flashing
Re: flashing
Failure #4 usually occurs if you run the program in a virtual machine. You have to flash your drive in your native OS. If on a Mac please check the Mac section or under Linux check the Linux section.
yamahaman
Re: flashing
Post by yamahaman »
I am running it on windows 10 x64 not on virtual.machine.
Re: flashing
yamahaman wrote: Sat Oct 24, 2020 12:08 pm updating with that flasher gives updating failure #4
This is the problem you are flashing the wrong firmware if you followed my pined guide this would not be an issue flash WH16NS60 1.02mk like my guide says.
Wh16NS40 1.03 mk does not have the additional downgrade checks disabled so it will always fail.
Re: flashing
Billy,
I'm puzzled.... Where do you say that WH16NS60 1.02 has be be flashed first???
Yamahaman:Try this and if successful you can then flash your drive specific firmware if you want
yamahaman
Re: flashing
Post by yamahaman »
I do not have WH16NS60 I have WN16NS40 on firmware 1.4 its starting to get confusing now.
Re: flashing
Billy says that you have to cross-flash first before you can flash to your drive specific firmware. So try to flash WH16NS60 1.02 and then afterwards W16NS40 1.02 or 1.03 or 1.04. If you are using only Makemkv you can also stay on WH16NS60. If you want to use other progs as well like AnyDVD you need to flash it to WH16NS40 firmware.
yamahaman
Re: flashing
Post by yamahaman »
nothing appears to work none of the programmes will open without errors looks like it is down to net framework but I have tried uninstalling then reinstalling but has not fixed problem.
Re: flashing
Any chance to put your drive in another PC?
Re: flashing
Last theory. Any Antivirus software running could also interfere.
yamahaman
Re: flashing
Post by yamahaman »
The drive is used external not in pc connected by Unitek Y-1099 its a dell XPS 8930 pc so no room to install a drive within.
Re: flashing
That's your problem. Not all USB adapters allow flashing. If you have no other possibilty you need a different adapter. Need to say that you come up with that information very late. That would have been very obvious in the first place.
Re: flashing
yamahaman. I'm out now and will not support this thread any further. You provided too less information in the first place and only did by small slices. If you would have stated your configuration right from the beginning we would have saved a lot of posts etc. and poking here and there. The way you asked for help is frustrating for us who want to help. Too little information to drill down to the problem. You see - I'm also frustrated. There could have been a real shortcut if we would have known about how you use your drive.
yamahaman
Re: flashing
Post by yamahaman »
So sorry but thanks every one for your help.
Re: flashing
yamahaman wrote: Sat Oct 24, 2020 9:32 pm So sorry but thanks every one for your help.
The Unitek Y-1099 adapter is fine for flashing your drive. I use one myself!
You can use either the modified ASUS flasher or the SDFtool Flasher, however .net framework 4.7.2 is required. If you install the latest version you should be ok.
Once you have that sorted out, I suggest flashing your drive to WH16NS40 1.04 MK from the MK firmware pack. Once you have completed this initial flash, you can then flash the drive to whatever desktop firmware you please.
yamahaman
Re: flashing
Post by yamahaman »
Thank you so much for the confirmatiom
