agneva
Post
by agneva » Tue Oct 27, 2020 7:51 am
DaMacFunkin wrote: Mon Oct 26, 2020 2:59 pm
agneva wrote: Mon Oct 26, 2020 1:39 pm
I have the 77CX9LA
the other option was "mobile with dolby vision", I took "theather" in DVD Fab.
Hi This isn't the Fab support room, also you are using a demo, probably the new version, this is how it should look in version 11, you choose the profile, select the spanner and choose single track, you may need to adapt.
P.S. Choose copy video, you don't wan to transcode, or do you?
I got it as you said
/ works great, thank you!
What can the LG OLED play in mp4 DV? only AC3 5.1 640kbit/s ?
vobsub is muxed and shown to choose in tv-menu, but it doesn´t work.
a separate file with *.srt works.
DaMacFunkin
Post
by DaMacFunkin » Wed Oct 28, 2020 5:58 am
agneva wrote: Tue Oct 27, 2020 7:51 am
I have the 77CX9LA
You can choose Dolby Digital + from within fab at a higher bit rate up to 7.1 or you can mux in DTS-HD with mp4 mux, obviously you only get core playback unless you have eARC capable receiver.
agneva
Post
by agneva » Wed Oct 28, 2020 7:08 am
ok, I want to try
but I don´t find a "mp4toolnix"
Do I have to work with ffmpg + mp4box in command line?
Digital moe
Post
by Digital moe » Wed Oct 28, 2020 7:36 pm
So can I just confirm something, is MakeMKV creating a single or dual layer file? And is it single or dual layer that Plex now supports?
Post
by shawnc22 » Wed Oct 28, 2020 7:44 pm
Digital moe wrote: Wed Oct 28, 2020 7:36 pm
They are single track dual layer files. Plex supports it, but the more important thing that matters is whether the hardware that runs Plex supports it.
DaMacFunkin
Post
by DaMacFunkin » Wed Oct 28, 2020 7:54 pm
shawnc22 wrote: Wed Oct 28, 2020 7:44 pm
...or decodes it properly...
DaMacFunkin
Post
by DaMacFunkin » Wed Oct 28, 2020 7:55 pm
agneva wrote: Wed Oct 28, 2020 7:08 am
ok, I want to try
I already posted you the link.
Digital moe
Post
by Digital moe » Wed Oct 28, 2020 8:24 pm
Thanks, is there a way to see this whether something is single or dual layer in Mediainfo?
Post
by shawnc22 » Wed Oct 28, 2020 9:05 pm
Digital moe wrote: Wed Oct 28, 2020 8:24 pm
If there is a mention of EL in mediainfo, then it's dual layer.
DaMacFunkin
Post
by DaMacFunkin » Tue Nov 03, 2020 10:11 pm
Hi Mike,
The Hunt For Red October reports as FEL when it is reported on blu-ray.com database as MEL.
The ripped makemkv doesn’t play on Zidoo at all, it just hangs.
Can you fix this or is there a way to rip it correctly as Profile 7 MEL?
Cheers.
Mr_Orange
Post
by Mr_Orange » Tue Nov 03, 2020 10:44 pm
DaMacFunkin wrote: Tue Nov 03, 2020 10:11 pm
Hi Mike,
Cheers.
The blu-ray.com database could be wrong. It wouldn't be the first time!
DaMacFunkin
Post
by DaMacFunkin » Wed Nov 04, 2020 5:55 am
Mr_Orange wrote: Tue Nov 03, 2020 10:44 pm
Hi Mike,
Cheers.
The fact that a straight rip doesn’t play in any way shape or form tells me something isn’t correct.
It also wouldn’t be the first time makemkv has been wrong, Mike and Youesepe have had more than one ‘discussion’ about this.
Can anybody else verify this title please?
jayper
Post
by jayper » Wed Nov 04, 2020 3:37 pm
DaMacFunkin wrote: Wed Nov 04, 2020 5:55 am
Hi Mike,
Cheers.
I just checked my back-up, and the MKV I created:
MakeMKV when decrypting disc:
- Backup.png (4.59 KiB) Viewed 28361 times
Mediainfo report from the resulting MKV:
- mkv.png (3.04 KiB) Viewed 28361 times
DaMacFunkin
Post
by DaMacFunkin » Wed Nov 04, 2020 4:20 pm
jayper wrote: Wed Nov 04, 2020 3:37 pm
Thanks, what does mediainfo say from the original mlps?
jayper
Post
by jayper » Wed Nov 04, 2020 4:55 pm
DaMacFunkin wrote: Wed Nov 04, 2020 4:20 pm
mpls:
- 222mpls.png (1.71 KiB) Viewed 28349 times
The same is true for the m2ts file. No mention of DV.
