I'm running 1.15.3 and I think I've found the problem. There are two UHD 4K Bluray disks out there in the market. One is UK/Australia which is HDR only, and the other is a USA version which has Dolby Vision. I've lucked out when I bought it from Amazon and received a UK/Australia version without Dolby Visionshawnc22 wrote: ↑Mon Oct 26, 2020 3:44 pmNot sure what you're doing wrong, but my copy is showing up as BL+FEL+RPU just fine. Are you sure you're opening the title that's labeled as "Terminator: Dark Fate - 20 chapter(s), 58.3 GB". Otherwise, double check the version of your makemkv.
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
Correct. I just checked mine and the Aussie version does not have DV.Larrikin wrote: ↑Mon Oct 26, 2020 10:58 pmI'm running 1.15.3 and I think I've found the problem. There are two UHD 4K Bluray disks out there in the market. One is UK/Australia which is HDR only, and the other is a USA version which has Dolby Vision. I've lucked out when I bought it from Amazon and received a UK/Australia version without Dolby Vision. Makes no sense to me why there are two different disc versions for exactly the same movie.
Different studios in different regions is the answer. Paramount released it in the US, 20th Century Fox in the UK.Larrikin wrote: ↑Mon Oct 26, 2020 10:58 pmI'm running 1.15.3 and I think I've found the problem. There are two UHD 4K Bluray disks out there in the market. One is UK/Australia which is HDR only, and the other is a USA version which has Dolby Vision. I've lucked out when I bought it from Amazon and received a UK/Australia version without Dolby Vision. Makes no sense to me why there are two different disc versions for exactly the same movie.
I have the ExoPlayer working. Is there a code I can put in to make any MKV ply automatically using exoplayer? At the moment I need to go down to play movie using... on Kodi. Would love to find a way to eliminate that.
Can you reshare the latest yusecope's modified ExoPlayer apk? I would like to install it into FireTV 4k under Kodi.shawnc22 wrote: ↑Sat Jul 25, 2020 9:29 pmSure of course. Here is the latest version of yusecope's modified ExoPlayer apk:
https://wetransfer.com/downloads/581a34 ... 917/ba7865
Please note that I have only tested short sample clips made from makemkv 1.15.2 and not a full length title. Also this has only been tested on the 2019 Shield Pro, so YMMV on other Android devices. And finally, all credit goes to yusecope and thanks again for the great work.
pistachiomatt
How can I disable Dolby Vision muxing? This one mux is producing overly saturated results and I want to generate a non-Vision HDR version to a/b test.
Why not just use an earlier version of MakeMKV prior to it supporting Dolby Vision?pistachiomatt wrote: ↑Tue Nov 03, 2020 2:52 amHow can I disable Dolby Vision muxing? This one mux is producing overly saturated results and I want to generate a non-Vision HDR version to a/b test.
pistachiomatt
Tried that. Earlier versions (even the immediate preceding one) require a registration code.
But! I realised Plex could play the stream files without muxing, so I was able to compare— this Dolby Vision blu-ray remuxed into an mkv, played on Infuse on Apple TV, on a TV that doesn't support Dolby Vision looks crazy saturated and wrong.
Probably because the Apple TV doesn't support the profile that MakeMKV etc. are using to mux DV into an MKV file. Apple TV only supports Profile 5 from this - https://www.apple.com/ca/apple-tv-4k/specs/. MakeMKV is outputting Profile 7 from a UHD disc from my understanding.pistachiomatt wrote: ↑Tue Nov 03, 2020 5:15 amTried that. Earlier versions (even the immediate preceding one) require a registration code.
eblackadder
I'm trying to make dolby vision work with the modified exo player from yusesope. Now i want to put the playercorefactory.xml in Android/data/org.xbmc.kodi/files/.kodi/userdata/ but when i want to copy it with a file manager i see only Android/data/org.xbmc.kodi/files. The directory files is empty. Do i have to add the other 2 folders(.kodi/userdata/) manually or do i something wrong?
Thanks a lot!
P.S. I found it already. They were hidden folders. The mkv's made with MKV 1.15.3 works great with the modified exo player and this config file. Thanks a lot !
Thanks a lot!
Sgt Hartman
Hello Gents, download link for modified ExoPlayer for Kodi isn't working anymore, would it be possible to re-share it? Thanks!
eblackadder
I hope that it's allowed to reshare. All credits of this wonderful version goes to Yusesope. Here is a linkSgt Hartman wrote: ↑Thu Nov 12, 2020 6:45 amHello Gents, download link for modified ExoPlayer for Kodi isn't working anymore, would it be possible to re-share it? Thanks!
https://wetransfer.com/downloads/93b630 ... 206/137672
Enjoy it!
Sgt Hartman
Thanks buddy!eblackadder wrote: ↑Thu Nov 12, 2020 11:07 amI hope that it's allowed to reshare. All credits of this wonderful version goes to Yusesope. Here is a link
Enjoy it!
Do you think that someday plex will just be able to analyze a random mkv and play it with dv if it contains a dolby vision layer as a second video track ?
The most recent versions of Plex server can recognize Dolby Vision in a MKV rip of a UHD. It then depends on the capabilities of the various clients to be able to do something with it.
