Splitting single .mpls file with multiple video files but no chaptering
theundefeatednoob
Post by theundefeatednoob »
I am new to this forum and I need some assistance regarding splitting m2ts files. First off I am working with an SSH connected seedbox so there is no GUI and I use mkvtoolnix via command line and I am not that proficient with Linux but I know my way around a couple of things. Anyway, when I am making a REMUX of a Blu ray with combined episodes in a single .m2ts file I would first check the chaptering of the Blu ray whilst within the BDMV PLAYLIST folder with the command mediainfo xxxxx.mpls and it gives me the chapter layout etc and I would proceed to use the command mkvmerge xxxxx.mpls --split chapters:x,y,z -o output.mkv and it gives me the split mkv as output. But now I have an issue with the BDMV for Seitokai Ichizon (Student Council's Discretion). When I try to see the chaptering for reference, there is only 1 chapter and multiple video sources and I am not sure how to go about splitting this BDMV into multiple episodes. I have managed to extract the multiple xml files contained within the first 00000.mpls file but I do not know where to go from here.
General
Complete name                            : 00000.mpls
Format                                   : Blu-ray Playlist
File size                                : 1.10 KiB
Duration                                 : 2 h 26 min
Overall bit rate                         : 1 b/s
Video #1
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Duration                                 : 1 s 1 ms
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Frame rate                               : 23.976 (23976/1000) FPS
Video #2
Format                                   : AVC
Duration                                 : 48 min 52 s
Video #3
Format                                   : AVC
Video #4
Format                                   : AVC
Video #5
Format                                   : AVC
Duration                                 : 13 s 13 ms
Audio #1
Format                                   : PCM
Duration                                 : 1 s 1 ms
Channel(s)                               : 2 channels
Language                                 : Japanese
Audio #2
Format                                   : PCM
Language                                 : Japanese
Audio #3
Format                                   : PCM
Language                                 : Japanese
Audio #4
Format                                   : PCM
Language                                 : Japanese
Audio #5
Format                                   : PCM
Language                                 : Japanese
Menu
00:00:00.000                             : Chapter 1
Re: Splitting single .mpls file with multiple video files but no chaptering
You need tools other than MakeMKV for what you're trying to do.
Also, my logs show that this title comes with per-episode play lists, so if it was ripped by MakeMKV, you don't have to do anything special to split out episodes or chapters.
theundefeatednoob
Woodstock wrote:
Wed Oct 28, 2020 11:35 pm
Thank you for the reply. I ended up getting the chapter .xml files by opening the 00000.mpls file with the program called pymplschapters and discovered that the 00000.mpls had the playlists corresponding to 5 .m2ts files (00000.m2ts, 00001.m2ts, 00002.m2ts, 00006.m2ts & 00010.m2ts of which 01,06 & 10 were the main files containing 2 episodes each and each main m2ts file had 11~12 chapters with the extra file having 1 chapter each for a total of 37 chapters) , but I still was not sure on how to proceed. And I will again stress the fact that I suck at working only in command line, so I ended up taking the long route of first converting the 00000.mpls into an output.mkv by using the command mkvmerge 00000.mpls -o output.mkv and it joined all 6 episodes plus the extra 00000.m2ts (a 1 sec black screen) and 00002.m2ts (a 13 sec warning text screen). The output was a 39.1gb file with all 37 chapters and I managed to separate the files with the mkvmerge --split by chapters command. I am yet to check after uploading to my drive whether it has gone smoothly or whether I have to redo it all again until I get it right. 5 of the 6 episodes had the correct time of 24 minutes 26 seconds with the last episode having an extra 13 seconds for a total of 24 minutes 39 seconds.
