quietvoid
Post by quietvoid » Thu Oct 29, 2020 7:30 pm
yusesope wrote:
Thu Oct 29, 2020 5:24 pm
I have generated four other FEL DTDL variants.
Each of them has small changes and the degree of complexity increases from file n1 to file n4.
These files can only be played using the INTERNAL PLAYER of LG TVs (via DLNA, USB).
If you want to try, you can find them HERE.
In your feedback please specify the TV model and the file that worked (if any of these will ever work :mrgreen: ).
On my LG C8, via DLNA, they all show the endless spinning wheel and never start playing back.
Same behavior as the latest mp4muxer when creating dual track mp4s.
I thought you took inspiration from that code though. Maybe you could find a significant difference between 2018 and now's code.
cuculain
Post by cuculain » Thu Oct 29, 2020 8:40 pm
All four files
Zidoo Z9X direct to panasonic z1000 oled all 4 played hdr pq only ...no stutters
Panasonic z1000 Oled direct all 4 played hdr pq only ,,,no stutters
DaMacFunkin
Post by DaMacFunkin » Thu Oct 29, 2020 9:49 pm
DaMacFunkin wrote:
Thu Oct 29, 2020 5:51 pm
DaMacFunkin wrote:
Thu Oct 29, 2020 4:37 pm
yusesope wrote:
Thu Oct 22, 2020 1:42 pm
I have updated the POST of the 0.0.4 GAMMA version.
I think I have made some steps forward.
THESE samples were obtained with the latter version.
Do they trigger DV on your devices?
The files contain an ATMOS audio track that could create some incompatibility with those devices without decoder, e.g. LG TVs.
So I finally tried these sample files, none trigger DoVi on Zidoo Z9X only HDR10.
On the Shield 2019 pro with Latest Plex Beta and Latest Plex Beta server all 3 - FEL, FEL to MEL and FEL to Profile 8.1 all trigger Dolby Vision... err wow...
Just for fun I tried them on Oppo 203, all 3 play in HDR10 only.
On this particular post I am referring to MKV samples as discussed and linked to in the quoted text.
Hi Yusesope, can you explain why you think FEL titles created with Gamma 004 don’t trigger DV on Zidoo Z9X regardless of which conversion to MEL or profile is used?
bdub46
Post by bdub46 » Fri Oct 30, 2020 1:31 am
Hi I'm New to this,
I'm trying to make a mp4 for Dolby Vision. I've seen some of the post on her and have tried the following,
tsmuxer Gui-- It makes the files but when i try to run those files with mp4muxer i get "ERROR! Can't open input file:Error parsing command line!"
When i use the dvmp4 maker it makes the mp4 file but it doesn't read on my tv as Dolby vison it reads as HDR
When i look up the file om MediaInfo is show 2 streams ans list the HDR10
Ive tried some of the sample mp4 on her and the do show Dolby Vision on my tv and when i look up the Mediainfo it show HDR/HDR
Im trying to get to that to show on the file i created on Mediainfo.
I've also tried eac3to334 which i assume is like tsmuxer and i get error saying the batch files isn't recognized.
Any suggestions would be greatly appreciated.
Also I'm confused weather the layer is suppose to be single or dual layer for the mp4 track. I have an LG SuperUHD tv with a 19 Nvidia Shield.
Thanks,
Bdub46
userr
Post by userr » Fri Oct 30, 2020 5:13 am
So im using Nvidia Shield 2019 Pro and Sony AG9/A9G OLED, ripping movies with makemkv and playing them with TrueHD, i do not get dolby vision, if i select AC3 audio track i do get DV, anyone know why?
I have old AVR, still using optical out from TV to AVR, is this why?
Im working on upgrading my audio situation, i just wanna know my files are futureproof
daddy
Post by daddy » Fri Oct 30, 2020 6:16 am
On LG C7, all 4 files = spinning wheel and never start playing back.
Hi-Res
Post by Hi-Res » Fri Oct 30, 2020 10:55 am
HongyuS wrote:
Fri Oct 23, 2020 3:40 am
badrobot wrote:
Fri Oct 23, 2020 2:52 am
I have tried MBOX demo video files on my iPad Pro, it seems that P5 can be identified as DoVi by infuse 6, but P8.1 can not.
Result:P5 play as DoVi, P8.1 play as HDR, I have uploaded these screenshots.
https://screenshotcomparison.com/comparison/7316
I forgot to mention one very important info: Apple require the video track fourcc ID to be “dvh1” for Dolby Vision. So you need to change it manually using a Hex editor. (More info: the sample I recommended to you is “dvhe”, which cannot be played by QuickTime/Apple TV app)
Furthermore, Infuse only supports profile 5. If you want to test profile 8.x, you need to copy the the m4v file to the “Files” app, and preview with it. (And you must use iPadOS 14.1 or 14.2 beta 4, or later versions, in order to support profile 8.x)
How do I change from dvhe to dvh1? Using a hex editor? How would I make the appropriate changes from dvhe to dvh1. It's showing up as HDR on infuse. If you could show me how to change the value. That would be appreciated.
Mediainfo
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 58.9 GiB
Duration                                 : 1 h 48 min
Overall bit rate                         : 78.0 Mb/s
Encoded date                             : UTC 2020-10-30 15:47:07
Tagged date                              : UTC 2020-10-30 15:47:07
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 77.4 Mb/s
Bits/(Pixel*Frame)                       : 0.389
Stream size                              : 58.4 GiB (99%)
Maximum Frame-Average Light Level        : 606 cd/m2
Audio
Codec ID                                 : ac-3
Stream size                              : 495 MiB (1%)
kws53
Post by kws53 » Fri Oct 30, 2020 9:51 pm
I have the following TEST data points to offer for 3 scenarios:
  1. Plex Windows Server->Shield 2019 Pro Plex Client->LG CX77
  2. Plex Windows Server->LG WebOS Plex Client->LG CX77 (eARC)
  3. Plex Windows Server->Sony x700 DLNA Client->LG CX77
Server = Version 1.20.3.3483
LG WebOS Plex Client Version = 5.3.1 (Client)
Shield Pro OS = Version 8.2.0
Shield Pro Plex Client = Version 7.23.0.13018
Sony x700 DLNA Client = latest US version as today
These Yusesope trial muxes were run:
  • DTDL_FEL.mp4
  • DTDL_FEL_1.mp4
  • DTDL_FEL_2.mp4
  • DTDL_FEL_3.mp4
  • DTDL_FEL_4.mp4
  • DTDL_FEL_to_MEL.mp4
  • STDL_FEL.mp4
  • STDL_FEL_to_MEL.mp4
  • FEL_to_Profile81.mp4
  • FEL.mkv
  • FEL_to_MEL.mkv
  • FEL_to_Profile81.mkv
For what it is worth, I also tried:
  1. A full DTDL .ts (TSMuxer) mux of 1917 (FEL)
    • Video 1 = SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
    • Video 2 = Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
  2. A full DTDL .ts (TSMuxer) mux of Shazam (MEL)
  3. A full STDL .ts (Alpha) mux of Shazam (MEL)
    • Video = Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
  4. A full DTDL .MP4 (Original MP4 method) mux of Casino Royale (MEL)
    • Video 1 = SMPTE ST 2086, HDR10 compatible
    • Video 2 = Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
  5. A full STDL .ts (Alpha) mux of First Man (FEL)
    • Video = Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Results (1=Shield, 2=WebOs, 3=X700):
  • DTDL_FEL.mp4: 1=HDR, 2= HDR, 3=DV
  • DTDL_FEL_1.mp4: 1=HDR, 2= HDR, 3=DV
  • DTDL_FEL_2.mp4: 1=HDR, 2= HDR, 3=DV
  • DTDL_FEL_3.mp4: 1=HDR, 2= HDR, 3=DV
  • DTDL_FEL_4.mp4: 1=HDR, 2= HDR, 3=DV
  • DTDL_FEL_to_MEL.mp4: 1=HDR, 2= HDR, 3=DV
  • STDL_FEL.mp4: 1=HDR, 2= HDR, 3=DNP
  • STDL_FEL_to_MEL.mp4: 1=HDR, 2= HDR, 3=DNP
  • FEL_to_Profile81.mp4: 1=HDR, 2=DV, 3=HDR
  • FEL.mkv: 1=HDR, 2= HDR, 3=HDR (Audio Error)
  • FEL_to_MEL.mkv: 1=HDR, 2=HDR, 3=HDR (Audio Error)
  • FEL_to_Profile81.mkv: 1=HDR, 2=HDR, 3=HDR (Audio Error)
  • 1917.ts: 1=HDR, 2=HDR, 3=DV (buffering issues after 3-5 minutes)
  • Shazam.ts (STDL): 1=HDR, 2=HDR, 3=DNP (had multiple video issues with my Sony x700/Denon x4700/LG CX77 combination - scrambled pixellated overlay which required a power down of all equipment to reset)
  • Shazam.ts (DTDL): 1=HDR, 2=HDR, 3=DNP
  • Casino Royale.mp4: 1=HDR, 2=HDR, 3=DV (audio not recognized)
  • Casino Royale.ts: 1=HDR, 2=DV (incompatible eARC audio), 3=DNP
  • First Man.ts: 1=HDR, 2=HDR, 3=DNP
In summary:
  • All DTDL MP4 test files triggered DV for x700 - may or may not be buffering issues, files too small
  • DTDL .ts file triggered DV for x700 - buffering issues
  • MP4 files from early method triggered DV in x700 but audio limitations prevented use
  • No file configuration to date triggered DV in Shield
  • Casino Royale.ts (Alpha method) triggered DV in WebOS but LG eARC audio restrictions prevented sound
  • FEL_to_Profile81.mp4 triggered DV in WebOS but LG eARC audio restrictions will be issue
Ultimately, I need SOMETHING to trigger DV in the Shield...
DaMacFunkin
Post by DaMacFunkin » Fri Oct 30, 2020 9:58 pm
Mediainfo
Video
Audio
Codec ID                                 : ac-3
Err... rip Casino Royale to mkv with latest Makemkv = Dolby Vision on Shield 2019 pro via latest Plex - it’s that easy.
Post by shawnc22 » Fri Oct 30, 2020 11:04 pm
Mediainfo
Video
Audio
Codec ID                                 : ac-3
I was about to say the same thing, but I think you quoted the wrong person lol.
@kws53, just rip with makemkv 1.15.3 and call it a day.
badrobot
Post by badrobot » Fri Oct 30, 2020 11:08 pm
  • DTDL_FEL.mp4
  • DTDL_FEL_1.mp4
  • DTDL_FEL_2.mp4
  • DTDL_FEL_3.mp4
  • DTDL_FEL_4.mp4
  • STDL_FEL.mp4
  • FEL.mkv
  • FEL_to_MEL.mkv
In summary:
You need to update Shield Pro Plex Client version to 8.8.0.
I am not a native English speaker.
Sorry for my bad English.
Hi-Res
Post by Hi-Res » Sat Oct 31, 2020 12:27 am
  • DTDL_FEL.mp4
  • DTDL_FEL_1.mp4
  • DTDL_FEL_2.mp4
  • DTDL_FEL_3.mp4
  • DTDL_FEL_4.mp4
  • STDL_FEL.mp4
  • FEL.mkv
  • FEL_to_MEL.mkv
In summary:
The x700 playing in Dolby vision dual-layer mp4 from both DLNA and USB. Forcing Dolby vision to ON in settings, applies a pseudo dv to all content and isn't real Dolby vision. Turning on DV sends the DV metadata for everything. So just triggering DV isn't enough of a test to know for SURE that it's truly playing DV content. Turning it off will still properly flag dv so long as the actual Metadata exists and your source content is correct.
If you search far back enough. The x700 isn't 1:1 DV playback. It has been confused by many because they see the logo popup.
Post by RESET_9999 » Sat Oct 31, 2020 2:50 am
not true at all. the x700 OSD will show ''Dolby Vision HDR'' for real DV and ''HDR'' only for fake DV.
it sure is a 1:1 DV playback device.
also, turning off DV wont trigger DV anymore for any content. it will even tonemap profile 5 full range DV content to HDR10.
Image Image
mmm... the x700 play ALL the DT DL TS produced by tsmuxer. not sure why you couldnt play Shazaam , Casino Royal, 1917 and first man. I watched all of them without any issue.
koolkunz
Post by koolkunz » Sat Oct 31, 2020 8:25 am
I have been trying a lot of sample files posted here on my new sony bravia x90h tv. It can play basically all MEL files (mp4/ts/mkv) and all profile8.1 files but havent been able to find a way to get any FEL file trigger dolby vision, is it simply not possible to play FEL files on sony tvs without external hardware player?
Also I have one other question, any FEL file converted to MEL vs the same FEL file converted to profile 8.1, what is supposed to look better? (MEL file should look better right as 8.1 has no enhancement layer and only dynamic metadata?)
DaMacFunkin
Post by DaMacFunkin » Sat Oct 31, 2020 12:35 pm
No, Sony doesn’t support full Dolby (FEL).
Also no one is sure what is happening with these FEL players that actually play them, is the enhancement getting discarded?
