4 file to a DV .mkv file which plays on the shield 2019 hidden somewhere? Came across something interesting to try out :P
ghostshadow
mkvtoolnix then makemkv can be
DaMacFunkin
Epedemic wrote:
Tue Nov 10, 2020 12:43 pm
On the first post of the Makemkv 1.5.3 thread Mike gives a ffmpeg command line to convert back to MKV then run it through Makemkv.
Epedemic
Post by Epedemic »
DaMacFunkin wrote:
Tue Nov 10, 2020 1:15 pm
Arh, i was looking in this thread and the 1.5.1 thread..... The blindness is strong with this one :| Thanks though, it was exactly what i needed, and it worked with great success :D
