Currently, if I'm trying to edit the chapter names, there is a large amount of clicking around (have to select a new chapter with the mouse and then go back and select the text field.
In reality, I think a simpler UX that would work for most people is if you hit enter while editing the name of the chapter, it goes to the next chapter and lets you continue typing.
MakeMKV needs a better chapter editing UX
Re: MakeMKV needs a better chapter editing UX
I didn't know there was a chapter name editor function.
However, now that I do, it operates just like the other naming functions in MakeMKV... using the down or up arrow, while the cursor is in the name field, moves to the next chapter down or up from the current one.
It doesn't highlight the text for replacement, though. So, if I were doing this, I'd put the "common" text into the system clipboard, then change the first chapter, hit down arrow, Ctrl-A, Ctrl-V, type the text that is different, down arrow, etc.
Things like this are a pain when trying to do them with a mouse.
thetoad
ah, didnt know about the arrow keys, but yes, down, ctrl-a, type is much easier. still think "enter" should act as down and ctrl-a together, but this is doable, to avoid mousing around
