Installing and compilng MakeMKV
Berghutze
#1 Post by Berghutze » Wed Nov 04, 2020 1:03 pm
Hi all,
hope to get some help. I am working of getting rid of Windows for good and therefore I try to get everything I need to work using Mate XFCE. A lot to learn so please bear with me if ask sth. obvious from the specialist side... :D
What I did is using the how-to here:
https://www.makemkv.com/forum/viewtopic.php?f=3&t=224
I compiled it and got not warnings, errors or similar.
BUT: I don't get it to run. How-to says: The application will be installed as "/usr/bin/makemkv". In that directory I can't find the this file; only a file named makemkvcon. Starting the latter (I am sure that is not the way to go) results in:
./makemkvcon: error while loading shared libraries: libmakemkv.so.1: cannot open shared object file: No such file or directory
Thanks in advance for helping me
Berghutze
xr200
Re: Installing and compilng MakeMKV
#2 Post by xr200 » Thu Nov 05, 2020 1:02 am
/usr/bin/makemv is correct.
go back to the directions and make sure you build both packages: oss and bin.
