Both files properly trigger DV mode and play on the LG C7.
yusesope
I just sent you a PM with what you need!
When you feel like it, give it a try!
PlatypusW wrote: Mon Nov 02, 2020 9:29 pm I think you already knew the result but just for completion sake:
On my CX both files did the usual "This file cannot be recognised. Do you want to play the next file?"
It seems that 2020 LG TVs actually have some issues with the DTDL mp4 files generated by both Dolby's mp4muxer and my tool.quietvoid wrote: Mon Nov 02, 2020 6:51 pm Both seem to work and playback the same, triggering Dolby Vision on the C8.
I advise the owners of the latter to use files with profile 8.1 (as soon as I have some time, I will update the GAMMA post with instructions to generate MP4 files).
cuculain wrote: Mon Nov 02, 2020 8:12 pm neither of the new files are recognized by the internal Panasonic Z1000 oled / Zidoo Z9x ......... both files played as HDR only
DTDL files can only be played on LG TVs and bluray players.kws53 wrote: Mon Nov 02, 2020 8:54 pm all MP4 samples (including the new 021120 ones) only play HDR. MP4 and Shield apparently do not play well together.
I haven't tried it yet. Try like this:kws53 wrote: Mon Nov 02, 2020 8:54 pm I've now standardized on using the GAMMA method. I'd like to add Chapters to the MKV file. Any thoughts on how I should proceed?
using GAMMA, in the second command line:
- replacewith
-i \path\to\your\original\file.m2tswhere \path\to\bluray must be the address of the folder that contains the BDMV folder.Code: Select all
-i bluray:\path\to\bluray
. - before -c copy add the switch -map_chapters 1
EXPLANATION:
On blu-ray chapters are stored in mpls files.
With the "-i bluray:" switch you tell FFmpeg to read the longest playlist (mpls).
With the -map_chapters switch instead you tell FFmpeg to copy the chapters from the second input and insert them in the output file. Remember that, as in programming languages, the first element is always zero. So, in this case, the second input is one (-map_chapters 1)!
I invite you to read how these switches work (bluray and map_chapters).
With FFmpeg you can do whatever you want. It's up to you to read the documentation.
kws53
I considered this originally, but thought that a REMUX would remove the relevant internal metadata/coding. However, a test has confirmed this works!DaMacFunkin wrote: Mon Nov 02, 2020 9:06 pmDrop your new mkv in mkvtoolnix then either add the original mpls file or mkv rip and delete everything except the chapters then remix together.kws53 wrote: Mon Nov 02, 2020 8:54 pm I've now standardized on using the GAMMA method. I'd like to add Chapters to the MKV file. Any thoughts on how I should proceed?
I now have a Jack Reacher MKV with Chapters triggering DV...
kws53
I'll give this a try (including changing the appropriate code in first command line) and report back. If this works, it will solve another potential problem - UHD with seamless branching (multiple m2ts components).yusesope wrote: Tue Nov 03, 2020 10:46 amI haven't tried it yet. Try like this:kws53 wrote: Mon Nov 02, 2020 8:54 pm I've now standardized on using the GAMMA method. I'd like to add Chapters to the MKV file. Any thoughts on how I should proceed?
- replace
withCode: Select all
-i bluray:\path\to\bluray- before -c copy add the switch -map_chapters 1
EXPLANATION:
DaMacFunkin
If there are multiple main movie playlists, ie 0800, 0801, 0802 and you specifically know you want 0801, cut the other 2 out of the playlist folder, this way ffmpeg will choose 0801 as the only main movie playlist in the folderkws53 wrote: Tue Nov 03, 2020 5:41 pmI'll give this a try (including changing the appropriate code in first command line) and report back. If this works, it will solve another potential problem - UHD with seamless branching (multiple m2ts components).yusesope wrote: Tue Nov 03, 2020 10:46 amI haven't tried it yet. Try like this:kws53 wrote: Mon Nov 02, 2020 8:54 pm I've now standardized on using the GAMMA method. I'd like to add Chapters to the MKV file. Any thoughts on how I should proceed?
- replace
EXPLANATION:
ragico
@Yusesope
I am trying to use your command for chapters in gamma tool without success.
First command:
Second command:
And I get this:
Of course my mistake, But "where?"
First command:
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp I:\Atomic\BDMV\STREAM\00234.m2tsCode: Select all
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i bluray: I:\Atomic -map 0:0 -map 1:2 -map 1:6 -map 1:11 -map_chapters 1 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Atomic_____________________________________" D:\Atomic.mkvOf course my mistake, But "where?"
kws53
I had the same problem, so I tried (using my files but extending your example):ragico wrote: Wed Nov 04, 2020 2:09 pm @Yusesope
First command:Second command:Code: Select all
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp I:\Atomic\BDMV\STREAM\00234.m2tsAnd I get this:Code: Select all
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp bluray:\I:\Atomic-
yusesope
I just realized that the version of FFmpeg I have attached to my tool does not implement the bluray protocol.
To solve, download the full version of FFmpeg HERE, unpack the archive, rename ffmpeg.exe (inside the "bin" folder) to ffmpeg_win_x64.exe and overwrite, with the latter, the same file that you find in the src\FFmpeg folder (inside my tool folder).
Try again and let me know.
There is just one small mistake: remove the space after "bluray:" in the second command line.ragico wrote: Wed Nov 04, 2020 2:09 pm First command:Second command:Code: Select all
I never talked about changes to the first command line.kws53 wrote: Wed Nov 04, 2020 4:48 pm I had the same problem, so I tried (using my files but extending your example):While this revised 1st command executed as expected................Code: Select all
My tool is programmed to receive a file not a folder address. Besides, he doesn't know what "bluray" is.
And finally the address of the folder written in this way does not make sense in Windows (remove the first Backslash ... \I:\Atomic).
Follow the instructions and take a cue from @ragico's commands (except for the space after "bluray:" in the second command line)
There is a special switch in FFmpeg: -playlistDaMacFunkin wrote: Tue Nov 03, 2020 9:18 pm If there are multiple main movie playlists, ie 0800, 0801, 0802 and you specifically know you want 0801, cut the other 2 out of the playlist folder, this way ffmpeg will choose 0801 as the only main movie playlist in the folder![]()
DaMacFunkin
Hi, I’m getting the same error trying to create a -mode 2 from The Hunt For Red October which I’m also having problems with in makemkvragico wrote: Wed Nov 04, 2020 2:09 pm @Yusesope
ragico
Followed your suggestion. Now the program works but the file generated does not contain any chapter and also it does not start playing and stays at zeroyusesope wrote: Wed Nov 04, 2020 6:30 pm
kws53
@Yusesopeyusesope wrote: Wed Nov 04, 2020 6:30 pmI never talked about changes to the first command line.kws53 wrote: Wed Nov 04, 2020 4:48 pm I had the same problem, so I tried (using my files but extending your example):While this revised 1st command executed as expected................Code: Select all
FYI - bluray:\C:\ and bluray:C:\ are equivalent. I use the additional "\" for clarity.
My interest in exporting the folder address (which we use in Command 2), is to handle seamless branching. By mixing and matching an exported m2ts file with a folder, I can't see how we could handle multiple m2ts files.
And Command 1 worked using the -exp bluray command. While it may not have exported the appropriate data, I received :
"I'M WAITING FOR THE OTHER COMMAND LINE..."
DaMacFunkin
ragico wrote: Wed Nov 04, 2020 8:19 pmFollowed your suggestion. Now the program works but the file generated does not contain any chapter and also it does not start playing and stays at zeroyusesope wrote: Wed Nov 04, 2020 6:30 pm
DaMacFunkin
Hi, I got the program to run, my output file didn’t transfer chapters either, I haven’t had time to try on a device yet (so busy at work).DaMacFunkin wrote: Thu Nov 05, 2020 5:56 amragico wrote: Wed Nov 04, 2020 8:19 pmFollowed your suggestion. Now the program works but the file generated does not contain any chapter and also it does not start playing and stays at zeroyusesope wrote: Wed Nov 04, 2020 6:30 pm
whiplash1
I muxed in chapters using MKVtoolNix, worked fine.DaMacFunkin wrote: Thu Nov 05, 2020 5:58 amHi, I got the program to run, my output file didn’t transfer chapters either, I haven’t had time to try on a device yet (so busy at work).DaMacFunkin wrote: Thu Nov 05, 2020 5:56 amragico wrote: Wed Nov 04, 2020 8:19 pm
DaMacFunkin
yep, done this previously, it’s just an extra step.whiplash1 wrote: Thu Nov 05, 2020 6:46 amI muxed in chapters using MKVtoolNix, worked fine.DaMacFunkin wrote: Thu Nov 05, 2020 5:58 amHi, I got the program to run, my output file didn’t transfer chapters either, I haven’t had time to try on a device yet (so busy at work).
