Newbie: Successfully ripped, but how to start a movie?
mcascella
#1 Post by mcascella » Sat Oct 24, 2020 1:34 pm
Well, the software ripped the movie, with apparent success. How does one play the movie? There are a few folders and many files. Which file does one play?
-mark
Re: Newbie: Successfully ripped, but how to start a movie?
#2 Post by Woodstock » Sat Oct 24, 2020 2:11 pm
Ripped via which method, "Backup", or "Open->Save as MKV"?
If you used "Backup", your player needs to be "Bluray aware", in that it understands and can play unencrypted BD file structures.
If you used "Open->Save as MKV", your player needs to be able to handle MKV files, in which case you just have it open the main movie MKV file.
st4evr
#3 Post by st4evr » Sat Oct 24, 2020 2:18 pm
And for questions like this, this is where Google is your friend. As it will quickly provide starting points and in many cases decent detailed explanations/guides that may give you an idea of what to look for. As well as thousands of existing similar discussions on the matter. Examples:
https://www.google.com/search?q=mkv+pla ... e&ie=UTF-8
https://www.google.com/search?rlz=1C9BK ... s-wiz-serp
Christinaarnold
#4 Post by Christinaarnold » Tue Nov 03, 2020 7:37 am
thanks!
mcascella
#5 Post by mcascella » Sun Nov 29, 2020 7:41 pm
:D Thank you from the newbee.
