Mission Impossible 2
Giffdev
#1 Post by Giffdev » Wed Oct 14, 2020 10:50 pm
Having issues opening this disk. Has anyone successfully been able to back it up on UHD?
st4evr
Re: Mission Impossible 2
#2 Post by st4evr » Wed Oct 14, 2020 10:55 pm
Yes, people have backed this one up already.
Forum members would need more information from you to be able to better advise. Simply saying “it does not work” does not give the forum much to go on. Help us help you.
Are you receiving any specific error(s)?
Any error logs available? If so, can you please post them?
Any additional relevant information related to the problem you are seeing on your end may be useful for advise.
Giffdev
#3 Post by Giffdev » Wed Oct 14, 2020 10:57 pm
Same issue with MI3 :(
MKB20_v65_Mission-_Impossible_II_F1C7.tgz
(556.06 KiB) Downloaded 1258 times
MKB20_v61_Mission-_Impossible_III_F1C3.tgz
(509.39 KiB) Downloaded 1146 times
st4evr
#4 Post by st4evr » Wed Oct 14, 2020 11:02 pm
If it’s a missing key then posting the .tgz files in the forums does no one any good. These .tgz files differ from error log files in certain ways. This is because only Mike (owner/developer of MakeMKV) can do something with these files in order to add support for the discs.
I see you’ve previously submitted dumps correctly based on your post history. Do the same with these. The process has not changed.
Giffdev
#5 Post by Giffdev » Wed Oct 14, 2020 11:41 pm
Thanks, I wasn't sure if it was a key issue or disk issue, as the error just says "failed to open disk" (technically it says the volume key is unknown, so i'm guessing emailing the address is the right thing to do).
for the record, MI Ghost Protocol worked fine, but I just moved on to Rogue Nation and that also did not decrypt
Digital moe
#6 Post by Digital moe » Fri Oct 16, 2020 3:20 pm
I did all MI movies last week, the only one that gave me an issue was Fallout and I have two copies of that and both were unreadable. I managed to rip one of them by downgrading to 1.15.1.
Giffdev
#7 Post by Giffdev » Fri Oct 16, 2020 9:56 pm
As of this morning MI 2 and 3 are ripping while they weren't before, but I am still getting "unable to open disk" on MI: Rogue Nation
henkeli
#8 Post by henkeli » Sat Oct 17, 2020 10:38 pm
Hey did you submit the dump file for Rogue Nation?
I won't do it if it's already been sent...
st4evr
#9 Post by st4evr » Sun Oct 18, 2020 12:05 am
That’s not how this process works. AACS LA and studios can implement dozens and if they ever wish to hundreds of different encryption keys for any one particular release. There is hardly ever one single key for one single movie release. It wouldn’t be much of a protection process if it was that simple.
So, in short, the key for his disc may not necessarily be the same for yours. So you should always be submitting your dumps for your discs regardless without waiting for someone else to do it for you. Otherwise, you could be sitting there forever waiting for support for your discs.
osuplaya90
#10 Post by osuplaya90 » Mon Oct 19, 2020 2:25 pm
I'm having this same issue. Received my 6 disc collection of all of the MI's and Rogue Nation won't decrypt. Submitted my dump file this morning.
WAYFLIX
#11 Post by WAYFLIX » Thu Oct 22, 2020 5:25 pm
Yeah I can't rip that one either. I can't downgrade because I want to preserve the DV information.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00067.m2ts' at offset '30474104832'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '30474104832'
Failed to save title 0 to file D:/Rips/Mission- Impossible Fallout_t00.mkv
0 titles saved, 1 failed
Digital moe
#12 Post by Digital moe » Fri Oct 23, 2020 8:40 pm
You can downgrade rip the movie then run the mkv through 1.15.3 and you still preserve the DV info.
WAYFLIX
#13 Post by WAYFLIX » Sat Oct 24, 2020 3:15 pm
No luck with 1.15.1 either. Same errors. I ordered a second drive. I'll try with that when I receive it. I'll also see if I can get my hand on a second disc.
osuplaya90
#14 Post by osuplaya90 » Sat Oct 24, 2020 3:23 pm
I have 3 different drives I tried with. I dice.
WAYFLIX
#15 Post by WAYFLIX » Thu Oct 29, 2020 11:27 am
I finally managed to rip Fallout. The combination of cleaning, OSX, LG drive (mk1.0.5) and MakeMKV 1.15.1 worked! It took a very long time to rip. I made a back up copy and ran it through MakeMKV 1.15.3 to get the DV information back. Success!
