MUX into MKV, transcoding causes audio sync issue
dahli
#1 Post by dahli » Tue Dec 21, 2010 11:51 pm
I've been trying to figure this one out but have had no luck. Maybe somebody here can shed some light on this topic.
I've been creating a digital media library of DVD and BD and my choice is to keep original streams where possible. Due to a variety of playback devices the format I'm going to is H.264/AC3 or AAC-LC 6ch. To hit this format it sometimes requires muxing into MKV and then I'll transcode later.
typical sources
DVD: MPEG2 video with DTS or AC3
BD: MPEG2 or VC1 or H.264 with DTS or AC3 or trueHD.
The movie I've been playing with recently is Adaptation DVD, this is the sequence right now.
Source: DVD media (copied to HDD with AnyDVDHD)
MakeMKV: create MKV file with one MPEG2 stream and DTS audio track (no subtitles) audio sync is fine here
Ripbot or handbrake: Transcode to H.264 with AC3 or H.264 with AAC-LC 6ch. audio is way off here
I've tried on systems with CCCP and with FFMPEG plus haali splitter. (Two separate systems)
thanks for any ideas
setarip_old
Re: MUX into MKV, transcoding causes audio sync issue
#2 Post by setarip_old » Wed Dec 22, 2010 8:01 pm
Hi!
Try using multiAVCHD instead...
dahli
#3 Post by dahli » Tue Dec 28, 2010 3:41 pm
I've also tried with windows movie maker (and newer live version). I'll give the other program a try but I don't think that it is an answer. It seems like this is a codec issue or issue with the file produced by MakeMKV.
Has anybody else tried the MKV validation tool? I tried it on the MakeMKV output and it has many errors. DVDFab outputs MKV files that can be transcoded into other formats but that is a very expensive tool.
marshalleq
#4 Post by marshalleq » Sat Jul 02, 2011 4:21 am
I've been trying too with the same problem. I'm using h264enc to re-encode to a smaller format. It works fine with all the files I've tried, but not a blu-ray using makemkv. It does work from a makemkv dvd extract, just not a blu ray one.
The following post seems to indicate for linux at least ffms2 is required to fix audio sync issues....
http://www.makemkv.com/forum2/viewtopic.php?f=6&t=1313
Romansh
#5 Post by Romansh » Fri Jul 08, 2011 10:31 pm
dahli wrote:Ripbot or handbrake: Transcode to H.264 with AC3 or H.264 with AAC-LC 6ch. audio is way off here
The HandBrake Activity Log will contain a lot of information about what's going on, some of which may be useful in figuring out what's causing the desync.
