How does that process work with GAMMA? That's my objective.DaMacFunkin wrote: ↑Fri Nov 06, 2020 6:08 amHi, I have previously posted if you know what playlist you need you can ‘temporary remove’ the other playlists from the playlist folder and ffmpeg will then process the correct one, it actually processed the mpls related to the largest title so you usually only need to remove 1 or 2, or you can just move them all.
Are you saying use ffMpeg to create a new M2TS file, then use GAMMA?
