All four files
Zidoo Z9X direct to panasonic z1000 oled all 4 played hdr pq only ...no stutters
Panasonic z1000 Oled direct all 4 played hdr pq only ,,,no stutters
Hi Yusesope, can you explain why you think FEL titles created with Gamma 004 don’t trigger DV on Zidoo Z9X regardless of which conversion to MEL or profile is used?DaMacFunkin wrote: ↑Thu Oct 29, 2020 5:51 pmOn this particular post I am referring to MKV samples as discussed and linked to in the quoted text.DaMacFunkin wrote: ↑Thu Oct 29, 2020 4:37 pmSo I finally tried these sample files, none trigger DoVi on Zidoo Z9X only HDR10.yusesope wrote: ↑Thu Oct 22, 2020 1:42 pm
I have updated the POST of the 0.0.4 GAMMA version.
I think I have made some steps forward.
THESE samples were obtained with the latter version.
Do they trigger DV on your devices?
The files contain an ATMOS audio track that could create some incompatibility with those devices without decoder, e.g. LG TVs.
On the Shield 2019 pro with Latest Plex Beta and Latest Plex Beta server all 3 - FEL, FEL to MEL and FEL to Profile 8.1 all trigger Dolby Vision... err wow...
Just for fun I tried them on Oppo 203, all 3 play in HDR10 only.
Hi I'm New to this,
I'm trying to make a mp4 for Dolby Vision. I've seen some of the post on her and have tried the following,
tsmuxer Gui-- It makes the files but when i try to run those files with mp4muxer i get "ERROR! Can't open input file:Error parsing command line!"
When i use the dvmp4 maker it makes the mp4 file but it doesn't read on my tv as Dolby vison it reads as HDR
When i look up the file om MediaInfo is show 2 streams ans list the HDR10
Ive tried some of the sample mp4 on her and the do show Dolby Vision on my tv and when i look up the Mediainfo it show HDR/HDR
Im trying to get to that to show on the file i created on Mediainfo.
I've also tried eac3to334 which i assume is like tsmuxer and i get error saying the batch files isn't recognized.
Any suggestions would be greatly appreciated.
Also I'm confused weather the layer is suppose to be single or dual layer for the mp4 track. I have an LG SuperUHD tv with a 19 Nvidia Shield.
Thanks,
Bdub46
Thanks,
Bdub46
So im using Nvidia Shield 2019 Pro and Sony AG9/A9G OLED, ripping movies with makemkv and playing them with TrueHD, i do not get dolby vision, if i select AC3 audio track i do get DV, anyone know why?
I have old AVR, still using optical out from TV to AVR, is this why?
Im working on upgrading my audio situation, i just wanna know my files are futureproof
On LG C7, all 4 files = spinning wheel and never start playing back.
How do I change from dvhe to dvh1? Using a hex editor? How would I make the appropriate changes from dvhe to dvh1. It's showing up as HDR on infuse. If you could show me how to change the value. That would be appreciated.HongyuS wrote: ↑Fri Oct 23, 2020 3:40 amI forgot to mention one very important info: Apple require the video track fourcc ID to be “dvh1” for Dolby Vision. So you need to change it manually using a Hex editor. (More info: the sample I recommended to you is “dvhe”, which cannot be played by QuickTime/Apple TV app)badrobot wrote: ↑Fri Oct 23, 2020 2:52 amI have tried MBOX demo video files on my iPad Pro, it seems that P5 can be identified as DoVi by infuse 6, but P8.1 can not.
Result:P5 play as DoVi, P8.1 play as HDR, I have uploaded these screenshots.
https://screenshotcomparison.com/comparison/7316
Furthermore, Infuse only supports profile 5. If you want to test profile 8.x, you need to copy the the m4v file to the “Files” app, and preview with it. (And you must use iPadOS 14.1 or 14.2 beta 4, or later versions, in order to support profile 8.x)
Mediainfo
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 58.9 GiB
Duration : 1 h 48 min
Overall bit rate : 78.0 Mb/s
Encoded date : UTC 2020-10-30 15:47:07
Tagged date : UTC 2020-10-30 15:47:07
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 77.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.389
Stream size : 58.4 GiB (99%)
Default : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 606 cd/m2
Codec configuration box : hvcC+dvcC
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 495 MiB (1%)
Language : English
Service kind : Complete Main
Default : No
I have the following TEST data points to offer for 3 scenarios:
LG WebOS Plex Client Version = 5.3.1 (Client)
Shield Pro OS = Version 8.2.0
Shield Pro Plex Client = Version 7.23.0.13018
Sony x700 DLNA Client = latest US version as today
These Yusesope trial muxes were run:
Results (1=Shield, 2=WebOs, 3=X700):
- Plex Windows Server->Shield 2019 Pro Plex Client->LG CX77
- Plex Windows Server->LG WebOS Plex Client->LG CX77 (eARC)
- Plex Windows Server->Sony x700 DLNA Client->LG CX77
- DTDL_FEL.mp4
- DTDL_FEL_1.mp4
- DTDL_FEL_2.mp4
- DTDL_FEL_3.mp4
- DTDL_FEL_4.mp4
- DTDL_FEL_to_MEL.mp4
- STDL_FEL.mp4
- STDL_FEL_to_MEL.mp4
- FEL_to_Profile81.mp4
- FEL.mkv
- FEL_to_MEL.mkv
- FEL_to_Profile81.mkv
- A full DTDL .ts (TSMuxer) mux of 1917 (FEL)
- Video 1 = SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
- Video 2 = Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
- A full DTDL .ts (TSMuxer) mux of Shazam (MEL)
- A full STDL .ts (Alpha) mux of Shazam (MEL)
- Video = Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
- A full DTDL .MP4 (Original MP4 method) mux of Casino Royale (MEL)
- Video 1 = SMPTE ST 2086, HDR10 compatible
- Video 2 = Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
- A full STDL .ts (Alpha) mux of First Man (FEL)
- Video = Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
- DTDL_FEL.mp4: 1=HDR, 2= HDR, 3=DV
- DTDL_FEL_1.mp4: 1=HDR, 2= HDR, 3=DV
- DTDL_FEL_2.mp4: 1=HDR, 2= HDR, 3=DV
- DTDL_FEL_3.mp4: 1=HDR, 2= HDR, 3=DV
- DTDL_FEL_4.mp4: 1=HDR, 2= HDR, 3=DV
- DTDL_FEL_to_MEL.mp4: 1=HDR, 2= HDR, 3=DV
- STDL_FEL.mp4: 1=HDR, 2= HDR, 3=DNP
- STDL_FEL_to_MEL.mp4: 1=HDR, 2= HDR, 3=DNP
- FEL_to_Profile81.mp4: 1=HDR, 2=DV, 3=HDR
- FEL.mkv: 1=HDR, 2= HDR, 3=HDR (Audio Error)
- FEL_to_MEL.mkv: 1=HDR, 2=HDR, 3=HDR (Audio Error)
- FEL_to_Profile81.mkv: 1=HDR, 2=HDR, 3=HDR (Audio Error)
- 1917.ts: 1=HDR, 2=HDR, 3=DV (buffering issues after 3-5 minutes)
- Shazam.ts (STDL): 1=HDR, 2=HDR, 3=DNP (had multiple video issues with my Sony x700/Denon x4700/LG CX77 combination - scrambled pixellated overlay which required a power down of all equipment to reset)
- Shazam.ts (DTDL): 1=HDR, 2=HDR, 3=DNP
- Casino Royale.mp4: 1=HDR, 2=HDR, 3=DV (audio not recognized)
- Casino Royale.ts: 1=HDR, 2=DV (incompatible eARC audio), 3=DNP
- First Man.ts: 1=HDR, 2=HDR, 3=DNP
- All DTDL MP4 test files triggered DV for x700 - may or may not be buffering issues, files too small
- DTDL .ts file triggered DV for x700 - buffering issues
- MP4 files from early method triggered DV in x700 but audio limitations prevented use
- No file configuration to date triggered DV in Shield
- Casino Royale.ts (Alpha method) triggered DV in WebOS but LG eARC audio restrictions prevented sound
- FEL_to_Profile81.mp4 triggered DV in WebOS but LG eARC audio restrictions will be issue
Err... rip Casino Royale to mkv with latest Makemkv = Dolby Vision on Shield 2019 pro via latest Plex - it’s that easy.Hi-Res wrote: ↑Fri Oct 30, 2020 10:55 amHow do I change from dvhe to dvh1? Using a hex editor? How would I make the appropriate changes from dvhe to dvh1. It's showing up as HDR on infuse. If you could show me how to change the value. That would be appreciated.HongyuS wrote: ↑Fri Oct 23, 2020 3:40 amI forgot to mention one very important info: Apple require the video track fourcc ID to be “dvh1” for Dolby Vision. So you need to change it manually using a Hex editor. (More info: the sample I recommended to you is “dvhe”, which cannot be played by QuickTime/Apple TV app)badrobot wrote: ↑Fri Oct 23, 2020 2:52 amI have tried MBOX demo video files on my iPad Pro, it seems that P5 can be identified as DoVi by infuse 6, but P8.1 can not.
Mediainfo
Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/dby1/isom) File size : 58.9 GiB Duration : 1 h 48 min Overall bit rate : 78.0 Mb/s Encoded date : UTC 2020-10-30 15:47:07 Tagged date : UTC 2020-10-30 15:47:07 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 1 h 48 min Bit rate : 77.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.389 Stream size : 58.4 GiB (99%) Default : No Encoded date : UTC 2020-10-30 15:47:07 Tagged date : UTC 2020-10-30 15:47:07 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 606 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : ac-3 Duration : 1 h 48 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 495 MiB (1%) Language : English Service kind : Complete Main Default : No Encoded date : UTC 2020-10-30 15:47:07 Tagged date : UTC 2020-10-30 15:47:07
I was about to say the same thing, but I think you quoted the wrong person lol.DaMacFunkin wrote: ↑Fri Oct 30, 2020 9:58 pmErr... rip Casino Royale to mkv with latest Makemkv = Dolby Vision on Shield 2019 pro via latest Plex - it’s that easy.Hi-Res wrote: ↑Fri Oct 30, 2020 10:55 amHow do I change from dvhe to dvh1? Using a hex editor? How would I make the appropriate changes from dvhe to dvh1. It's showing up as HDR on infuse. If you could show me how to change the value. That would be appreciated.HongyuS wrote: ↑Fri Oct 23, 2020 3:40 am
Mediainfo
@kws53, just rip with makemkv 1.15.3 and call it a day.
You need to update Shield Pro Plex Client version to 8.8.0.kws53 wrote: ↑Fri Oct 30, 2020 9:51 pmI have the following TEST data points to offer for 3 scenarios:Server = Version 1.20.3.3483
These Yusesope trial muxes were run:For what it is worth, I also tried:
- DTDL_FEL.mp4
- DTDL_FEL_1.mp4
- DTDL_FEL_2.mp4
- DTDL_FEL_3.mp4
- DTDL_FEL_4.mp4
- STDL_FEL.mp4
- FEL.mkv
- FEL_to_MEL.mkv
Results (1=Shield, 2=WebOs, 3=X700):In summary:
Ultimately, I need SOMETHING to trigger DV in the Shield...
I am not a native English speaker.
Sorry for my bad English.
The x700 playing in Dolby vision dual-layer mp4 from both DLNA and USB. Forcing Dolby vision to ON in settings, applies a pseudo dv to all content and isn't real Dolby vision. Turning on DV sends the DV metadata for everything. So just triggering DV isn't enough of a test to know for SURE that it's truly playing DV content. Turning it off will still properly flag dv so long as the actual Metadata exists and your source content is correct.kws53 wrote: ↑Fri Oct 30, 2020 9:51 pmI have the following TEST data points to offer for 3 scenarios:Server = Version 1.20.3.3483
- DTDL_FEL.mp4
- DTDL_FEL_1.mp4
- DTDL_FEL_2.mp4
- DTDL_FEL_3.mp4
- DTDL_FEL_4.mp4
- STDL_FEL.mp4
- FEL.mkv
- FEL_to_MEL.mkv
If you search far back enough. The x700 isn't 1:1 DV playback. It has been confused by many because they see the logo popup.
not true at all. the x700 OSD will show ''Dolby Vision HDR'' for real DV and ''HDR'' only for fake DV.Hi-Res wrote: ↑Sat Oct 31, 2020 12:27 am
it sure is a 1:1 DV playback device.
also, turning off DV wont trigger DV anymore for any content. it will even tonemap profile 5 full range DV content to HDR10.
mmm... the x700 play ALL the DT DL TS produced by tsmuxer. not sure why you couldnt play Shazaam , Casino Royal, 1917 and first man. I watched all of them without any issue.
I have been trying a lot of sample files posted here on my new sony bravia x90h tv. It can play basically all MEL files (mp4/ts/mkv) and all profile8.1 files but havent been able to find a way to get any FEL file trigger dolby vision, is it simply not possible to play FEL files on sony tvs without external hardware player?
Also I have one other question, any FEL file converted to MEL vs the same FEL file converted to profile 8.1, what is supposed to look better? (MEL file should look better right as 8.1 has no enhancement layer and only dynamic metadata?)
No, Sony doesn’t support full Dolby (FEL).koolkunz wrote: ↑Sat Oct 31, 2020 8:25 amI have been trying a lot of sample files posted here on my new sony bravia x90h tv. It can play basically all MEL files (mp4/ts/mkv) and all profile8.1 files but havent been able to find a way to get any FEL file trigger dolby vision, is it simply not possible to play FEL files on sony tvs without external hardware player?
Also no one is sure what is happening with these FEL players that actually play them, is the enhancement getting discarded?
Testing that should be pretty easy I guess? Just take comparison photographs in a pitch black room on a good tv. Comparing FEL file vs MEL file for the same movie?
