[SOLVED] M:I 6 - Fallout UHD
WAYFLIX
Post by WAYFLIX »
Any tricks to this one that I haven't tried?
3 UHD discs that where brand new. MakeMKV 1.15.1,2 and 3. Windows 10 and OSX. Asus drive and 2 LG drives. All exhibt the same errors:
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00067.m2ts' at offset '30474104832'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '30474104832'
Failed to save title 0 to file D:/Rips/Mission- Impossible Fallout_t00.mkv
0 titles saved, 1 failed
Digital moe
Re: M:I 6 - Fallout UHD
Post by Digital moe »
I had loads of problems with 2 copies of Fallout, in the last few days I have learnt some discs just need some serious cleaning:
This is some advice from the BTTF thread which is working on movies that I have been previously been unable to rip, heck it even did Gladiator today, had it since the day it came out no matter what I did it wouldn't rip, but this fixed that too.
kurayamino wrote: Fri Oct 23, 2020 6:57 am This isn't a firmware or drive problem. There is a thin film on the bottom of the discs left over from the manufacturing process which causes these read errors. I put some 99% isopropyl alcohol on soft toilet paper and carefully but firmly wiped across the bottom of the discs. After the alcohol evaporated I wiped them down again using a microfiber cloth to remove any residue from the alcohol.
All three discs worked perfectly afterwards.
WAYFLIX
Re: [SOLVED] M:I 6 - Fallout UHD
Post by WAYFLIX »
I tried what you quoted a few times. Shortly after I posted however I finally got lucky! The combination of cleaning, OSX, LG drive (mk1.0.5) and MakeMKV 1.15.1 worked! It took a very long time to rip. I’m making a back up copy and running it through MakeMKV 1.15.3 to get the DV information back.
