longseason
Post by longseason » Wed Oct 28, 2020 8:59 pm
shawnc22 wrote:
Wed Oct 28, 2020 7:03 pm
Yeah, pretty much, so the method on the first couple pages of this thread still works
No such luck with DLNA with both an MP4 and TS file muxed with mp4muxer and tsMuxeR respectively but given the success on the first page I’m thinking it might be DLNA and not the files; need to dig up a big enough USB drive to test.
blenky
Post by blenky » Wed Oct 28, 2020 9:04 pm
yusesope wrote:
Wed Oct 28, 2020 7:36 pm
As promised, here are some test files for you to try on LG devices.
GAMMA should now be able to return MP4 files as well (in addition to MKV ones).
I say "should" because today was a looooooooooooooooong day and I'm really tired (so forgive any mistakes).
Find the test files HERE.
They were all obtained from an initial m2ts FEL profile 7 file (only video, no audio).
The main reason why GAMMA has to return MP4 files is related to the "whispers" circulating these days that see the LG OLED 2020 TVs unable to play DTDL MP4 files.
Owners of these TVs should make sure the "FEL_to_Profile81.mp4" file is played.
@quietvoid pointed out to me that LG OLED TVs <= 2019 can still play DTDL files: having a faster method to generate this type of file would therefore be advantageous.
I modified GAMMA to get this type of file.
So, from a FEL m2ts file (profile 7) you can get the following MP4:
  • DTDL_FEL.mp4
  • DTDL_FEL_to_MEL.mp4
  • STDL_FEL.mp4
  • STDL_FEL_to_MEL.mp4
  • FEL_to_Profile81.mp4
Try the files and let me know!
DTDL = Dual Track Dual Layer
STDL = Single Track Dual Layer
On my LG CX using Zidoo Z9X I can play all files but only STDL_FEL_to_MEL.mp4 engages DV.
DaMacFunkin
Post by DaMacFunkin » Wed Oct 28, 2020 9:10 pm
  • DTDL_FEL.mp4
  • STDL_FEL.mp4
Hi, these have been created to be played directly on the LG, not via an external player.
cuculain
Post by cuculain » Wed Oct 28, 2020 9:26 pm
PlatypusW wrote:
Tue Oct 27, 2020 11:39 am
I have an LG CX so happy to test...
quietvoid wrote:
Tue Oct 27, 2020 7:00 pm
Oh, I thought you were referring to dual track mp4 as well. Those are pretty much the only reason I'd convert to mp4, because the C8 still supports them as profile 7 FEL.
  • DTDL_FEL.mp4
  • STDL_FEL.mp4
I just tried the Files zidoo Z9X direct to Panasonic z1000 Oled
All files played
All files brought up DV on tv
STDL Fel .mp4 was noticably stuttering/rest were all smooth
Problem were all seeing on zidoo z9x thou is short test files dont show the issues (probably due to Z9X being early beta firmware)
ie
Alita ..Makemkv .53 to MKV convert ...all works lovley til 5 mins in then noticable stutter and audio lags by 2 secs(atmos track)Mel 7
Funnily enuff same mkv file HDR 10+ and Atmos plays and looks perfect
finally managed to make a Gama version of a movie
exactly same issue ..worked fine till 4 5 mins then stutter and audio lag by 2 secs in DAMel 8.1 from mem (deleted file cos issue not sorted,and forget which movie)
again thou i believe its Zidoo firmware issues atm
Edit just saw your later comment to use direct to TV
Fel to 8.1 worked fine as dolby vision
All other files played as HDR PQ when direct to Panasonic z1000 OLED
blenky
Post by blenky » Wed Oct 28, 2020 10:06 pm
  • DTDL_FEL.mp4
  • STDL_FEL.mp4
All files played
ie
Interesting playing the files on your Panasonic via Z9X all files play in DV but for me only STDL_FEL_to_MEL.mp4 played in DV on my LG CX. The rest in HDR10.
cuculain
Post by cuculain » Wed Oct 28, 2020 11:10 pm
blenky
id updated my post once i saw you wanted files played direct to tv
only one the 8.1 played as DV rest all hdr pq only
quietvoid
Post by quietvoid » Wed Oct 28, 2020 11:13 pm
Both DTDL files do not playback on the C8 internal player, the STDL ones trigger Dolby Vision but stutter.
Are you using the latest mp4muxer code from Github? It causes these issues on the C8 at least, while the first version posted in 2018 works perfectly. From this tree: https://github.com/DolbyLaboratories/dl ... 0d7ca4eabd
BTW, this is the only post I've seen mention the CX thing: https://www.makemkv.com/forum/viewtopic ... 477#p98477
So FWIW, still don't know how true it is.
blenky
Post by blenky » Wed Oct 28, 2020 11:16 pm
Ok so I put the files on a USB stick and connected directly into my LG CX.
FEL_to_Profile81.mp4 played in DV. All other files failed with the message "This file cannot be recognised..."
DaMacFunkin
Post by DaMacFunkin » Thu Oct 29, 2020 6:46 am
Hi, I think that is what Yuescope was thinking might happen, it seems direct play of Profile 7 on the CX might have been crippled.
There has been a North America firmware this week for the C9, it will be interesting to see if that can still play profile 7, it isn’t available in Europe yet so I can’t test it.
badrobot
Post by badrobot » Thu Oct 29, 2020 7:27 am
LG internal player CAN NOT play any DV mkv with dolby truehd atmos sound track, right ?
I am going to buy a CX model LG TV. Is there any way to handle DV mkv with dolby truehd atmos on CX model?
I am not a native English speaker.
Sorry for my bad English.
cuculain
Post by cuculain » Thu Oct 29, 2020 7:36 am
hopefully Zidoo will get the firmware sorted with their new range of mediaplayers
ive got the Z9X and its a noticeable upgrade video wise on the older z9S
firmwares not quite there with mkv DV
but hdr10+ seems to be working fine,and theyve always been solid re Atmos etc
ie Alita full rip makemkv .53 to mkv file
HDR 10+ and full atmos works fine looks lovely
same file trying DV atm looks lovely but loses synch after 5 mins and audios out by 2 secs ...VERY early on in the firmware thou
Forced DV lldl works pretty well too
something really old like Space1999 epis from 1975ish come out looking much improved vs normal when using forced DV...ie grey starry backgrounds become inky black
Metals look like metals,and faded clothing gains lots of colours back ..... just as an example
DaMacFunkin
Post by DaMacFunkin » Thu Oct 29, 2020 7:40 am
It can’t play DV from MKV full stop, that is why these files are mp4.
Only way is to get an external player.
DaMacFunkin
Post by DaMacFunkin » Thu Oct 29, 2020 7:46 am
I think even the Zidoo will need profile 8 for FEL titles, I just don’t see Dolby allowing a loophole that enables profile 7 FEL to be converted to single track dual layer AND play back correctly.
badrobot
Post by badrobot » Thu Oct 29, 2020 9:05 am
@DaMacFunkin
External player means APP like Plex?
Is Plex on LG CX model capable of playing DV mkv with Dolby truehd atmos ? thanks
DaMacFunkin
Post by DaMacFunkin » Thu Oct 29, 2020 10:54 am
@DaMacFunkin
No, external player means external hardware.
Internal Plex app will only transport what the internal decoder determines valid, everything else will transcode or not play, including True-HD.
