dmartinvera00
Doing the first post, will that be enough to have the best version? Or was there some advance in the entire discussion. I already tried with matrix and transformers, and everything ok with the tv
Do other DV movies play with DV?Tomas wrote: Fri Oct 23, 2020 4:17 pmYesBuzzie wrote: Fri Oct 23, 2020 3:17 pmDid you update the media server also to the latest version?? 1.20.xxxTomas wrote: Fri Oct 23, 2020 1:16 pm
Hello, I downloaded the version PLEX 8.8.0.21167, but when I release mkv, it doesn't start in Dolby Vision, but in HDR. Can you advise what it could be?
REMOVED earlier mediainfo
DaMacFunkin
Some people have said you need to force a re-scan of your metadata for all Dolby Files, as Plex has already stored them as HDR10 playback.
I tried it in the evening and some movies play Dolby Vision and some only play HDR. What can it be?DaMacFunkin wrote: Sat Oct 24, 2020 7:05 amSome people have said you need to force a re-scan of your metadata for all Dolby Files, as Plex has already stored them as HDR10 playback.
MasterDude
After Plex version 8.8.0.20999 most DV profile 6 movies play as HDR, but some still do play Dolby Vision. Apparently something changed. Re-scans etc dont help. If i go beyond this version it happens en when I go back DV activates normally again for all movies. So for now I stop updating the app. Using the latest server gives nog problems relating above isues.
Bravo!ragico wrote: Fri Oct 23, 2020 3:02 pm After many trials and hours I am capable to make the mkv with audio and subs chosen by me.
From scratch to the final mkv it takes less than 1 hour. Excellent, Master Yusesope, your Gamma version of the Tool works very well.
I knew you could do it!
Come on, honestly, it's not that complicated.
I am happy to know that the GAMMA version is working properly. In the future I will try to make everything automated.
An hour seems too much! When you run the second command, FFmpeg should show you the speed with which it processes the data I send to it: I oscillate between 6x (mechanical HDD) and 15x (NVMe). It means that a 2hr movie is processed in 20min (120/6) or 8min (120/15). My current CPU is an i5-7500.
I believe that too.HongyuS wrote: Fri Oct 23, 2020 1:38 pm It plays in HDR10 mode, and works fine. Good job. Guess Apple does not support profile 8.1 after all....
I'm sorry but not having a Mac I can't continue to support this platform.HongyuS wrote: Fri Oct 23, 2020 1:38 pm Please share a Mac version of your tool, or just the source code, so I can test it on my machine!
You have several options though. The easiest and fastest (15 minutes and everything is ready) is to use VirtualBox (free) or Parallels (trial) with the image of a virtual machine (ready to be started) with Windows or Linux OS.
Keep in mind that my BETA version returns a raw HEVC file while the GAMMA a full MKV file.
The MP4 I posted to you was obtained by modifying the source code of Dolby's mp4muxer (and using a raw HEVC stream obtained with BETA)).
This file is important for anyone who wants to encode (x265) their files with DoVi.HongyuS wrote: Fri Oct 23, 2020 1:38 pm Another interesting phenomenon is that your Terminator sample can be edited with Apple's Photos app, as well as latest version of iMovie on iOS. So I tried to re-encode the video with iMovie, and I got THIS file (DoVi profile 8.4 compatible with HLG, 30FPS, 1080p).
This proves that the latest version of your tool works perfectly with Apple devices! The RPU data is 100% compatible with Apple's Dolby certificated encoder!!!
This is a correct encoding: not only the Base Layer has been changed but all the RPUs have been recalibrated.
The encoding was done through a certified encoder!
It is wrong to encode the Base Layer and "re-paste" the original RPUs through my tool!
I also took a closer look at your video (recorded with iPhone 12) and the file obtained with iMovie.
The coding scheme is virtually identical.
I then extracted all the RPUs present in your video, in my sample (Terminator) and those in the Terminator encoded with iMovie (zip HERE).
Open the CHECKSUM.md5 file (found in each folder) with a text editor. Inside are the md5 hashes of each individual RPU.
In files produced with iOS, there are many identical MD5s and therefore many identical RPUs.
The strength of Dolby Vision should be precisely that of dynamically varying the characteristics of the image (but I don't think it can happen if there are many identical RPUs).
Then I looked at some (not all) RPUs (the ones with different md5) and the only parameters that vary are max_PQ* and avg_PQ*.
The variations are also minimal.
It seems to me a fairly minimal implementation of Dolby Vision technology.
The UHD-BD RPUs are all different from each other and the parameters that change are multiple, frame after frame (see the CHECKSUM of my sample)
As I said, very often it is not enough to change the header of a box for the file to be played. QuickTime is perhaps smarter and can retrieve the information needed to initialize the decoder. The iPad player may not be capable of it!HongyuS wrote: Fri Oct 23, 2020 1:38 pm I also tried to change "dvh1" to "hvc1" of the MBox profile 8.1 sample. The resulting file can be played in QuickTime (contrast still wrong), but cannot be played on my iPad. This is what I could't understand. It should be at least backward compatible with HDR10, like your Terminator sample.
max_PQ (maximum luminance value of current scene in 12-bit PQ encoding)
avg_PQ (midpoint luminance value of current scene in 12-bit PQ encoding)
I am still refining the whole process, You are right, it takes less time. On my pc between 20 and 30 minutes, depends also if the original movie has got HDR10+ and I want to remove it for compatibility problem with Firestick. In that case the process takes a little more time.yusesope wrote: Sat Oct 24, 2020 10:30 am
My processor is an I3 6100.
Can you share your source code with me? I'm happy to help you compile a Mac version.yusesope wrote: Sat Oct 24, 2020 10:30 am I'm sorry but not having a Mac I can't continue to support this platform.
The performance of VM is very poor on my computer, so I have to reboot into Windows every time.
Can you also share the modified source code of Dolby's mp4muxer? I cannot reproduce a working mp4 file. Please share the source code so I can know what you've changed.yusesope wrote: Sat Oct 24, 2020 10:30 am The MP4 I posted to you was obtained by modifying the source code of Dolby's mp4muxer (and using a raw HEVC stream obtained with BETA)).
If you need a hand, as soon as I can, I'll answer you.ragico wrote: Sat Oct 24, 2020 12:20 pm I am still refining the whole process, You are right, it takes less time. On my pc between 20 and 30 minutes....
After the October 2 update on BETA, there is no longer any source code for Mac.HongyuS wrote: Sun Oct 25, 2020 7:23 am Can you share your source code with me? I'm happy to help you compile a Mac version.
Then take the GAMMA version for example: for now it only works on Windows ... when I have time I will extend support to Linux as well.
Windows and Linux are the only platforms I can experiment with.
I'm sorry for the inconvenience.HongyuS wrote: Sun Oct 25, 2020 7:23 am The performance of VM is very poor on my computer, so I have to reboot into Windows every time.
On my 400€ machine the VMs have the same performance as the primary OS: I can hardly believe that your Mac (iMac 2020 ??? ... MacBook Pro >= 2018 ???) struggles!
I simply forced the value of "sample_entry_name_flag" (setting it to 1) through the "p_usr_cfg_es" pointer.yusesope wrote: Sat Oct 24, 2020 10:30 am Can you also share the modified source code of Dolby's mp4muxer? I cannot reproduce a working mp4 file. Please share the source code so I can know what you've changed.
Add the row
p_usr_cfg_es->sample_entry_name_flag = 1;This type of solution is fine for my experiments.
For something more dynamic, you'd better add a switch (something like --force-hvc1 1) in the frontend (mp4_muxer_app.c).
I have not checked but I think it is possible by modifying the ema_mp4_mux_set_input function in such a way that it accepts the value of the new switch and with the latter set usr_cfg_es->sample_entry_name_flag
FIRST - Very fine work Yusesope.
Ran GAMMA on 1917...
With no additional switches and Profile 8:
SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
With -skip_hdr10plus:
SMPTE ST 2086, HDR10 compatible
Speed was 10.5x (AMD Ryzen 9 3900x), so 11minutes20seconds. No idea how to determine whether FEL or MEL (no MakeMKV...). And BDInfo doesn't provide this info either. 3rd party app?
Most importantly - how do I get DolbyVision?
The input file must be a dual track dual layer profile 7 file (e.g. an m2ts file inside the decrypted folder of a UHD-BD)kws53 wrote: Sun Oct 25, 2020 4:20 pm FIRST - Very fine work Yusesope.
The mkv file obtained after the program has finished is not recognized as a file with DoVi!
Needs to be patched!
Did you use the mkv patcher as indicated in the third step (HERE)?
I don't understand what you mean when you talk about FEL or MEL: if in the first command line you used "-mode 2" then, when the patcher asks you, type 8 otherwise your file (FEL or MEL, it doesn't matter) will be a profile 7 and you will have to type 7 when prompted by the patcher!
baohen1510
What wrong ? Pls help me
F:\DOLBYVISION\MAKEMKVDOLBYVISION>python-3.7.6.amd64\python.exe src\MKV_patcher.py
Please, drag and drop here the MKV file and press ENTER:
G:\DV.mkv
Please choose the profile to assign (7 or:
8
Traceback (most recent call last):
File "F:\DOLBYVISION\MAKEMKVDOLBYVISION\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 833, in _initialise
init_without_length_or_offset[k](self, v)
KeyError: 'uint'
During handling of the above exception, another exception occurred:
File "src\MKV_patcher.py", line 243, in <module>
patched_data = mkv_patcher.inject_dolby_vision(dolby_vision_data)
File "src\MKV_patcher.py", line 217, in inject_dolby_vision
self.init_elements()
File "src\MKV_patcher.py", line 159, in init_elements
el_property["size"] = self.read_variable_size_int()
File "src\MKV_patcher.py", line 138, in read_variable_size_int
parsedValue = BitArray(uint=(self.mkv_data[pos:pos + 8] & (~self.get_len_mark(length))).uint,length=length)
File "src\MKV_patcher.py", line 127, in get_len_mark
return BitArray(uint=1 << (8 - int(length /),length=8)
File "F:\DOLBYVISION\MAKEMKVDOLBYVISION\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 3059, in __new__
y = Bits.__new__(BitArray, auto, length, offset, **kwargs)
File "F:\DOLBYVISION\MAKEMKVDOLBYVISION\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 812, in __new__
x._initialise(auto, length, offset, **kwargs)
File "F:\DOLBYVISION\MAKEMKVDOLBYVISION\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 838, in _initialise
init_with_length_only[k](self, v, length)
File "F:\DOLBYVISION\MAKEMKVDOLBYVISION\python-3.7.6.amd64\lib\site-packages\bitstring.py", line 1388, in _setuint
raise CreationError(msg, uint, length, (1 << length) - 1)
bitstring.CreationError: 256 is too large an unsigned integer for a bitstring of length 8. The allowed range is [0, 255].
F:\DOLBYVISION\MAKEMKVDOLBYVISION>pause
So I got curious about the iPhone 12 pro doblyvision which I haven’t gotten yet,
But I do have the pro11 MAX, so I uploaded the captured I phone 12 clip dovi on the pro max 11 & ran I movie on the max 11pro
And I movie on the 11 produce a doblyvision
File slightly different from the original.
Produced an profile 8 id36 doblyvision hlg.
So I phone 11pro can encode dovi/rpu/bl
Which played in doblyvision on my dv devices.
I’ll post a media info later today.
My second test is to use uhbd dual to single layer mp4 in I move to encode in doblyvision
My question is does any further minuplation needed to uhd mp4s so I movie can accept them.
I’m also going to try on my MacBook Pro.
- FA0D3FB3-6C03-4DE6-B7E4-38AE4323DCC9.jpeg (1.24 MiB) Viewed 50643 times
- D6767639-1DEB-43D3-979E-442BB0E5FB2C.jpeg (832.31 KiB) Viewed 50760 times
- 11B5908D-6EE0-454C-BDC4-43D945514154.png (2.87 MiB) Viewed 50761 times
Last edited by Manixx2020beyound on Mon Oct 26, 2020 8:03 pm, edited 1 time in total.
It is a dual track, dual layer m2ts file from the original - see Image 1. How can I tell whether it is a profile 7 file?The input file must be a dual track dual layer profile 7 file (e.g. an m2ts file inside the decrypted folder of a UHD-BD)
Specifically: \BDMV\STREAM\00294.m2ts from the 1917 ISO [US]
Indeed - see Image 2.The mkv file obtained after the program has finished is not recognized as a file with DoVi!
I didn't use any switches other than the "-skip_hdr10plus" for my comparison.I don't understand what you mean when you talk about FEL or MEL: if in the first command line you used "-mode 2" then, when the patcher asks you, type 8 otherwise your file (FEL or MEL, it doesn't matter) will be a profile 7 and you will have to type 7 when prompted by the patcher!
- EAC3TO Output
- Dual Layer.png (10.85 KiB) Viewed 50738 times
- Patch Verification
- PatchScreen.png (14.88 KiB) Viewed 50738 times
