quietvoid
#3481 Post by quietvoid » Tue Oct 27, 2020 11:50 am
PlatypusW wrote:
Tue Oct 27, 2020 11:39 am
I have an LG CX so happy to test. I’m not sure if it would gain anything over the fire stick though? But would be great for comparisons and it might even end up being better if some of the hdmi vs internal apps DV ‘settings’ queries turn out to be true. I’d love to try getting 7.1 pcm out of it as well, I didn’t know mp4 could contain that.
The firestick doesn't play FEL so yes, a more convenient and faster way to create mp4s would be good for use in the LG internal player.
PlatypusW
#3482 Post by PlatypusW » Tue Oct 27, 2020 2:19 pm
This is true, if there is a faster way to create a playable file then I'm all for it. Definetely willing to do some tests to see what files will playback on the CX. My last attempt didn't work out so well though :P
koolkunz
#3483 Post by koolkunz » Tue Oct 27, 2020 3:17 pm
koolkunz wrote:
Tue Oct 27, 2020 5:10 am
I have a couple of questions that might sound dumb (please bear with me I got my first Dolby Vision TV-Sony X900H last week only)
1) When we are converting FEL file to MEL we are losing the advantages FEL has over MEL right?
2) When we are converting FEL file to 8.1, does the FEL data get retained?
Also I see your exoplayer being reffered a lot in your previous posts but I couldnt find it please link it.
And can anyone guide me to what is the difference between the various dolby vision profiles?
MY final goal is to be able to play FEL dolby vision mkvs/mp4s/ts through Plex or Kodi on my Sony X900H (Android TV). MEL/8.1 profile MKVs/MP4s play correctly already.
Anyone who can answer these questions please?
yusesope
#3484 Post by yusesope » Tue Oct 27, 2020 3:58 pm
Correct. It is normal to have to give up something with this type of conversion (FEL->MEL) but the "losses" may not be as severe. Read THIS post and check out @RESET_9999 comparisons
Profile 8.1, by its nature, does not include any Enhancement Layer.
Read the official documentation to get an idea of ​​the various profiles (Chapter 2)
You can find my player HERE (to be used in conjunction with a DLNA server). Anyway, you better try the latest beta of PLEX.
To get an idea of ​​the capabilities of your TV then use @PapitaHD samples
DaMacFunkin wrote:
Tue Oct 27, 2020 10:58 am
Plex app is outputting AAC 5.1 / 7.1 as PCM 2.0.
All these limitations are currently being discussed on Kodi and Plex forums.
:shock: :shock:
Perfect for 1995 ...
From what I remember, owners of LG TVs have always had problems with my Single Track Dual Layer profile 7 files.
LGs were famous for their ability to play Dual Track Dual Layer profile 7 mp4 files.
Now that this functionality seems to have been inhibited, maybe my files (profile 8.1) can partially make up for the loss.
I don't have much hope in profile 7 (FEL/MEL) but the new LGs may be able to reproduce them (I am referring to the STDL files) ... only by trying will we find out.
Technically I have the possibility to store also an ATMOS/TrueHD audio track inside an MP4 container.
The problem is the device that has to play it. For example, I don't think your LG is capable of playing a multichannel PCM track or an ATMOS/TrueHD track in an mp4 file.
I remember I was unpleasantly surprised by the eARC implementation on the 2019 LG OLEDs (especially when using the internal player). I hope things have improved.
quietvoid
#3485 Post by quietvoid » Tue Oct 27, 2020 7:00 pm
Oh, I thought you were referring to dual track mp4 as well. Those are pretty much the only reason I'd convert to mp4, because the C8 still supports them as profile 7 FEL.
8.1 being the only option kinda kills the idea for me, I'd just remux to MKV and play on the Firestick.
I think I've read that the 2020 models had an update that made them unable to play the dual track files.
PlatypusW
#3486 Post by PlatypusW » Tue Oct 27, 2020 10:54 pm
That’s a bit worrying. I wonder how long fire stick / shield lasts if that was the case :shock:
No doubt Dolby forced them too...
kws53
#3487 Post by kws53 » Wed Oct 28, 2020 3:03 am
yusesope wrote:
Tue Oct 27, 2020 8:52 am
Only the latest version of Mediainfo (Version 20.09, 2020-10-09) is capable of detecting DV in a MKV container.
I sincerely hope your version of Mediainfo is up to date...
otherwise...
I will look for you, I will find you, and I will patch you...
Indeed I wasn't aware of the failings of MediaInfo 20.08. Upgraded to 20.09 and good to go.
Next challenge - will Plex or Shield recognize the MKV as DV?
Thanks, again.
dmartinvera00
#3488 Post by dmartinvera00 » Wed Oct 28, 2020 4:02 am
Hello. I don't know how to mux the .dtshd to the .mp4 (muxed with mp4muxer), I've tried with mp4box but it says this message
E:\gpac-0.9.0-DEV-latest-filters-x64>MP4Box -add 2.dtshd dsd.mp4
[FFDmx] Fail to open 2.dtshd - error Error number -360024468 occurred
[Importer] Error probing 2.dtshd
Error importing 2.dtshd: Filter not found for the desired type
dapope
#3489 Post by dapope » Wed Oct 28, 2020 4:56 am
LG CX 2020 owners, for example, may be interested - they could take advantage of GAMMA's speed to generate MP4 files with DV (profile 8.1) and with custom audio and subtitles.
Is anyone interested or am I wasting my time?
I tested flac and wav surround speaker set up files. LG CX internal player only seems to know what to do with the stereo channels. I think you are unlikely to get 7.1 pcm playback.
longseason
#3490 Post by longseason » Wed Oct 28, 2020 5:08 pm
Apologies if I've missed this somewhere along the line (I've read a lot of this thread but not all of it!) but has it been determined if there's some combination of MakeMKV/tsMuxeR/mp4muxer that will combine the separate 4K HEVC and 1080p DV HEVC tracks in an M2TS rip into a single HEVC stream?
I've determined that Plex (from a server, not Shield) will happily a play a single DV encoded HEVC on my LG C7 if it's muxed as a TS - but the last piece of the puzzle seems to be taking the two-stream M2TS and converting it to a single video stream, or is this part just not possible?
kws53
#3491 Post by kws53 » Wed Oct 28, 2020 5:26 pm
Can I convert a GAMMA generated MKV DV profile 7 to a profile 5?
I'm trying to play it on a Plex Server/Shield/CX77 combo.
And is there a solution for Sony x700 through the CX77?
Using Yusesope's GAMMA, I can test a lot of options...
#3492 Post by shawnc22 » Wed Oct 28, 2020 5:30 pm
If you read a lot of this thread and missed the answer to that question, then yeah you missed quite a bit. The whole purpose of yusecope's tool -> tsMuxer and the new version of makemkv is to convert dual track DV into single track DV.
kws53
#3493 Post by kws53 » Wed Oct 28, 2020 5:32 pm
Possible - but how do you know it will play a single layer DV encoding? And, if so, what profile?
For TS, try Yusesope's ALPHA method
For MKV, try GAMMA method
Neither version actually needs MakeMKV if you have an alternative ripping solution...
longseason
#3494 Post by longseason » Wed Oct 28, 2020 6:18 pm
I dumped the test DV file from https://4kmedia.org/lg-dolby-vision-uhd-4k-demo/ on my server and it played without any further modification. Mediainfo reports the video stream in that as:
Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU
so looks like Profile 4?
Thanks, think I'll start here.
salimkhan
#3495 Post by salimkhan » Wed Oct 28, 2020 6:28 pm
thelittleworm wrote:
Wed Dec 26, 2018 10:37 pm
So apparently there's a method to backup UHD ISO's into MP4's that triggers Dolby Vision on an LG or Vizio television app via USB. I made this thread in the hopes we can figure out a way to reconvert this into MKV. The procecure is the following -
1. Make ISO of movie. I have only tested this with Black Panther since that's the only one I own. I will be buying Gladiator this weekend to test out though.
2. Use TS Muxer to open the ISO. Find the correct M2TS file and demux the following files:
A. HEVC1 in 4K (Base layer)
B. HEVC 2 in 1080p (this is the dolby vision enhancement layer)
C. Audio track which you will have to convert to AC3. This is a hard line limitation- you need to use AC3!!!
3. Once you have HEVC1, HEVC2, and the Audio track. Run Dolby Vision MP4Muxer (https://github.com/DolbyLaboratories/dlb_mp4base)
DolbyVision MP4 Muxer only works in Command Prompt so you have to navigate to the corresponding folders where the files are and type
mp4muxer --dv-profile 7 --input-file (baselayername.hevc1) --input-file (dvlayername.hevc2) --input-file (audio.ac3) --media-lang eng --output-file (nameofmovie).mp4
*Right now we are limited to only MP4 and AC3 audio. Hoping we figure out an MKV solution.
It sounds like its complicated, but it isn't. The entire process took me an hour to figure out, but once I did it, I sold my Xbox One X, because I'm now using my LG USB to play Dolby Vision MP4's! Hopefully this starts a discussion.
This just creates a dual-layer DV file, not a single layer one. How to do it? Can any1 help me please?
