Game of Thrones UHD Complete Series 1-8 - No Decrypt Key yet
sgtblackice
Re: Game of Thrones UHD Complete Series 1-8 - No Decrypt Key yet
Post by sgtblackice »
Getting the following error on most of the discs, any advice?
MakeMKV v1.15.3 win(x64-release) started
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
File 00020.mpls was added as title #0
Title #00056.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00802.mpls was added as title #1
File 00801.mpls was added as title #2
File 00053.mpls was added as title #3
File 00800.mpls was added as title #4
Title #00058.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.m2ts was added as title #5
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00044.m2ts was added as title #6
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00045.m2ts was added as title #7
Title #00052.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '139132928'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '139196416'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '138805248'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '139151360'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '0'
Title #00020.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00046.m2ts' at offset '0'
Title #00802.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00045.m2ts' at offset '0'
Title #00801.mpls was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00016.m2ts' at offset '0'
Title #00053.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00044.m2ts' at offset '0'
Title #00800.mpls was skipped
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00045.m2ts' at offset '0'
Title #00045.m2ts was skipped
Title #00044.m2ts was skipped
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00046.m2ts' at offset '0'
Title #00046.m2ts was skipped
Encountered 123 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Giffdev
Post by Giffdev »
SamuriHL wrote: Mon Nov 02, 2020 5:16 pm Sweet. That means by the time Amazon gets around to actually sending me the f****ing thing the keys should be available. LMAO Currently scheduled for later this week. Come on, Amazon! This is why I usually go Best Buy. Anyway thanks for submitting them.
For the record, friend, best buy delivered mine 2 days late! I sprang for the steel book edition for once. It's purty but I do feel silly since I digitize it anyway, so glad someone already sent the disks in for decryption!
Post by SamuriHL »
These discs really are a pain in the ass. I'm ripping them all at 2x.
Post by SamuriHL »
Giffdev wrote: Thu Nov 05, 2020 11:16 pm
I had switched my order from steel book to amazon cause I got it cheaper. Won't make that mistake again.
preserve
Post by preserve »
el_pollo_hermano wrote: Thu Nov 05, 2020 9:52 amMy backups are now unlocking. As these are 4K Discs they should be universally the same.
Glad to hear the discs are now unlocking for folks. But UHDs are not universally the same. Distribution rights for a movie or TV show can be held by different studios in different countries. And even when the same studio owns the rights in different countries, they might still author country-specific discs... as just one example, they might use only a BD-66 in some countries (to save money I'd assume), and in other regions where they need to put more languages on the disc and thus require more space, they'll use a BD-100.
Using: ASUS BW-16D1HT 3.00
Giffdev
Post by Giffdev »
SamuriHL wrote: Fri Nov 06, 2020 1:35 am These discs really are a pain in the ass. I'm ripping them all at 2x.
Are you getting consistent results of them backing up successfully that way? I have never messed with the speed setting, as most things "just work"
Post by SamuriHL »
Giffdev wrote: Fri Nov 06, 2020 6:03 am
So far, yes. I'm about half way through season 2. This is extremely painfully slow, obviously. I theorize that maybe part of the reason we see so many "I can play it in my UHD player so it's not the disc" posts. UHD players by design play them at 1x. We all try to rip them as fast as our drives will let us, and I don't think that's ideal for UHD in a lot of cases. Anyway, I've had WAY more success locking my drives to 2x for all kinds of UHD's lately. It's slower, but, IMO it's better than a ton of failed rips.
mva5580
Post by mva5580 »
I've experienced the same; definitely not the normal experience for me. Multiple discs not reading the first time and I'm getting a constant offset error on S3 D2. I'll try the 2x setting for that one and see if it works.
Post by SamuriHL »
It's going to take a LONG time to go through them all like this. I'm on season 3 as we speak and at 2x I've not had any issues. I can't even read the disc at 4x or higher. I've tried.
Post by mike admin »
SamuriHL wrote: Fri Nov 06, 2020 11:14 pm It's going to take a LONG time to go through them all like this. I'm on season 3 as we speak and at 2x I've not had any issues. I can't even read the disc at 4x or higher. I've tried.
Do you know if the same happens on Pioneer drives (not that they can be used for decryption, but still)?
Post by SamuriHL »
mike admin wrote: Fri Nov 06, 2020 11:31 pm
Ewww. I don't own a Pio that can read UHD. :) Honestly not sure. These discs are BRUTAL. Even at 2x I'm hearing some grinding going on as we speak. It's not erroring, but, it's retracking and rereading. But I'm not sure on the Pio question.
rdgrimes
Post by rdgrimes »
For each season, discs 1-3 are 100GB triple layer discs. Even at 8x they take a long time to rip. Disc 4 is 66GB double layer. The triples always have a high rate of rip failure.
Lowering the read speed can help, but not as much as a vigorous cleaning and polishing.
Post by SamuriHL »
Believe me, I know. This isn't my first dance with UHD. :) But the discs I've bought the last couple months have been horrible quality. BTTF even with rigorous cleaning took 5 attempts to rip disc 1. I'm just going slow and methodical for these GoT discs. I already have season 8 ripped from my stand alone UHD set but I will eventually re-rip them because I haven't gotten around to redoing them for DV yet. Thank God for filebot. This would be REALLY painful without it. LOL
P.S. I'm about to be through seasons 1-3 before I end for the evening. That's how slow this has been.
TheCrazyCanuck
Post by TheCrazyCanuck »
Running into the same issue too. I thought I got defective discs at first so I had amazon ship me replacements. With the replacements I found dropping down to 2x helps but still had problems are two discs and I'm only at the end of season 2. So I'm grabbing whichever disc rips properly from both sets and making my own set and putting the problematic ones into the set I will send back. Amazon gave me until Feb 1st to return it so I think I can manage to slowly get this to rip in time :) In case anyone is looking to drop their read speed as well have a look at this: https://www.makemkv.com/forum/viewtopic.php?t=22689
I'm using a mix of LG WH16NS40 and ASUS BW-16D1HT drives. I'm curious if anyone running into the same thing has tried to put their discs into a standalone UHD player and if they are misbehaving too. I'd check but I don't have one (I just rip and play everything through Plex after).
I'm struggling to get the 2nd title on the first disc of Season 2 to rip using both collections and 2x ripping speed. I've ripped plenty of titles with makemkv but this set is being a royal PITA so I hope Mike figures out what is going on.
sgtblackice
mva5580 wrote: Thu Nov 05, 2020 3:29 pm I really hope they figure out 4k/HDR handbrake ripping sometime soon.....things like this take a serious chunk out of the HDD space.
Native bitrate or nothing :)
