Wall-E commentary track
Wayned
#1 Post by Wayned » Thu Nov 05, 2020 4:32 pm
I bought a copy of Wall-E & used MakeMKV to make a copy and then used HandBrake to create an MP4, I didn't see any errors. When I checked the video, I saw/heard a commentary on the audio. How do I select the audio track? I'm sure it's something obvious, etc.
This clown speaks for himself
Re: Wall-E commentary track
#2 Post by Woodstock » Thu Nov 05, 2020 8:11 pm
The default selection rules for MakeMKV can sometime confuse the Descriptive Audio and some commentary tracks for the movie main audio. I have found that the most effective way to deal with this is to have MakeMKV rip ALL audio tracks, and sort them out in VLC before running handbrake.
Wayned
#3 Post by Wayned » Fri Nov 06, 2020 10:52 pm
Thank you, I couldn't find any audio files directly, but I did start looking for big files (>250MB) and found the movie and shorts (MTS files?), and those had audio listed.
#4 Post by Woodstock » Sat Nov 07, 2020 1:55 am
Do you have a preferred language set?
When you have a language set, MakeMKV will normally only select audio/subtitle tracks that have that language set.
You can take a look at this topic for more information on manually manipulating track selections. If the images come up "broken", your browser is trying to prevent you from viewing non-HTTPS pages; right-click on them as select "view image", because the images are stored on one of my servers, not Mike's.
