Forrest Gump UHD errors
deathangelkiller
Post by deathangelkiller »
I am getting errors on a brand new UHD bluray -
The disk looks perfectly fine, except from my research there are some manufacturing defects on the inner ring that look like scratches/refraction. From what I read that won't effect reading of data as there is no data on the inner ring. I have cleaned it with a microfiber cloth. I was able to back it up but after the backup I haven't been able to make the mkv. Is this disc dead or is this a disk drive problem? It occurs at a similar point in time each time I try the rip (~25gig ripped).
I have a WH16NS40-NS50 with WH16NS60 firmware 1.03MK. My speed settings are: B1=99;B2=99;U1=99;U2=99
I also run into the disk drive just disappearing from my system until I restart, is this the sleep bug? Or is the drive going bad (drive is brand new from amazon)? Are there any stress tests I could do to identify if it is a disk drive hardware issue? Can disk drives overheat (due to running at faster than advertised speeds)? I just started getting into this this past weekend so I am still trying to understand what problems cause what.
Debug Log-
DEBUG: Code 1 at j_2*gIk0SDRBlYdA[&(.:29394758
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 29433139200, attempting to work around
Hash check failed for file 00010.m2ts at offset 29433194496, file is corrupt.
DEBUG: Code 2 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 3 at j_2*gIk0SDRBlYdA[&(.:29394758
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 29433169920, attempting to work around
DEBUG: Code 4 at j_2*gIk0SDRBlYdA[&(.:29394758
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 29433182208, attempting to work around
DEBUG: Code 5 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 6 at j_2*gIk0SDRBlYdA[&(.:29394758
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 29433262080, attempting to work around
DEBUG: Code 7 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 8 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 9 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 10 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 11 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 12 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 13 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 14 at j_2*gIk0SDRBlYdA[&(.:29394758
DEBUG: Code 15 at j_2*gIk0SDRBlYdA[&(.:29394758
Hash check failed for file 00010.m2ts at offset 29433391104, file is corrupt.
DEBUG: Code 69888 at j_2*gIk0SDRBlYdA[&(.:29395563
DEBUG: Code 141 at j_2*gIk0SDRBlYdA[&(.:213133250
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:213131157
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:213131272
DEBUG: Code 14371830 at )|-Dt0UfP<I#NHOVBsLn:121261773
DEBUG: Code 0 at !I9dd\a\uxpm~\US;lv[8:213129984
DEBUG: Code 0 at G-:2J:LOr}j3QY>HbnolD:213137091
DEBUG: Code 2 at u4R:e/r%V,|GP!| :213132330
Failed to save title 0 to file E:/Video/Movies/Forrest Gump/Forrest Gump_t00.mkv
Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
deathangelkiller
Re: Forrest Gump UHD errors
Update, I reflashed to WH16NS60 Firmware 1.02MK and the results were the same.
Was the backup you made a decrypted backup?
As a test, you could perhaps try setting the speed to something slower, like "0=8" to run at 2x speed.
https://www.makemkv.com/forum/viewtopic ... 19&t=22689
As for drives having problems because of speed, the most common issue is running out of power if the drive is in a usb powered enclosure. Forcing it to run slow should help alleviate that issue.
deathangelkiller
I was able to get it to make the mkv, after running it with no speed setting set. I am still experiencing the drive just disappearing from my system if I try to run it at a certain speed with this specific disk. It's on a dedicated power from my power supply so there shouldn't be a power problem. Not sure what is going on. I tried flashing to 1.01MK to make sure the sleep bug wasn't the cause, if anything this just caused the failure at high speed occur quicker. I am going re-flash to 1.02MK and see what happens. At this point I am debugging the disk drive so I probably will make a new post in the UHD disk forum if I can't figure out what is causing the drive to drop from the system. Thanks for the help!
