Asus BW-16D1Ht and Asus BW-16D1H-U
akse0435
#1 Post by akse0435 » Thu Oct 29, 2020 6:52 pm
I hope I'm posting this in the right forum.
So, I've looked at buying a Asus BW-16D1HT internal Blu-Ray, which I would then use with my labtop through a sata to usb converter. I then discovered that there exists a drive called Asus BW-16D1H-U external USB 3.0, but, the kind that also needs AC-power.
I will be using the drive for ripping of boath cd's, dvd's and Blu-Ray's, and I found a list of most accurate disk-drives, where the Asus BW-16D1HT was the number one top most accurate drive, and so my question is:
Is the Asus BW-16D1H-U the exact same drive as the BW-16D1HT, just in an USB-enclosure, so can I expect the exact same accuracy, if I buy the BW-16D1H-U?
Thanks in advance.
Best regards:
Aksel Christoffersen
Re: Asus BW-16D1Ht and Asus BW-16D1H-U
#2 Post by Billycar11 » Thu Oct 29, 2020 9:21 pm
No it's a different drive won't work with UHD.
akse0435
#3 Post by akse0435 » Fri Oct 30, 2020 3:40 am
Thank you, so maybe I schould get an Asus BW-16D1HT, but now I have another question.
It seems like, for boath models, there exist boath a normal version and a pro-version, but unfortunately the pro-version isn't available in Denmark, where I live. What is the difference between Asus BW-16D1HT and Asus BW-16D1HT Pro, and why could it be unavailable in Denmark? Does it just have some functions, that Danish customers might not need or something?
#4 Post by MartyMcNuts » Fri Oct 30, 2020 6:26 am
akse0435 wrote: Fri Oct 30, 2020 3:40 am Thank you, so maybe I schould get an Asus BW-16D1HT, but now I have another question.
There is no difference. They are exactly the same drive with exactly the same firmware. (I have compared them!) The "PRO" model is available in Australia.
akse0435
#5 Post by akse0435 » Fri Oct 30, 2020 8:52 am
OK, so i guess it has something to do with software included in the package.
Thank you for the replies. Now I'll go and buy the Asus BW-16D1HT.
