MakeMKV 1.15.3 fails to start
wtuppa
Post by wtuppa »
I just downloaded and installed version 1.15.3 of MakeMKV under Windows 10. When I try to start it, just a small window pops up with the text "Application failed to initialize". I cannot download previous version 1.15.2.
Regards
Walter
wtuppa
Re: MakeMKV 1.15.3 fails to start
Post by wtuppa »
found in another thread, how to download older version, there is at least 1.15.1.
Post by mike admin » Fri Aug 14, 2020 10:41 pm
http://www.makemkv.com/download/old/
This is very wrong. Does it still happen? May ask you to collect the log file?
stikle
Post by stikle »
Mike-
I think I can shed some light on this, as I've had the same thing happen. It took me a while to track down then resolution, but it's easily reproduceable.
I've got an 8GB RamDisk (R:) set up that I've been playing with. I changed my system temp folder to R:\Temp. Well, somewhere along the way, the RamDisk crashed, hence no %TMP% or %TEMP% available.
With no accessible temp folder available, MakeMKV throws the following dialog and won't run:
So, you might add a check on start for a valid temp folder and adjust the dialog text to be more meaningful. Maybe even try and create the default temp folder.
Anyway, that was my related experience.
