Flash Gordon UHD
jefftr66
Flash Gordon UHD
Post by jefftr66 » Thu Nov 05, 2020 8:00 pm
Keep getting the "volume key is unknown" error for this disk. I've sent in the AACS file twice but it still does not work.
I'm running MakeMKV in docker - am I missing something?
Re: Flash Gordon UHD
Post by Woodstock » Thu Nov 05, 2020 8:07 pm
Are there any restrictions on reaching the key server? A number of high-level DNS servers will refuse to resolve data for "fairuse.org", including CloudFlare. And some country restrictions will get in the way, too.
jefftr66
Post by jefftr66 » Mon Nov 09, 2020 4:39 pm
Good question - how would I determine this?
Post by Woodstock » Mon Nov 09, 2020 5:03 pm
Quoting a previous post about this:
At a shell prompt, type:
host hkdata.fairuse.org
Do you get an IP back? Some DNS servers will not resolve any host in the domain fairuse.org. Cloudflare at 1.1.1.1, for example, returns nothing, but both Google DNS IPs 8.8.4.4 and 8.8.8.8 resolve it just fine. What your local DNS server gets depends on the "chain" used by the servers in your /etc/resolv.conf file.
jefftr66
Post by jefftr66 » Tue Nov 10, 2020 4:22 pm
hkdata.fairuse.org has address 91.224.23.225
jefftr66
Post by jefftr66 » Tue Nov 10, 2020 4:24 pm
Hm - that IP is a Russian website??
Post by Woodstock » Tue Nov 10, 2020 6:26 pm
Yes, it is in the Russian Federation.
jefftr66
Post by jefftr66 » Tue Nov 10, 2020 7:40 pm
Ah, ok. So it should be working. I tried another 4K disk and same thing. It did rip a regular BR disk though.
jefftr66
Post by jefftr66 » Wed Nov 11, 2020 4:15 pm
Any other ideas?
Post by dcoke22 » Wed Nov 11, 2020 4:19 pm
Can you post your MakeMKV log from it failing with Flash Gordon?
jefftr66
Post by jefftr66 » Thu Nov 12, 2020 4:51 pm
This is what I get when I run: docker logs makemkv
https://pastebin.com/VD7ARtHa
Doesn't seem to be much there. Is there another place to get logs?
Post by dcoke22 » Thu Nov 12, 2020 8:33 pm
MakeMKV has its own log.
https://makemkv.com/faq/item/8
There's a checkbox in the preferences to turn it on. The bottom of the GUI will tell you where the log file is being stored.
More importantly, if MakeMKV can't access the key server it'll show a message saying as much.
On this Docker for MakeMKV (https://github.com/jlesage/docker-makemkv) the most recent issue is about being unable to rip a UHD (https://github.com/jlesage/docker-makemkv/issues/94).
jefftr66
Post by jefftr66 » Thu Nov 12, 2020 9:34 pm
