kws53 wrote: ↑Fri Nov 06, 2020 3:10 pmHow does that process work with GAMMA? That's my objective.DaMacFunkin wrote: ↑Fri Nov 06, 2020 6:08 amHi, I have previously posted if you know what playlist you need you can ‘temporary remove’ the other playlists from the playlist folder and ffmpeg will then process the correct one, it actually processed the mpls related to the largest title so you usually only need to remove 1 or 2, or you can just move them all.
Are you saying use ffMpeg to create a new M2TS file, then use GAMMA?
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp bluray: I:\Atomicthat should choose the largest mlps file.
If you have 3 mlps of the same size it will choose the first one it comes too ie 00800.mlps - but what if you want 00801.mlps?
Delete the mlps from the file you DONT want leaving the one you do.
