Thanks to you @DaMacFunkin for your walkthroughDaMacFunkin wrote: ↑Sun Nov 01, 2020 1:11 pmHi,ghostshadow wrote: ↑Sun Nov 01, 2020 10:12 amZidoo Z9x, Z10 Pro etc :
the DV conversion by the yusesope method to Profile 8 works perfectly. I tested Fel and Mel and transformed into Profile 8 and they work !!
The problem with the Atmos TrueHD DV + Track does not come from the conversion or the method used!
it comes from the Zidoo Firmware. For proof it is enough to :Went back into Realtek developer options, switched "reserve less buffer" space off and enabled "Enable Playback Performance mode (experimental)". And the most desynchronization after 15 minutes. There are a few jerks, but it works (at the end of the viewing (1 hour) I had a red screen).
So the solution for the DV + Atmos TrueHD will come from a correction of the Zidoo Firmware.
So playing all UHD DV with the yusesope method allows them to be played in MKV DV on the zidoo.
Midway, Justice Ligue, GOT 8 ---> ok
Can I ask which guide you used to create profile 8.1 MEL from FEL that triggers DV on Zidoo Z9X?
The titles I have created with Gamma 004 only trigger HDR10.
P.S. thanks for posting my workaround for the Realtek developer options.
I used the yusesope 8.1 solution
tested on 2 zidoo: 1 z9x and 1 Z1000Pro
