Goodmorning,
Recently I bought a second hand Asus Blu Ray reader (BC-12D2HT) under the (wrong) impression that every BC-12D2HT is using the MT1959 platform. Unfortunately Asus started building these drives in 2013 and my drive has a production date of september 2014 and is using the MT1939 platform.
When I start MakeMKV the following information is displayed:
Drive informatie
Naam OS-apparaat: H:
Fabrikant: ASUS
Product: BC-12D2HT
Revisie: 1.00
Serienummer: K9HE9UH0810
Firmware datum: 2113-06-14 12:00
Bus encryptie flags: 1E
Drive platform: MT1939
Firmware version: 1.00
BD raw metadata read: Partial
What does the status "Enabled" mean in the context of LibreDrive. Will this drive behave in the same way as LibreDrive enabled drives on the MT1959 platform?
Question about Asus BC-12D2HT
Re: Question about Asus BC-12D2HT
No it's not the same you don't get UHD support otherwise it's mostly the sameTheFonz wrote: Thu Oct 29, 2020 10:31 am
TheFonz
Thanks for your clear reply!
