KTL03
Re: Ultimate UHD Drives Guide Updated 2020
Thanks for providing the information in either updating or crossflashing with the appropriate tools and firmwares. I was able to upgrade one WH16NS40-NS50 to the 1.05MK firmware and another to the NS60 1.03MK firmware. It's nice to see there's still some unofficial support for optical drives.
Qwonset The Hutt
I just got a pair of LG WH16NS40 drives that were manufactured in June, 2020. They came with 1.05 firmware.
sdftool_flasher appears to succeed flashing DE_LG_WH16NS40_1.02_NS50.bin, but the firmware version displayed by MakeMKV is still 1.05. I tried the MK firmware. Same thing.
What options are there for this 1.05 factory firmware that taunts me?
Jabba, you ff, stop stalking me or I'll tell mom.
ubuntuuser
I am unsure, if I have to update this drive:
If this drive needs an update, please give me a link how to do it? The drive is used with Linux, but I will connect it for flashing to a very old Windows 10 20.10H2 PC, Bios has no mouse configuration, so I assume UEFI is not suppored, AHCI is not enabled but IDE.
OS-Gerätename: /dev/sr0
Produzent: HL-DT-ST
Produkt: BD-RE BH16NS40
Revision: 1.03
Serienummer: xxxx
Firmware-Datum: 2115-05-26 17:14
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 70
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
Unrestricted read speed: Yes-
It's too old to ever do UHD, but it's already LibreDrive enabled & as capable as it will ever be.ubuntuuser wrote: Wed Nov 04, 2020 1:00 am I am unsure, if I have to update this drive:
Produzent: HL-DT-ST
Revision: 1.03
Serienummer: xxxx
ubuntuuser
It can read UHD / BD for sure, but my question is, if it can do BD-4k. In the 1st posting HL-DT-ST-BD-RE_BH16NS40-NS50 is mentioned.It's too old to ever do UHD
Please note, the date is fantasy it does not say 2015, but 2115
Billycar11 wrote: Mon May 27, 2019 5:20 am
New Encrypted firmware
List of Know Encrypted firmware (so far, any firmware with date in 2020 is encrypted)Code: Select all
... HL-DT-ST-BD-RE_BH16NS40-NS50-1.05-N000600-212005061331.bin
st4evr
Ok, it appears you are confused. As it was advised above, no, it will not read/decrypt UHD content. UHD is just another acronym for 4k media content. Google is your friend if you wish to verify that.
Flashing that drive will result in a bricked drive. If you still wish to do it, go ahead, but you’ve been warned twice now.
The incompatibility of the MT1939 platform with UHD content decryption has been discussed hundreds upon hundreds of times already. Including the warning clearly listed in the first post of this guide. The search function will return hundreds of those conversations as well. And why there are two platforms with the exact same drive model distributed by drive manufacturers/distributors over many years.
https://www.makemkv.com/forum/search.ph ... rds=MT1939
There were 2 HW versions. This drive is a' HL-DT-ST-BD-RE_BH16NS40-NS40 drive, manufactured before Oct 2015. Check the physical label on the drive if you must, but "Drive platform: MT1939" says it all. NOT "BD-4k" (UHD) capable.
All spelled out in the 1st post of this thread.
ubuntuuser
Sorry, yes you are right. For some reasons I thought UHD = BD, which is not, while BD can have HD and UHD resolutions and what I wanted is UHD / 4k.Ok, it appears you are confused.
So I have to look for another drive and keep this drive as it is.
Because you are doing it wrong! 1.05 is an encrypted firmware, so you should:Qwonset The Hutt wrote: Tue Nov 03, 2020 8:39 pm I just got a pair of LG WH16NS40 drives that were manufactured in June, 2020. They came with 1.05 firmware.
Step 1: Use the SDFtool Flasher to flash WH16NS40 1.05 from the MK folder checking the "enc" box.
Step 2: Now flash whatever firmware you want to use ("enc" box unchecked.)
liquidfish
Big thank you to Billy!
Sodapop74
For all the Europeans: this USB to SATA adapter from amazon.de has been working for me with no issues on both Windows and Mac with an ASUS BW-16D1HT that has a UHD compatible custom firmware in it. Here's a link: https://www.amazon.de/-/en/gp/product/B00N4JLNXM/
ubuntuuser
So I have a newer drive now.It's too old to ever do UHD
Laufwerksinformation
Produzent: ASUS
Produkt: BW-16D1HT
Revision: 3.10
Firmware-Datum: 2119-01-04 10:14
Markierungen der Bus-Verschlüsselung: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Is it normal, that I always get dates from the future like 2 1 19?
Can you please post a few lines what I have to do and what I have to download?
Am I right, that I have to flash 2 times, 1st 3.10MK and then downgrade to which version?
All that is old news. If Windows detects the drive, you are good to go.ubuntuuser wrote: Thu Nov 05, 2020 3:33 am It is in a linux box at the moment. I will put it in a Windows 10 20H2 system with IDE installed (no AHCI) and no UEFI, connected to the master of SATA 1, system ist on SATA 0 master.
Yep.ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Is it normal, that I always get dates from the future like 2 1 19?
Link to MK FW pack in 1st post of this thread. Flash w/ SDFtool Flasher (instructions included).ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Can you please post a few lines what I have to do and what I have to download?
Just 3.10MK should do.ubuntuuser wrote: Thu Nov 05, 2020 3:33 am Am I right, that I have to flash 2 times, 1st 3.10MK and then downgrade to which version?
ubuntuuser
Thanks, I asked because I use the latest Win 10 from October 2020. Any known problems with the latest Win 10?All that is old news. If Windows detects the drive, you are good to go.
I remember, that SDFtool Flasher does cross flashing to LG? And at another place I read crossflashing is not recommended.Link to MK FW pack in 1st post of this thread. Flash w/ SDFtool Flasher (instructions included).
Is the needed firmware included already or do I have to download from another place, if so where?
Thanks!Just 3.10MK should do.
ubuntuuser
Hmm, at least for me, who is not so experienced with Windows, it can be confusing. The drive was recognized by the device manager (hopefully translated correctly into English), but was not shown in the file manager. After a few restarts it took a while with the restart and then the drive was shown in the file manager. I think you have to patient and let the pc alone for a while before you do a restart.
