Does this mean I have a bad Disc?
brianmw36
Post by brianmw36 » Fri Oct 30, 2020 10:56 am
MakeMKV v1.15.3 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/bmw/MakeMKV_log.txt
Optical drive "DVD+R-DL Optiarc DVD RW AD-7540A 1.D0d" opened in OS access mode.
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Title #1 was added (15 cell(s), 1:52:48)
Title #3 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (1 cell(s), 0:12:35)
Title #5 was added (1 cell(s), 0:18:46)
Title #6 was added (1 cell(s), 0:03:23)
Title #7 was added (1 cell(s), 0:03:02)
Title #8 was added (1 cell(s), 0:02:05)
Title #9 was added (1 cell(s), 0:03:10)
Title #10 was added (1 cell(s), 0:02:39)
Title #11 was added (1 cell(s), 0:04:15)
Title #12 was added (1 cell(s), 0:04:03)
Title #13 was added (1 cell(s), 0:04:17)
Title #14 was added (1 cell(s), 0:03:20)
Title #15 was added (1 cell(s), 0:02:46)
Title #16 was added (1 cell(s), 0:05:13)
Title #17 was added (13 cell(s), 1:09:34)
Title #18 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 was added (1 cell(s), 0:18:25)
Title #20 was added (1 cell(s), 0:23:35)
Title #23 was added (12 cell(s), 1:37:19)
Title #25 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 10551311 at WSq4yjBebG+Cl%PT:213142496
DEBUG: Code 0 at WSq4yjBebG+Cl%PT:121274998
DEBUG: Code 0 at +"e(ENxH@xiSFs^F{;:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 15-15 were removed from title end
Title #28 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 was added (12 cell(s), 1:37:19)
Title #37 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #43 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #55 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #58 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #61 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #64 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #65 was added (11 cell(s), 1:27:12)
Title #67 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 1 in VTS 8 is equal to title 1 and was skipped
DEBUG: Code 233 at lBOWVwFPVsRvLQgE6g8/G5Vc:0
Saving 1 titles into directory /Volumes/1TBSSD/New Movies
DEBUG: Code 0 at _QArMns35KE <Dj+5:213130237
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading 'DVD+R-DL Optiarc DVD RW AD-7540A 1.D0' at offset '19306496'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk11' at offset '19306496'
DEBUG: Code 1073741829 at ui]{;3u:7O4yrt7iLp:29395149
DEBUG: Code 100860416 at ui]{;3u:7O4yrt7iLp:29395149
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:29395471
DEBUG: Code 0 at `INs-e#4P^u9m;olHZp:29393562
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:213131157
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:121262647
DEBUG: Code 9427 at i/KyO`_OY#FKb6Mwy:rI:121261773
DEBUG: Code 0 at F2KY5iV:#oS,h:x=5Kk:213132491
DEBUG: Code 0 at Tk_-[@5B#==Kelrv;&y41:213137091
Failed to save title 0 to file /Volumes/1TBSSD/New Movies/title_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Re: Does this mean I have a bad Disc?
Post by Woodstock » Fri Oct 30, 2020 12:50 pm
It means you probably have a DIRTY disk.
Have you read through If you're experiencing rip errors, please read here first! yet?
