If you're playing files off of your TV, I still think it's best to skip any of the complicated tools and just use mp4muxer to create a dual track profile 7 DV mp4. Then skip Plex and just host a DLNA server to play these files. It's the least complicated method and playback of ST DV TS files off the TV has been somewhat of a hit or miss depending on the title.longseason wrote: ↑Wed Oct 28, 2020 6:18 pmI dumped the test DV file from https://4kmedia.org/lg-dolby-vision-uhd-4k-demo/ on my server and it played without any further modification. Mediainfo reports the video stream in that as:
so looks like Profile 4?Code: Select all
Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU
Thanks, think I'll start here.
longseason
Yeah I think that might be the best bet, otherwise it's going to be a huge process for every film that will be hit or miss every time.shawnc22 wrote: ↑Wed Oct 28, 2020 6:30 pmIf you're playing files off of your TV, I still think it's best to skip any of the complicated tools and just use mp4muxer to create a dual track profile 7 DV mp4. Then skip Plex and just host a DLNA server to play these files. It's the least complicated method and playback of ST DV TS files off the TV has been somewhat of a hit or miss depending on the title.
Is profile 7 the most compatible format in this situation then?
Yeah, pretty much, so the method on the first couple pages of this thread still workslongseason wrote: ↑Wed Oct 28, 2020 6:45 pmYeah I think that might be the best bet, otherwise it's going to be a huge process for every film that will be hit or miss every time.shawnc22 wrote: ↑Wed Oct 28, 2020 6:30 pmIf you're playing files off of your TV, I still think it's best to skip any of the complicated tools and just use mp4muxer to create a dual track profile 7 DV mp4. Then skip Plex and just host a DLNA server to play these files. It's the least complicated method and playback of ST DV TS files off the TV has been somewhat of a hit or miss depending on the title.
longseason
As promised, here are some test files for you to try on LG devices.
GAMMA should now be able to return MP4 files as well (in addition to MKV ones).
I say "should" because today was a looooooooooooooooong day and I'm really tired (so forgive any mistakes).
Find the test files HERE.
They were all obtained from an initial m2ts FEL profile 7 file (only video, no audio).
The main reason why GAMMA has to return MP4 files is related to the "whispers" circulating these days that see the LG OLED 2020 TVs unable to play DTDL MP4 files.
Owners of these TVs should make sure the "FEL_to_Profile81.mp4" file is played.
@quietvoid pointed out to me that LG OLED TVs <= 2019 can still play DTDL files: having a faster method to generate this type of file would therefore be advantageous.
I modified GAMMA to get this type of file.
So, from a FEL m2ts file (profile 7) you can get the following MP4:
- DTDL_FEL.mp4
- DTDL_FEL_to_MEL.mp4
- STDL_FEL.mp4
- STDL_FEL_to_MEL.mp4
- FEL_to_Profile81.mp4
Try the files and let me know!
DTDL = Dual Track Dual Layer
STDL = Single Track Dual Layer
longseason
No such luck with DLNA with both an MP4 and TS file muxed with mp4muxer and tsMuxeR respectively but given the success on the first page I’m thinking it might be DLNA and not the files; need to dig up a big enough USB drive to test.
On my LG CX using Zidoo Z9X I can play all files but only STDL_FEL_to_MEL.mp4 engages DV.yusesope wrote: ↑Wed Oct 28, 2020 7:36 pm
- DTDL_FEL.mp4
- STDL_FEL.mp4
DaMacFunkin
Hi, these have been created to be played directly on the LG, not via an external player.blenky wrote: ↑Wed Oct 28, 2020 9:04 pmOn my LG CX using Zidoo Z9X I can play all files but only STDL_FEL_to_MEL.mp4 engages DV.yusesope wrote: ↑Wed Oct 28, 2020 7:36 pm
- DTDL_FEL.mp4
- STDL_FEL.mp4
I just tried the Files zidoo Z9X direct to Panasonic z1000 Oledyusesope wrote: ↑Wed Oct 28, 2020 7:36 pmAs promised, here are some test files for you to try on LG devices.
- DTDL_FEL.mp4
- STDL_FEL.mp4
All files played
All files brought up DV on tv
STDL Fel .mp4 was noticably stuttering/rest were all smooth
Problem were all seeing on zidoo z9x thou is short test files dont show the issues (probably due to Z9X being early beta firmware)
ie
Alita ..Makemkv .53 to MKV convert ...all works lovley til 5 mins in then noticable stutter and audio lags by 2 secs(atmos track)Mel 7
Funnily enuff same mkv file HDR 10+ and Atmos plays and looks perfect
finally managed to make a Gama version of a movie
exactly same issue ..worked fine till 4 5 mins then stutter and audio lag by 2 secs in DAMel 8.1 from mem (deleted file cos issue not sorted,and forget which movie)
again thou i believe its Zidoo firmware issues atm
Edit just saw your later comment to use direct to TV
Fel to 8.1 worked fine as dolby vision
All other files played as HDR PQ when direct to Panasonic z1000 OLED
Interesting playing the files on your Panasonic via Z9X all files play in DV but for me only STDL_FEL_to_MEL.mp4 played in DV on my LG CX. The rest in HDR10.cuculain wrote: ↑Wed Oct 28, 2020 9:26 pmI just tried the Files zidoo Z9X direct to Panasonic z1000 Oledyusesope wrote: ↑Wed Oct 28, 2020 7:36 pmAs promised, here are some test files for you to try on LG devices.
- DTDL_FEL.mp4
- STDL_FEL.mp4
All files played
ie
blenky
id updated my post once i saw you wanted files played direct to tv
only one the 8.1 played as DV rest all hdr pq only
Both DTDL files do not playback on the C8 internal player, the STDL ones trigger Dolby Vision but stutter.
Are you using the latest mp4muxer code from Github? It causes these issues on the C8 at least, while the first version posted in 2018 works perfectly. From this tree: https://github.com/DolbyLaboratories/dl ... 0d7ca4eabd
BTW, this is the only post I've seen mention the CX thing: https://www.makemkv.com/forum/viewtopic ... 477#p98477
So FWIW, still don't know how true it is.
Ok so I put the files on a USB stick and connected directly into my LG CX.DaMacFunkin wrote: ↑Wed Oct 28, 2020 9:10 pmHi, these have been created to be played directly on the LG, not via an external player.
FEL_to_Profile81.mp4 played in DV. All other files failed with the message "This file cannot be recognised..."
DaMacFunkin
Hi, I think that is what Yuescope was thinking might happen, it seems direct play of Profile 7 on the CX might have been crippled.blenky wrote: ↑Wed Oct 28, 2020 11:16 pmOk so I put the files on a USB stick and connected directly into my LG CX.DaMacFunkin wrote: ↑Wed Oct 28, 2020 9:10 pmHi, these have been created to be played directly on the LG, not via an external player.
There has been a North America firmware this week for the C9, it will be interesting to see if that can still play profile 7, it isn’t available in Europe yet so I can’t test it.
LG internal player CAN NOT play any DV mkv with dolby truehd atmos sound track, right ?DaMacFunkin wrote: ↑Thu Oct 29, 2020 6:46 amHi, I think that is what Yuescope was thinking might happen, it seems direct play of Profile 7 on the CX might have been crippled.blenky wrote: ↑Wed Oct 28, 2020 11:16 pmOk so I put the files on a USB stick and connected directly into my LG CX.DaMacFunkin wrote: ↑Wed Oct 28, 2020 9:10 pm
I am going to buy a CX model LG TV. Is there any way to handle DV mkv with dolby truehd atmos on CX model?
I am not a native English speaker.
Sorry for my bad English.
