Antebellum Blu-ray
TORRRRR
Antebellum Blu-ray
#1 Post by TORRRRR » Fri Oct 23, 2020 3:12 am
Antebellum has like 500 playlists...I grabbed the whole disk until I figure it out. All 1:46:00 and 33GB. Let me know if you know!
Title information
Name: Antebellum (English)
Source file name: 00007.mpls
Duration: 1:46:00
Chapters count: 16
Segment count: 15
Segment map: 515,503,504,513,512,501,511,506,509,514,502,508,507,505,510
File name: Antebellum_t01.mkv
ChodaBoy
Re: Antebellum Blu-ray
#2 Post by ChodaBoy » Thu Oct 29, 2020 11:15 pm
My research has playlist 00568 (US Retail).
515,503,504,513,512,509,501,505,502,511,506,514,507,508,510
Steveredrum
#3 Post by Steveredrum » Sat Oct 31, 2020 9:27 am
[US Retail]
Confirmation That [00568.MPLS] Works
Thanks hvnphoto
hvnphoto
#4 Post by hvnphoto » Sat Oct 31, 2020 11:01 pm
US Retail is 00568.MPLS.
swervarelli
#5 Post by swervarelli » Wed Nov 04, 2020 3:02 am
Any info on the Redbox version? There is no segment map starting with 515. Only 505.
coneslayer
#6 Post by coneslayer » Wed Nov 04, 2020 9:41 pm
swervarelli wrote: Wed Nov 04, 2020 3:02 am Any info on the Redbox version? There is no segment map starting with 515. Only 505.
Same for Netflix.
thetoad
#7 Post by thetoad » Thu Nov 05, 2020 7:27 pm
let me teach you a trick on a way to figure out proper playlist with a bit of detective work (at least in a linux env)
makemkvcon -r info iso:/path/to/your/iso |grep ",26," | cut -f4- -d',' |sort
you now have every playlist sorted by segments. now, you can play the first segment and skip to the end, and see how it ends (and see if it makes sense how it starts)
then look at the second segment, and see if it follow correctly from the first, if not skip all the lines with the same second segment and find the next possible second segment, till you find one that fits, once you do, move onto the third and rinse and repeat. one you find the line that makes sense, return makemkvconf -r info without any grep or cut to find the playlist that segment list is associated with and then you have it.
Crtguy
#8 Post by Crtguy » Thu Nov 05, 2020 8:46 pm
That doesn't help us dummies - like me.
stansolo
#9 Post by stansolo » Thu Nov 05, 2020 8:51 pm
Please ignore my last post. This is the correct playlist for RedBox...
Title information
Source file name: 00991.mpls
Duration: 1:46:00
Chapters count: 16
Segment count: 15
Segment map: 505,509,513,508,506,514,507,502,503,501,511,504,515,510,512
File name: Antebellum_t405.mkv
#10 Post by dcoke22 » Thu Nov 05, 2020 8:56 pm
@Crtguy
https://www.makemkv.com/forum/viewtopic ... 357#p97862
That post is, I think, a reasonable primer on what segments are on blu-rays.
Crtguy
#11 Post by Crtguy » Thu Nov 05, 2020 9:32 pm
dcoke22:
I read and appreciate your post. I am familiar with segments and playlists - I just don't have enough expertise.
thetoad
#12 Post by thetoad » Fri Nov 06, 2020 2:22 pm
theres not much expertise needed if one can run a version of the command I gave.
makemkvcon -r info prints out a lot of info
| grep ",26," -> selects the lines that contain segment maps
| cut -f4- -d',' -> takes those lines and only includes the segment map portion
| sort -> sorts all the segment maps alphabeticaly, i.e. you will end up with something like
505,500,501,504,503,506
505,501,500,504,503,506
506,505,504,501,500,503
you start with 505, it if makes sense, you then see if 500 folows it, if not you try 501
if 505 didnt make snse, you look at 506 and so the same thing from there.
this should really minimize the amount of playlists one has to look at.
bradleyc
#13 Post by bradleyc » Mon Nov 09, 2020 6:44 pm
Any reason my MakeMKV would list t00/00150.mpls as the Main Feature (literally labels that as "FPL_MainFeature) for RB? I have attached a screenshot.
Screen Shot 2020-11-09 at 12.42.13 PM.png (286.07 KiB) Viewed 42799 times
stansolo
#14 Post by stansolo » Tue Nov 10, 2020 1:15 am
bradleyc wrote: Mon Nov 09, 2020 6:44 pm Any reason my MakeMKV would list t00/00150.mpls as the Main Feature (literally labels that as "FPL_MainFeature) for RB? I have attached a screenshot.
The titles selected by the software as the 'Main Feature' are frequently wrong. I posted the correct title last week. I went through the entire process of verifying the segments, and have since watched it with subtitles from an external source that matched up perfectly. The correct Redbox playlist is 991.mpls.
bradleyc
#15 Post by bradleyc » Thu Nov 12, 2020 11:46 pm
stansolo wrote: Tue Nov 10, 2020 1:15 am
Thanks for answering my question - shame about the software "Main Feature" error rate but that's what this excellent support forum is for!
