Maybe in all these files we are just getting HDR10 with dynamic metadata.
I know for a fact that original Dual Track DV on the Oppo203 is better than any rip played back via an Android player that I have seen.
If there is a difference in those files then they cant all just be hdr10 with dynamic metadata..one of them has to be proper DV?DaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
What kind of "original dual track DV" ? Ripped DTDL profile7? or from the disc?DaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
the oppo can just play the full folder backups without any extra modifications.userr wrote: ↑Sat Oct 31, 2020 4:06 pmWhat kind of "original dual track DV" ? Ripped DTDL profile7? or from the disc?DaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
You can think about STDL version as Schrödinger's Dolby Vision - It's equal and unequal to DTDL at the same timeDaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
Maybe, I certainly think that there is a way, Sony LLDV works and it is a fudge, I’m quite sure there that the fudges can work, we are definitely closer than we was.lexyz wrote: ↑Sat Oct 31, 2020 4:41 pmYou can think about STDL version as Schrödinger's Dolby Vision - It's equal and unequal to DTDL at the same timeDaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
Indeed! 8.8.1 triggers DV on all of my GAMMA profile 8 and profile 7 MKV files, the Alpha Muxed files and the original TSMuxer method. I just hope that I'm getting DV and not simply showing as triggered. As a result, I intend to use the GAMMA MKV method going forward.
Btw the Sony X90H is the first sony tv to support proper TV led dolby vision. (They added this in a recent software update - https://www.youtube.com/watch?v=R2WDVRR4WV0), Does that effect the possibility of playing FEL files directly on the TV without using external player?DaMacFunkin wrote: ↑Sat Oct 31, 2020 7:51 pmMaybe, I certainly think that there is a way, Sony LLDV works and it is a fudge, I’m quite sure there that the fudges can work, we are definitely closer than we was.lexyz wrote: ↑Sat Oct 31, 2020 4:41 pmYou can think about STDL version as Schrödinger's Dolby Vision - It's equal and unequal to DTDL at the same timeDaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
PlatypusW wrote: ↑Thu Oct 29, 2020 5:40 pmCX48 - Played via USB using the internal player:
DTDL_FEL_1: "This file cannot be recognised. Do you want to play the next file?"
DTDL_FEL_2: "This file cannot be recognised. Do you want to play the next file?"
DTDL_FEL_3: "This file cannot be recognised. Do you want to play the next file?"
DTDL_FEL_4: "This file cannot be recognised. Do you want to play the next file?"
Ok, we are getting closer to emulating the behavior of the latest version of mp4muxer: the new LGs do not recognize files, the "old" LGs recognize files but cannot play them, X700 recognizes and plays the files.
It takes time (which I don't have
 ) and it would be like looking for a needle in a haystack
 ) and it would be like looking for a needle in a haystack   .
Zidoo Z9X and panasonic z1000 cannot play DTDL files - it is normal to get only HDR.
In the end you succeeded...kws53 wrote: ↑Sun Nov 01, 2020 3:36 amIndeed! 8.8.1 triggers DV on all of my GAMMA profile 8 and profile 7 MKV files, the Alpha Muxed files and the original TSMuxer method. I just hope that I'm getting DV and not simply showing as triggered. As a result, I intend to use the GAMMA MKV method going forward.
Very impressive Yusesope!
 RESET_9999 wrote: ↑Sat Oct 31, 2020 2:50 amthe x700 OSD will show ''Dolby Vision HDR'' for real DV and ''HDR'' only for fake DV.
HDR10 with dynamic metadata is HDR10+.DaMacFunkin wrote: ↑Sat Oct 31, 2020 2:26 pmMaybe in all these files we are just getting HDR10 with dynamic metadata.
 I don't know the device at all, so I don't have a clue ...DaMacFunkin wrote: ↑Thu Oct 29, 2020 9:49 pmHi Yusesope, can you explain why you think FEL titles created with Gamma 004 don’t trigger DV on Zidoo Z9X regardless of which conversion to MEL or profile is used?
I tried to convert First Man 2018 to MEL mkv using this method and the resultant file is detected correctly as Dolby Vision but the audio is out of sync from the beginning, comparing the generated file to the original m2ts stream and FEL mkv created using makemkv 1.15.3.yusesope wrote: ↑Fri Oct 16, 2020 1:37 pmThe weekend has come! It's time to experiment!
HERE (UPDATE 22/10/20) you can find what I was working on last weekend.
This is v0.0.4 GAMMA "only for the brave" edition!
It is a partial job, there is no guarantee that it will work, but first of all I have to understand if I am proceeding on the right path and to do it I need to understand what is wrong. The tests that I can do alone are a limited number so "unity is strength": the more tests we do, the more errors we will discover and there will be more chances for me to be able to correct what doesn't work!
The new tool only works on Windows (for now): I'm sure that people who use Linux are ready to use their quadruple bootor already have QEMU running in the background
When I experiment on Windows I often use THESE virtual machines (fast and clean method). The login password is "Passw0rd!"
Hi,ghostshadow wrote: ↑Sun Nov 01, 2020 10:12 amZidoo Z9x, Z10 Pro etc :
the DV conversion by the yusesope method to Profile 8 works perfectly. I tested Fel and Mel and transformed into Profile 8 and they work !!
The problem with the Atmos TrueHD DV + Track does not come from the conversion or the method used!
it comes from the Zidoo Firmware. For proof it is enough to :Went back into Realtek developer options, switched "reserve less buffer" space off and enabled "Enable Playback Performance mode (experimental)". And the most desynchronization after 15 minutes. There are a few jerks, but it works (at the end of the viewing (1 hour) I had a red screen).
So the solution for the DV + Atmos TrueHD will come from a correction of the Zidoo Firmware.
So playing all UHD DV with the yusesope method allows them to be played in MKV DV on the zidoo.
Midway, Justice Ligue, GOT 8 ---> ok
Mirror from Zidoo offered you one for free a few weeks ago...yusesope wrote: ↑Sun Nov 01, 2020 9:56 amI don't know the device at all, so I don't have a clue ...DaMacFunkin wrote: ↑Thu Oct 29, 2020 9:49 pmHi Yusesope, can you explain why you think FEL titles created with Gamma 004 don’t trigger DV on Zidoo Z9X regardless of which conversion to MEL or profile is used?
It's not your fault.
Use a positive value (in this specific case, 170ms) if the audio starts before the video (aka “you have to slow down the audio”).src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -itsoffset 170ms -i \path\to\your\original\file.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Movie Title_________________________________________________________________________" \path\to\your\output\file.mkv
Forgive me, I did not understand what you are referring to.DaMacFunkin wrote: ↑Sun Nov 01, 2020 1:20 pmMirror from Zidoo offered you one for free a few weeks ago...yusesope wrote: ↑Sun Nov 01, 2020 9:56 amI don't know the device at all, so I don't have a clue ...DaMacFunkin wrote: ↑Thu Oct 29, 2020 9:49 pmHi Yusesope, can you explain why you think FEL titles created with Gamma 004 don’t trigger DV on Zidoo Z9X regardless of which conversion to MEL or profile is used?
Thanks to you @DaMacFunkin for your walkthroughDaMacFunkin wrote: ↑Sun Nov 01, 2020 1:11 pmHi,ghostshadow wrote: ↑Sun Nov 01, 2020 10:12 amZidoo Z9x, Z10 Pro etc :
Can I ask which guide you used to create profile 8.1 MEL from FEL that triggers DV on Zidoo Z9X?
The titles I have created with Gamma 004 only trigger HDR10.
P.S. thanks for posting my workaround for the Realtek developer options.
