Gladiator AV sync
Digital moe
Gladiator AV sync
Post by Digital moe »
So I have had loads if issues trying to rip this since the day it came out, every now and then i would give it a go and it always failed. Today however I used the method of cleaning a disc that was in the BTTF ASUS drive thread and it completed the rip, very slowly, like almost just shy of 2 hours but it done it nonetheless.
However the logs for the disc has a ton of AV Sync issues, I know most films seem to have a couple of these but this one had loads, is this anything to be worried about. I have played the file and jumped around in it and the audio all seems to be in sync.
AV synchronization issues were found in file 'C:/MKV/MKV 1/Gladiator_t04.mkv' (title #5)
AV sync issue in stream 1 at 0:16:22.731 with duration of 9.583ms : encountered overlapping frame, audio skew is +9.583ms
AV sync issue in stream 2 at 0:16:22.731 with duration of 20.25ms : encountered overlapping frame, audio skew is +20.25ms
AV sync issue in stream 1 at 0:18:46.875 with duration of 5.333ms : encountered overlapping frame, audio skew is +14.916ms
AV sync issue in stream 1 at 0:18:46.890 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 2 at 0:18:46.875 with duration of 16ms : encountered overlapping frame, audio skew is +36.25ms
AV sync issue in stream 2 at 0:18:46.912 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 1 at 0:31:49.407 with duration of 6.916ms : encountered overlapping frame, audio skew is +11.166ms
AV sync issue in stream 1 at 0:31:49.418 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.5ms
AV sync issue in stream 2 at 0:31:49.407 with duration of 28.25ms : encountered overlapping frame, audio skew is +32.5ms
AV sync issue in stream 2 at 0:31:49.440 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.5ms
AV sync issue in stream 1 at 0:32:54.222 with duration of 6.583ms : encountered overlapping frame, audio skew is +7.083ms
AV sync issue in stream 2 at 0:32:54.222 with duration of 17.25ms : encountered overlapping frame, audio skew is +17.75ms
AV sync issue in stream 1 at 0:52:38.655 with duration of 4.083ms : encountered overlapping frame, audio skew is +11.166ms
AV sync issue in stream 1 at 0:52:38.666 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.5ms
AV sync issue in stream 2 at 0:52:38.655 with duration of 14.75ms : encountered overlapping frame, audio skew is +32.5ms
AV sync issue in stream 2 at 0:52:38.688 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.5ms
AV sync issue in stream 2 at 0:54:56.751 with duration of 15.708ms : encountered overlapping frame, audio skew is +16.208ms
AV sync issue in stream 1 at 0:54:56.751 with duration of 5.041ms : encountered overlapping frame, audio skew is +5.541ms
AV sync issue in stream 1 at 1:06:07.088 with duration of 10.333ms : encountered overlapping frame, audio skew is +15.875ms
AV sync issue in stream 1 at 1:06:07.104 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +5.208ms
AV sync issue in stream 2 at 1:06:07.088 with duration of 31.666ms : encountered overlapping frame, audio skew is +47.875ms
AV sync issue in stream 2 at 1:06:07.136 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.875ms
AV sync issue in stream 2 at 1:07:40.890 with duration of 21.958ms : encountered overlapping frame, audio skew is +37.833ms
AV sync issue in stream 2 at 1:07:40.928 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.833ms
AV sync issue in stream 1 at 1:07:40.890 with duration of 0.625ms : encountered overlapping frame, audio skew is +5.833ms
AV sync issue in stream 1,2 at 1:17:43.158 with duration of 3.666ms : encountered overlapping frame, audio skew is +9.5ms
AV sync issue in stream 1 at 1:19:03.613 with duration of 3.291ms : encountered overlapping frame, audio skew is +12.791ms
AV sync issue in stream 1 at 1:19:03.626 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.125ms
AV sync issue in stream 2 at 1:19:03.613 with duration of 24.625ms : encountered overlapping frame, audio skew is +34.125ms
AV sync issue in stream 2 at 1:19:03.648 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.125ms
AV sync issue in stream 1 at 1:34:03.971 with duration of 4.875ms : encountered overlapping frame, audio skew is +7ms
AV sync issue in stream 2 at 1:34:03.971 with duration of 26.208ms : encountered overlapping frame, audio skew is +28.333ms
AV sync issue in stream 1 at 1:40:33.152 with duration of 3.541ms : encountered overlapping frame, audio skew is +10.541ms
AV sync issue in stream 2 at 1:40:33.152 with duration of 3.541ms : encountered overlapping frame, audio skew is +31.875ms
AV sync issue in stream 1 at 1:52:47.635 with duration of 1.583ms : encountered overlapping frame, audio skew is +12.125ms
AV sync issue in stream 1 at 1:52:47.648 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.458ms
AV sync issue in stream 2 at 1:52:47.635 with duration of 12.25ms : encountered overlapping frame, audio skew is +44.125ms
AV sync issue in stream 2 at 1:52:47.680 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.125ms
AV sync issue in stream 1 at 1:53:11.743 with duration of 9.916ms : encountered overlapping frame, audio skew is +11.375ms
AV sync issue in stream 1 at 1:53:11.754 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.708ms
AV sync issue in stream 2 at 1:53:11.743 with duration of 20.583ms : encountered overlapping frame, audio skew is +32.708ms
AV sync issue in stream 2 at 1:53:11.776 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.708ms
AV sync issue in stream 1,2 at 1:57:13.401 with duration of 5.916ms : encountered overlapping frame, audio skew is +6.625ms
AV sync issue in stream 1,2 at 2:00:52.119 with duration of 1.5ms : encountered overlapping frame, audio skew is +8.125ms
AV sync issue in stream 1 at 2:08:49.221 with duration of 7.708ms : encountered overlapping frame, audio skew is +15.833ms
AV sync issue in stream 1 at 2:08:49.237 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +5.166ms
AV sync issue in stream 2 at 2:08:49.221 with duration of 18.375ms : encountered overlapping frame, audio skew is +26.5ms
AV sync issue in stream 1 at 2:10:21.563 with duration of 9.75ms : encountered overlapping frame, audio skew is +14.916ms
AV sync issue in stream 1 at 2:10:21.578 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 2 at 2:10:21.563 with duration of 9.75ms : encountered overlapping frame, audio skew is +36.25ms
AV sync issue in stream 2 at 2:10:21.600 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 1,2 at 2:15:58.233 with duration of 2.333ms : encountered overlapping frame, audio skew is +6.583ms
AV sync issue in stream 1,2 at 2:18:21.584 with duration of 8.458ms : encountered overlapping frame, audio skew is +15.041ms
AV sync issue in stream 1 at 2:18:21.600 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.375ms
AV sync issue in stream 1 at 2:28:22.518 with duration of 5ms : encountered overlapping frame, audio skew is +9.375ms
AV sync issue in stream 2 at 2:28:22.518 with duration of 26.333ms : encountered overlapping frame, audio skew is +41.375ms
AV sync issue in stream 2 at 2:28:22.560 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.375ms
jayper
Re: Gladiator AV sync
Post by jayper »
Short answer: Nothing is wrong.
Longer answer: viewtopic.php?f=12&t=22903&p=94894#p94894
Digital moe
Thanks that link is great summary.
