Flash BU40N in external housing from Mac?
rmk13
Post by rmk13 »
Just to confirm - is is still true, that I need a Windows VM to last LibreDrive, or can I do it directly from the Mac?
Thanks,
Rainer
Re: Flash BU40N in external housing from Mac?
https://www.makemkv.com/forum/viewtopic.php?f=4&t=23129
You should be able to flash firmware into a drive using a Mac.
rmk13
Post by rmk13 »
Thanks.
Will try it out.
Are there any things I have to look at (versions, release dates of firmware, ...)?
Rainer
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
That's the sticky thread about flashing drives. Like the man says in Fast Times at Ridgemont High, "Learn it. Know it. Live it."
:D
rmk13
Post by rmk13 »
Perfect - thanks.
rmk13
Post by rmk13 »
Thanks a lot everybody - done it, and working nicely.
Rainer
