LG BU40N with Firmware Revision PH07
Bommatt
Post by Bommatt » Sat Sep 19, 2020 12:06 pm
hello,
I bought a used LG BU40N last week.
unfortunately I now had to notice that the drive has an unknown firmware PH07.
can someone tell me something about this firmware version?
thanks.
Re: LG BU40N with Firmware Revision PH07
Post by Woodstock » Sat Sep 19, 2020 2:27 pm
When you load MakeMKV, what does it say about the drive?
Bommatt
Post by Bommatt » Sat Sep 19, 2020 8:18 pm
Post by Billycar11 » Sat Sep 19, 2020 10:03 pm
Bommatt wrote: Sat Sep 19, 2020 8:18 pm
Recommended Firmware to flash for MakeMKV:
BU40N > BU40N 1.03MK
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Bommatt
Post by Bommatt » Sun Sep 20, 2020 11:15 am
Billycar11 wrote: Sat Sep 19, 2020 10:03 pm
Thank you for your quick response.
So you mean that I can simply flash the 1.03mk over the firmware PH07?
I'm new here.
could you briefly tell me which tool I should use for flashing?
Bommatt
Post by Bommatt » Tue Nov 03, 2020 8:49 am
can someone please help me?
Post by dcoke22 » Tue Nov 03, 2020 3:29 pm
The link Billycar11 posted is to the drives guide on this forum. In there, you'll find links to the various firmware, flashing tools, and what not. I think the SDFtool by MartyMcNuts is the preferred choice these days.
Post by mike admin » Wed Nov 04, 2020 5:18 pm
Bommatt wrote: Sat Sep 19, 2020 12:06 pm unfortunately I now had to notice that the drive has an unknown firmware PH07.
Did you notice MakeMKV writing an FW_xxxxxxxx.tgz file for this drive? Should have been created on first disc opening and placed into MakeMKV data directory. Please send this file to support@makemkv.com
Juanwen
Post by Juanwen » Thu Nov 19, 2020 7:24 pm
So that means there was an issue with your version 14.0. :scratch
About your last issue it is the workgroup. You must set the same workgroup than this one of your laptop set with the lan setup menu
Bommatt
Post by Bommatt » Tue Nov 24, 2020 11:02 am
mike admin wrote: Wed Nov 04, 2020 5:18 pm
I would flash my drive like this now.
do I need to turn on ENC?
Post by Billycar11 » Tue Nov 24, 2020 12:48 pm
Bommatt wrote: Tue Nov 24, 2020 11:02 am
No enc
