Back to the Future Trilogy - UK Steelbook
4K_junkie
#1 Post by 4K_junkie » Mon Nov 09, 2020 7:15 am
Hi
I have tried to read the three BTTF (UK Steelbook) discs with WH16NS60 using FW 1.0, 1.02 and 1.02. No dice.
I have emailed dumps for the three movies to svq@makemkv.com.
I have not been able to open any of the discs - get error "failed to open disc"
How long does a svq fix normally take and what is process required ? - does the updated data get detected via internet automatically when makemkv is run ?
preserve
Re: Back to the Future Trilogy - UK Steelbook
#2 Post by preserve » Mon Nov 09, 2020 8:38 am
There is an option in Preferences to allow web access, if enabled MakeMKV will check for updates when you try to open a disc.
After you submit a dump, the turnaround time can sometimes be within a day although sometimes it can take a bit longer.
Using: ASUS BW-16D1HT 3.00
4K_junkie
#3 Post by 4K_junkie » Mon Nov 09, 2020 9:21 am
Thanks for the reply. I will give it a shot !
4K_junkie
#4 Post by 4K_junkie » Tue Nov 10, 2020 8:49 am
Thank you very much. All discs now ripped perfect !!
