KTL03
Re: Ultimate UHD Drives Guide Updated 2020
#421 Post by KTL03 » Thu Oct 29, 2020 6:51 pm
Thanks for providing the information in either updating or crossflashing with the appropriate tools and firmwares. I was able to upgrade one WH16NS40-NS50 to the 1.05MK firmware and another to the NS60 1.03MK firmware. It's nice to see there's still some unofficial support for optical drives. 8)
Qwonset The Hutt
#422 Post by Qwonset The Hutt » Tue Nov 03, 2020 8:39 pm
I just got a pair of LG WH16NS40 drives that were manufactured in June, 2020. They came with 1.05 firmware.
sdftool_flasher appears to succeed flashing DE_LG_WH16NS40_1.02_NS50.bin, but the firmware version displayed by MakeMKV is still 1.05. I tried the MK firmware. Same thing.
What options are there for this 1.05 factory firmware that taunts me?
Jabba, you ff, stop stalking me or I'll tell mom.
ubuntuuser
#423 Post by ubuntuuser » Wed Nov 04, 2020 1:00 am
I am unsure, if I have to update this drive:
OS-Gerätename: /dev/sr0
Produzent: HL-DT-ST
Produkt: BD-RE BH16NS40
Revision: 1.03
Serienummer: xxxx
Firmware-Datum: 2115-05-26 17:14
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 70
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
If this drive needs an update, please give me a link how to do it? The drive is used with Linux, but I will connect it for flashing to a very old Windows 10 20.10H2 PC, Bios has no mouse configuration, so I assume UEFI is not suppored, AHCI is not enabled but IDE.
#424 Post by d00zah » Wed Nov 04, 2020 1:15 am
ubuntuuser wrote: Wed Nov 04, 2020 1:00 am I am unsure, if I have to update this drive:
Produzent: HL-DT-ST
Revision: 1.03
Serienummer: xxxx
It's too old to ever do UHD, but it's already LibreDrive enabled & as capable as it will ever be.
ubuntuuser
#425 Post by ubuntuuser » Wed Nov 04, 2020 1:27 am
It can read UHD / BD for sure, but my question is, if it can do BD-4k. In the 1st posting HL-DT-ST-BD-RE_BH16NS40-NS50 is mentioned.
Please note, the date is fantasy it does not say 2015, but 2115
Billycar11 wrote: Mon May 27, 2019 5:20 am
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)
HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-N000600-212005061331.bin
st4evr
#426 Post by st4evr » Wed Nov 04, 2020 1:38 am
ubuntuuser wrote: Wed Nov 04, 2020 1:27 am
Ok, it appears you are confused. As it was advised above, no, it will not read/decrypt UHD content. UHD is just another acronym for 4k media content. Google is your friend if you wish to verify that.
Flashing that drive will result in a bricked drive. If you still wish to do it, go ahead, but you’ve been warned twice now.
The incompatibility of the MT1939 platform with UHD content decryption has been discussed hundreds upon hundreds of times already. Including the warning clearly listed in the first post of this guide. The search function will return hundreds of those conversations as well. And why there are two platforms with the exact same drive model distributed by drive manufacturers/distributors over many years.
https://www.makemkv.com/forum/search.ph ... rds=MT1939
#427 Post by d00zah » Wed Nov 04, 2020 1:44 am
There were 2 HW versions. This drive is a' HL-DT-ST-BD-RE_BH16NS40-NS40 drive, manufactured before Oct 2015. Check the physical label on the drive if you must, but "Drive platform: MT1939" says it all. NOT "BD-4k" (UHD) capable.
All spelled out in the 1st post of this thread.
ubuntuuser
#428 Post by ubuntuuser » Wed Nov 04, 2020 1:49 am
Sorry, yes you are right. For some reasons I thought UHD = BD, which is not, while BD can have HD and UHD resolutions and what I wanted is UHD / 4k.
So I have to look for another drive and keep this drive as it is.
#429 Post by MartyMcNuts » Wed Nov 04, 2020 4:10 am
Qwonset The Hutt wrote: Tue Nov 03, 2020 8:39 pm I just got a pair of LG WH16NS40 drives that were manufactured in June, 2020. They came with 1.05 firmware.
Because you are doing it wrong! 1.05 is an encrypted firmware, so you should:
Step 1: Use the SDFtool Flasher to flash WH16NS40 1.05 from the MK folder checking the "enc" box.
Step 2: Now flash whatever firmware you want to use ("enc" box unchecked.)
liquidfish
#430 Post by liquidfish » Wed Nov 04, 2020 9:22 am
Big thank you to Billy! :D
Sodapop74
#431 Post by Sodapop74 » Wed Nov 04, 2020 10:54 pm
For all the Europeans: this USB to SATA adapter from amazon.de has been working for me with no issues on both Windows and Mac with an ASUS BW-16D1HT that has a UHD compatible custom firmware in it. Here's a link: https://www.amazon.de/-/en/gp/product/B00N4JLNXM/
ubuntuuser
#432 Post by ubuntuuser » Thu Nov 05, 2020 3:33 am
So I have a newer drive now.
Laufwerksinformation
Produzent: ASUS
Produkt: BW-16D1HT
Revision: 3.10
Firmware-Datum: 2119-01-04 10:14
Markierungen der Bus-Verschlüsselung: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
It is in a linux box at the moment. I will put it in a Windows 10 20H2 system with IDE installed (no AHCI) and no UEFI, connected to the master of SATA 1, system ist on SATA 0 master.
Is it normal, that I always get dates from the future like 2 1 19?
Can you please post a few lines what I have to do and what I have to download?
Am I right, that I have to flash 2 times, 1st 3.10MK and then downgrade to which version?
#433 Post by d00zah » Thu Nov 05, 2020 3:51 am
ubuntuuser wrote: Thu Nov 05, 2020 3:33 am It is in a linux box at the moment. I will put it in a Windows 10 20H2 system with IDE installed (no AHCI) and no UEFI, connected to the master of SATA 1, system ist on SATA 0 master.
All that is old news. If Windows detects the drive, you are good to go.
ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Is it normal, that I always get dates from the future like 2 1 19?
Yep.
ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Can you please post a few lines what I have to do and what I have to download?
Link to MK FW pack in 1st post of this thread. Flash w/ SDFtool Flasher (instructions included).
ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Am I right, that I have to flash 2 times, 1st 3.10MK and then downgrade to which version?
Just 3.10MK should do.
ubuntuuser
#434 Post by ubuntuuser » Thu Nov 05, 2020 4:10 am
Thanks, I asked because I use the latest Win 10 from October 2020. Any known problems with the latest Win 10?
I remember, that SDFtool Flasher does cross flashing to LG? And at another place I read crossflashing is not recommended.
Is the needed firmware included already or do I have to download from another place, if so where?
ubuntuuser
#435 Post by ubuntuuser » Thu Nov 05, 2020 4:53 am
Hmm, at least for me, who is not so experienced with Windows, it can be confusing. The drive was recognized by the device manager (hopefully translated correctly into English), but was not shown in the file manager. After a few restarts it took a while with the restart and then the drive was shown in the file manager. I think you have to patient and let the pc alone for a while before you do a restart.
