Wall-E commentary track
Wayned
Post by Wayned » Thu Nov 05, 2020 4:32 pm
I bought a copy of Wall-E & used MakeMKV to make a copy and then used HandBrake to create an MP4, I didn't see any errors. When I checked the video, I saw/heard a commentary on the audio. How do I select the audio track? I'm sure it's something obvious, etc.
This clown speaks for himself
Re: Wall-E commentary track
Post by Woodstock » Thu Nov 05, 2020 8:11 pm
The default selection rules for MakeMKV can sometime confuse the Descriptive Audio and some commentary tracks for the movie main audio. I have found that the most effective way to deal with this is to have MakeMKV rip ALL audio tracks, and sort them out in VLC before running handbrake.
Wayned
Post by Wayned » Fri Nov 06, 2020 10:52 pm
Thank you, I couldn't find any audio files directly, but I did start looking for big files (>250MB) and found the movie and shorts (MTS files?), and those had audio listed.
Post by Woodstock » Sat Nov 07, 2020 1:55 am
Do you have a preferred language set?
When you have a language set, MakeMKV will normally only select audio/subtitle tracks that have that language set.
You can take a look at this topic for more information on manually manipulating track selections. If the images come up "broken", your browser is trying to prevent you from viewing non-HTTPS pages; right-click on them as select "view image", because the images are stored on one of my servers, not Mike's.
