ghostshadow
#3571 Post by ghostshadow » Mon Nov 02, 2020 3:10 pm
yusesope wrote:
Mon Nov 02, 2020 11:52 am
ghostshadow wrote:
Sun Nov 01, 2020 5:03 pm
i don't use the Gamma 004 8.1 just 8.1
DaMacFunkin wrote:
Sun Nov 01, 2020 9:01 pm
So I wonder what Yousepe did differently?
Hey @ghostshadow, what do you mean "just 8.1"?
Are you using BETA or GAMMA?
Could you describe the steps you follow so @DaMacFunkin can replicate them and can experiment on his Zidoo too? Thanks!
Hello yusesope, I am using your 8.1 Beta method:
UHD-BD TO PROFILE 8.1
You can use both UHD-BD MEL and FEL
    In the case of a Dual Track Dual Layer DV file (e.g. an m2ts file in the BDMV\STREAM folder)
        Extract the base layer and the enhancement layer
        ffmpeg -i path\to\the\file.m2ts -ss 0 -t 120 -map 0:0 -c copy path\to\BL.hevc
        ffmpeg -i path\to\the\file.m2ts -ss 0 -t 120 -map 0:1 -c copy path\to\EL.hevc
        Using my tool, double click on the MUX_AND_CONVERT_TO_PROFILE_81.bat file and follow the instructions on the screen.
        You will get a BL_EL_RPU.hevc file.
        Actually, the file does not contain EL (it's just BL+RPU).
        BL_EL_RPU is just the filename !!!
        Let's put it this way, you are too lazy to use the command line and I am too lazy to add lines of code for the purpose of renaming a file
        EXTRA (MKV):
Simply, create an ISO using BL_EL_RPU and TsMuxeR.
Open the ISO with MakeMKV and create mkv
yusesope
#3572 Post by yusesope » Mon Nov 02, 2020 5:45 pm
PlatypusW wrote:
Thu Oct 29, 2020 5:40 pm
quietvoid wrote:
Thu Oct 29, 2020 7:30 pm
daddy wrote:
Fri Oct 30, 2020 6:16 am
kws53 wrote:
Fri Oct 30, 2020 9:51 pm
I took @quietvoid's advice and THESE should be the last samples to test ... I hope so :mrgreen: !
There are two samples (I still have a little doubt).
Try them both and let me know.
Thank you for your time!
Thanks for the reply
quietvoid
#3573 Post by quietvoid » Mon Nov 02, 2020 6:51 pm
Both seem to work and playback the same, triggering Dolby Vision on the C8.
cuculain
#3574 Post by cuculain » Mon Nov 02, 2020 8:12 pm
neither of the new files are recognized by the internal Panasonic Z1000 oled (did still show earlier versions on the drive)
edit
renamed files and recognized this time
both files played as HDR only (tested vs Alita mkv which does bring up DV/DA)
both files played as HDR only with audio on the Zidoo Z9x (should be new firmware this week,so hopefully they fix the DV/DA issues )
kws53
#3575 Post by kws53 » Mon Nov 02, 2020 8:54 pm
After installing Shield 8.8.1...
All MKV samples play DV - all MP4 samples (including the new 021120 ones) only play HDR. MP4 and Shield apparently do not play well together.
I've now standardized on using the GAMMA method. I'd like to add Chapters to the MKV file. Any thoughts on how I should proceed?
DaMacFunkin
#3576 Post by DaMacFunkin » Mon Nov 02, 2020 9:06 pm
Drop your new mkv in mkvtoolnix then either add the original mpls file or mkv rip and delete everything except the chapters then remix together.
DaMacFunkin
#3577 Post by DaMacFunkin » Mon Nov 02, 2020 9:10 pm
        EXTRA (MKV):
Thanks for this, I will try when I get time.
I have also submitted a sample of FEL to MEL 8.1 made with Gamma 004 to Zidoo vie Mark Swift, hopefully they can adapt the sdk to recognise this method, if they can I think we are onto a winner.
PlatypusW
#3578 Post by PlatypusW » Mon Nov 02, 2020 9:29 pm
I think you already knew the result but just for completion sake:
On my CX both files did the usual "This file cannot be recognised. Do you want to play the next file?"
FDM80
#3579 Post by FDM80 » Mon Nov 02, 2020 10:55 pm
Both files properly trigger DV mode and play on the LG C7.
yusesope
#3580 Post by yusesope » Tue Nov 03, 2020 10:46 am
quietvoid wrote:
Mon Nov 02, 2020 2:02 pm
@quietvoid, if the file works, would you like to test everything before I make it public?
So I can be sure that the new process works on a full movie and on an LG TV.
Sure.
I just sent you a PM with what you need!
When you feel like it, give it a try!
It seems that 2020 LG TVs actually have some issues with the DTDL mp4 files generated by both Dolby's mp4muxer and my tool.
I advise the owners of the latter to use files with profile 8.1 (as soon as I have some time, I will update the GAMMA post with instructions to generate MP4 files).
neither of the new files are recognized by the internal Panasonic Z1000 oled / Zidoo Z9x ......... both files played as HDR only
DTDL files can only be played on LG TVs and bluray players.
I haven't tried it yet. Try like this:
using GAMMA, in the second command line:
  • replace
    -i \path\to\your\original\file.m2ts
    with
    -i bluray:\path\to\bluray
    where \path\to\bluray must be the address of the folder that contains the BDMV folder.
  • before -c copy add the switch -map_chapters 1
EXPLANATION:
On blu-ray chapters are stored in mpls files.
With the "-i bluray:" switch you tell FFmpeg to read the longest playlist (mpls).
With the -map_chapters switch instead you tell FFmpeg to copy the chapters from the second input and insert them in the output file. Remember that, as in programming languages, the first element is always zero. So, in this case, the second input is one (-map_chapters 1)!
I invite you to read how these switches work (bluray and map_chapters).
With FFmpeg you can do whatever you want. It's up to you to read the documentation.
kws53
#3581 Post by kws53 » Tue Nov 03, 2020 5:38 pm
I considered this originally, but thought that a REMUX would remove the relevant internal metadata/coding. However, a test has confirmed this works!
I now have a Jack Reacher MKV with Chapters triggering DV...
kws53
#3582 Post by kws53 » Tue Nov 03, 2020 5:41 pm
  • replace
    with
EXPLANATION:
I'll give this a try (including changing the appropriate code in first command line) and report back. If this works, it will solve another potential problem - UHD with seamless branching (multiple m2ts components).
DaMacFunkin
#3583 Post by DaMacFunkin » Tue Nov 03, 2020 9:18 pm
  • replace
    with
EXPLANATION:
If there are multiple main movie playlists, ie 0800, 0801, 0802 and you specifically know you want 0801, cut the other 2 out of the playlist folder, this way ffmpeg will choose 0801 as the only main movie playlist in the folder ;-)
ragico
#3584 Post by ragico » Wed Nov 04, 2020 2:09 pm
@Yusesope
I am trying to use your command for chapters in gamma tool without success.
First command:
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp I:\Atomic\BDMV\STREAM\00234.m2ts
Second command:
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i bluray: I:\Atomic -map 0:0 -map 1:2 -map 1:6 -map 1:11 -map_chapters 1 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Atomic_____________________________________" D:\Atomic.mkv
And I get this:
Of course my mistake, But "where?"
kws53
#3585 Post by kws53 » Wed Nov 04, 2020 4:48 pm
@Yusesope
First command:
Second command:
And I get this:
I had the same problem, so I tried (using my files but extending your example):
python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp bluray:\I:\Atomic
While this revised 1st command executed as expected, the 2nd command exited with a "Pipe" input error. I believe that the 2nd command needs to be reworked for a different input file type.
