Help Dvd ripping
getburned2098
Help Dvd ripping
I been getting lot of this? anyone know how to fix it? I don't know what this is called but it happens lot when I rip any of the dvds I have.
Re: Help Dvd ripping
I am not a pro.
But I think the deinterlace option in VLC will work.
Looks like interlacing to me as well.
http://en.wikipedia.org/wiki/Interlaced_video
It's not a problem with the program it's just the way the source is, it'd look perfectly fine on an older tube television.
You get it bad with MakeMKV because it brings the video to your computer as is, if you encode that video using some kind of encoder you'd have the option to deinterlace it, or you should have the ability to deinterlace your titles within your software player of choice on your computer(most can), but that can result in artifacts of it's own. It's unfortunately probably always going to be that way with old titles unless they get some kind of fancy remaster and re-release.
Besides interlacing it could also be telecine. Please post mediainfo output of the file.
getburned2098
seems like deinterlace worked made it look better, is this what you want?
Debug log started at Thu Dec 30 21:13:19 2010 , written by MakeMKV v1.6.3 win(x86-release)
001005:0000 MakeMKV v1.6.3 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\xxxxxxx/MakeMKV_log.txt
003025:0000 Title #0 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #1 was added (7 cell(s), 0:42:48)
003028:0000 Title #2 was added (7 cell(s), 0:42:49)
003028:0000 Title #3 was added (22 cell(s), 0:11:21)
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003025:0000 Title #4 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=4 pgcn=2 hash=A29C064E587549DC
003025:0000 Title #5 has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=5 pgcn=1 hash=AA110F90222629D4
003028:0000 Title #6 was added (13 cell(s), 0:48:41)
003028:0000 Title #7 was added (1 cell(s), 0:03:54)
005014:0000 Saving 5 titles into directory C:/Users/xxxxxxxxx/Desktop
005005:0080 5 titles saved
005036:0104 Copy complete. 5 titles saved.
Application exited at Thu Dec 30 23:49:16 2010
No, post output of this: http://mediainfo.sourceforge.net
also read this:
http://trac.handbrake.fr/wiki/Telecine
and
http://trac.handbrake.fr/wiki/DeinterlacingGuide
Most likely if it is american it is telecined and not interlaced.
also read this:
and
