I'm sure there's lots of suggestions in the forum but it's a bit overwhelming looking through it...
Can someone recommend an excellent, fast and reliable UHD internal ROM that can be easily flashed with the usual available firmwares to work work with MakeMKV?
thanks in advance.
UHD Rom recommendation
Re: UHD Rom recommendation
Please see this:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
If you want your drive to work also with other software besides Makemkv then check my guide:
https://forum.redfox.bz/threads/guide-f ... dvd.79023/
You will need to join the Redfox forum to be able to see the pictures.
