HDR10+ Playback Issues - Please Help
PhreshPrince
#1 Post by PhreshPrince » Sun Oct 25, 2020 1:49 am
Morning Everybody.
I'm hoping someone can either help or shed some light on this issue that I've come across, as I've spent hours Googling and reading forums but to no luck. So I came across this forum and thought I've hit a dead end I need help.
I have a late 2019 Samsung Q60 TV that's compatible to play HDR10+.
Using an external HDD plugged into the TV's USB port, if I play a Remux HDR10+ mkv file the TV switches into HDR10+ mode and all good, however, if I play a rip of the Remux HDR10+ mkv file then the TV only plays in HDR10.
Can anyone help me with this?
Thanks in advance.
Below is the MediaInfo Text of the two files;
UHD HDR10+ REMUX
"@type": "General",
"UniqueID": "71222620358122848960790632184292361494",
"VideoCount": "1",
"AudioCount": "3",
"TextCount": "2",
"MenuCount": "1",
"FileExtension": "mkv",
"Format": "Matroska",
"Format_Version": "4",
"FileSize": "67778234145",
"Duration": "6962.336",
"OverallBitRate_Mode": "VBR",
"OverallBitRate": "77879877",
"FrameRate": "23.976",
"FrameCount": "166928",
"StreamSize": "35595449",
"IsStreamable": "Yes",
"Title": "UHD HDR10+ REMUX",
"Movie": "UHD HDR10+ REMUX",
"Encoded_Date": "UTC 2020-10-21 21:52:43",
"File_Modified_Date": "UTC 2020-10-21 22:22:00",
"File_Modified_Date_Local": "2020-10-22 09:22:00",
"Encoded_Application": "mkvmerge v51.0.0 ('I Wish') 64-bit",
"Encoded_Library": "libebml v1.4.0 + libmatroska v1.6.2",
"Cover": "Yes",
"extra": {
"Attachments": "small_cover_land.jpg / cover.jpg / cover_land.jpg / small_cover.jpg"
"@type": "Video",
"StreamOrder": "0",
"ID": "1",
"OriginalSourceMedium_ID": "4113",
"UniqueID": "1",
"Format": "HEVC",
"Format_Profile": "Main 10",
"Format_Level": "5.1",
"Format_Tier": "High",
"HDR_Format": "SMPTE ST 2094 App 4",
"HDR_Format_Version": "1",
"HDR_Format_Compatibility": "HDR10+ Profile B",
"CodecID": "V_MPEGH/ISO/HEVC",
"Duration": "6962.289000000",
"BitRate": "73199878",
"Width": "3840",
"Height": "2160",
"Sampled_Width": "3840",
"Sampled_Height": "2160",
"PixelAspectRatio": "1.000",
"DisplayAspectRatio": "1.778",
"FrameRate_Mode": "CFR",
"ColorSpace": "YUV",
"ChromaSubsampling": "4:2:0",
"ChromaSubsampling_Position": "Type 2",
"BitDepth": "10",
"Delay": "0.000",
"StreamSize": "63704838412",
"Language": "en",
"Default": "Yes",
"Forced": "No",
"colour_description_present": "Yes",
"colour_description_present_Source": "Stream",
"colour_range": "Limited",
"colour_range_Source": "Stream",
"colour_primaries": "BT.2020",
"colour_primaries_Source": "Stream",
"transfer_characteristics": "PQ",
"transfer_characteristics_Source": "Stream",
"matrix_coefficients": "BT.2020 non-constant",
"matrix_coefficients_Source": "Stream",
"MasteringDisplay_ColorPrimaries": "Display P3",
"MasteringDisplay_ColorPrimaries_Source": "Stream",
"MasteringDisplay_Luminance": "min: 0.0050 cd/m2, max: 4000 cd/m2",
"MasteringDisplay_Luminance_Source": "Stream",
"MaxCLL": "1000 cd/m2",
"MaxCLL_Source": "Stream",
"MaxFALL": "755 cd/m2",
"MaxFALL_Source": "Stream",
"extra": {
"OriginalSourceMedium": "Blu-ray"
UHD HDR10+ REMUX RIP
"@type": "General",
"UniqueID": "134412913919343410696152246985017671762",
"VideoCount": "1",
"AudioCount": "4",
"TextCount": "5",
"MenuCount": "1",
"FileSize": "28418147440",
"Duration": "7139.507",
"OverallBitRate": "31843260",
"FrameCount": "171172",
"Title": "UHD HDR10+ REMUX RIP",
"Movie": "UHD HDR10+ REMUX RIP",
"Encoded_Date": "UTC 2020-06-24 12:47:59",
"File_Modified_Date": "UTC 2020-10-16 04:25:08",
"File_Modified_Date_Local": "2020-10-16 15:25:08",
"Encoded_Application": "mkvmerge v33.1.0 ('Primrose') 64-bit",
"Encoded_Library": "libebml v1.3.7 + libmatroska v1.5.0"
"@type": "Video",
"StreamOrder": "0",
"ID": "1",
"UniqueID": "4682095224268487975",
"Format": "HEVC",
"Duration": "7139.299000000",
"BitRate": "27220301",
"Width": "3840",
"Height": "2160",
"BitDepth": "10",
"Delay": "0.000",
"StreamSize": "24291733829",
"Encoded_Library": "x265 - 3.3+33-04275ae58030:[Windows][MSVC 1900][64 bit] 10bit",
"Encoded_Library_Name": "x265",
"Encoded_Library_Version": "3.3+33-04275ae58030:[Windows][MSVC 1900][64 bit] 10bit",
"Encoded_Library_Settings": "cpuid=1111039 / frame-threads=6 / numa-pools=16,16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=171176 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=14.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,01) / cll=1000,168 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0",
"Default": "Yes",
"Forced": "No",
"MasteringDisplay_Luminance": "min: 0.0001 cd/m2, max: 1000 cd/m2",
"MaxFALL": "168 cd/m2",
Re: HDR10+ Playback Issues - Please Help
#2 Post by dcoke22 » Sun Oct 25, 2020 7:35 pm
I don't know exactly what is going on, but looking at the MediaInfo you posted, your rip is made with much older software.
your remux:
your rip:
