ragico
Post by ragico » Thu Oct 22, 2020 10:55 pm
yusesope wrote: Thu Oct 22, 2020 5:31 pm
ragico wrote: Thu Oct 22, 2020 5:10 pm
python-3.7.6.amd64\python.exe src\app.py -mux -exp \path\to\your\original\file.m2ts
can I write down D:\000125.m2ts? Is this example correct?
If the file is located in D:\000125.m2ts then you must write D:\000125.m2ts instead of \path\to\your\original\file.m2ts.
Are you sure the correct address is not D:\BDMV\STREAM\000125.m2ts?
A little trick: while copying the command line, stop at -exp, leave a space, and then drag and drop the m2ts file into the Command Prompt window you are using. Windows will automatically fill in the correct address of your file.
ragico wrote: Thu Oct 22, 2020 5:10 pm And Then:
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i \path\to\your\original\file.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Movie Title_________________________________________________________________________" \path\to\your\output\file.mkv
Same as above? And I need "" for Movie Title?
The same applies to all "\path\to\your\......" strings marked in blue (the above trick works the same way).
And yes, you need the quotes ("") when setting the title metadata
These are the commands that I applied.
1) python-3.7.6.amd64\python.exe src\app.py -mode 2 -mux -exp I:\BDMV\STREAM\00018.m2ts
2) src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i I:\BDMV\STREAM\00018.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title=
"Transformers_____________________________________"
D:\Transformers.mkv
And this is what I get:
Where is my fault?
HongyuS
Post by HongyuS » Thu Oct 22, 2020 11:55 pm
yusesope wrote: Thu Oct 22, 2020 4:59 pm I took a look at the iPhone 12 video: the RPUs are structurally identical to the ones my algorithm (-mode 2) produces when choosing UHD-BD -> profile 8.1 conversion.
It doesn't mean they're perfect but I'm happy with the insight I got :mrgreen: !
I just tried -mode 2 on my iPad Pro (latest iOS 14 Beta), contrast ratio looks wrong. But can confirm it was a bug of Apple, cuz profile 8.1 sample from MBox have the same issue. (Due to copyright limitations, I cannot share the samples with anyone, but you can download them from MysteryBox's website)
However, sample made by yusesope's "-mode 2" triggers crash on macOS Big Sur, while encoding sample from MBox does not. So there are still room for improvements.
yusesope wrote: Thu Oct 22, 2020 4:59 pm OT:
Do you guys use a VPN to be able to write here or upload files to Gdrive?
Yes. VPN is essential to access "real" internet in China :D
HongyuS
Post by HongyuS » Fri Oct 23, 2020 2:14 am
I’m also wondering that - is it possible to extract the RPU data which can be used by the x265 encoder?
Since all streaming services are using profile 5, it would be much more convenient if we can re-encode the video to profile 5. Looks like profile 5 have the best cross-platform capability by now.
dapope
Post by dapope » Fri Oct 23, 2020 2:35 am
EDIT: Seems to be some sort of glitch with Tsmuxer. Using Tsmuxer to remux the file as .m2ts and not .ts works and is recognised by the LG.
I'm having an audio problem in my quest for Dolby Vision on my LG CX internal player. I use headphones so I've been converting the DTS-HD MA track to a stereo WAV. Put simply I demux using Tsmuxer, merge HEVC files using 8.1.bat, convert the audio using eac3to and then remux using Tsmuxer. I have the Back to the Future 4K set. The first movie worked fine using this process. However movies 2 and 3 fail to recognise the LPCM audio track. Mediainfo displays that the track is there and all the attributes are identical to the first movie which works perfectly. I really have no idea what could be going wrong or how to fix it!
badrobot
Post by badrobot » Fri Oct 23, 2020 2:52 am
HongyuS wrote: Thu Oct 22, 2020 11:55 pm
I have tried MBOX demo video files on my iPad Pro, it seems that P5 can be identified as DoVi by infuse 6, but P8.1 can not.
Result:P5 play as DoVi, P8.1 play as HDR, I have uploaded these screenshots.
https://screenshotcomparison.com/comparison/7316
I am not a native English speaker.
Sorry for my bad English.
HongyuS
Post by HongyuS » Fri Oct 23, 2020 3:40 am
badrobot wrote: Fri Oct 23, 2020 2:52 am I have tried MBOX demo video files on my iPad Pro, it seems that P5 can be identified as DoVi by infuse 6, but P8.1 can not.
I forgot to mention one very important info: Apple require the video track fourcc ID to be “dvh1” for Dolby Vision. So you need to change it manually using a Hex editor. (More info: the sample I recommended to you is “dvhe”, which cannot be played by QuickTime/Apple TV app)
Furthermore, Infuse only supports profile 5. If you want to test profile 8.x, you need to copy the the m4v file to the “Files” app, and preview with it. (And you must use iPadOS 14.1 or 14.2 beta 4, or later versions, in order to support profile 8.x)
yusesope
Post by yusesope » Fri Oct 23, 2020 10:45 am
ragico wrote: Thu Oct 22, 2020 10:55 pm 2) src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i I:\BDMV\STREAM\00018.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title=
D:\Transformers.mkv
The first command line is fine, in the second there are two invisible mistakes!
You entered two "newline" characters (sei andato a capo due volte): one immediately after title= and the other after the underscores and the quotation mark (before the address of the output file).
Look HERE.
The command line is a single long line and the only spacing character allowed is the space.
You can help yourself with THIS online tool for removing line breaks.
the second command line should be (look at the parts in red):
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i I:\BDMV\STREAM\00018.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Transformers_____________________________________" D:\Transformers.mkv
No space between title= and the next quotation mark.
A simple space between the last quotation mark and the address of the output file.
HongyuS wrote: Thu Oct 22, 2020 11:55 pm However, sample made by yusesope's "-mode 2" triggers crash on macOS Big Sur, while encoding sample from MBox does not. So there are still room for improvements.
The mysterybox sample (the one with profile 8.1) is FHD (1920 × 1080): did we download the same file?
Mine are UHD (3840 x 2160): it would be an unequal comparison :mrgreen: !
Would you tell me exactly which sample produced by my tool you tried? It is important to know because "-mode 2" has undergone some changes over time!
I leave you a SAMPLE (video only - profile 8.1 derived from a FEL) obtained with the latest version of my tool and adapted to meet what I believe are the needs of macOS Big Sur. I don't know if it will be played but it doesn't hurt to try!
HongyuS wrote: Fri Oct 23, 2020 3:40 am I forgot to mention one very important info: Apple require the video track fourcc ID to be “dvh1” for Dolby Vision. So you need to change it manually using a Hex editor. (More info: the sample I recommended to you is “dvhe”, which cannot be played by QuickTime/Apple TV app)
The correct codec ID (for profile 8.1) should be "hvc1" in place of "hev1". But be careful, these boxes are not random: they indicate to the decoder how the information for the initialization of the latter is stored within the file. Changing the header with a hex editor isn't always enough!
Tomas
Post by Tomas » Fri Oct 23, 2020 1:16 pm
Buzzie wrote: Thu Oct 22, 2020 7:41 am
shawnc22 wrote: Wed Oct 21, 2020 10:14 pm
Buzzie wrote: Wed Oct 21, 2020 8:01 pm
Thanks for the reply.
I checked the versions
Plex Player is latest version : 8.7.2.20952
Plex server is also latest version : 1.20.3.3437
After re-anilysing the file it showed the DoVi data. But playing the file was still in HDR :(
You need the latest 8.8 version of plex. If you weren’t on the beta, i think the public releases just came out today.
Thanks....gonna download that one tonight and see if it works.
EDIT: Update Plex app to 8.8 and worked indeed. Thanks!!
Hello, I downloaded the version PLEX 8.8.0.21167, but when I release mkv, it doesn't start in Dolby Vision, but in HDR. Can you advise what it could be?
Media info:
Video
ID in the original source medium: 4113 (0x1011)
Format: HEVC
Format / Info: High Efficiency Video Coding
Profile format: Main 10 @ L5.1 @ High
HDR format: Dolby Vision, Version 1.0, dvhe.07.06, BL + EL + RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10 + Profile B compatible
Codec ID: V_MPEGH / ISO / HEVC
Duration: 1 h 56 min
Bit rate: 78.4 Mbps
Width: 3,840 pixels
Height: 2,160 pixels
Aspect ratio: 16: 9
Frame rate mode: Constant
Frame rate: 23,976 (24000/1001) FPS
Color space: YUV
Chroma subsampling: 4: 2: 0 (Type 2)
Bit depth: 10 bits
Bits / (Pixel * Frame): 0.394
Stream size: 63.6 GiB (94%)
Language: English
Default: No.
Forced: No.
Color range: Limited
Color primaries: BT.2020
Transfer characteristics: PQ
Matrix coefficients: BT.2020 non-constant
Mastering display color primaries: Display P3
Mastering display luminance: min: 0.0050 cd / m2, max: 4000 cd / m2
Maximum Content Light Level: 1000 cd / m2
Maximum Frame-Average Light Level: 755 cd / m2
Original source medium: Blu-ray
HongyuS
Post by HongyuS » Fri Oct 23, 2020 1:38 pm
yusesope wrote: Fri Oct 23, 2020 10:45 am The mysterybox sample (the one with profile 8.1) is FHD (1920 × 1080): did we download the same file?
Tried your new sample, but it does not trigger DoVi on macOS Big Sur.
It plays in HDR10 mode, and works fine. Good job. Guess Apple does not support profile 8.1 after all (but still don't know why QuickTime can play the incorrect profile 8.1 files).
Another interesting phenomenon is that your Terminator sample can be edited with Apple's Photos app, as well as latest version of iMovie on iOS. So I tried to re-encode the video with iMovie, and I got THIS file (DoVi profile 8.4 compatible with HLG, 30FPS, 1080p).
This proves that the latest version of your tool works perfectly with Apple devices! The RPU data is 100% compatible with Apple's Dolby certificated encoder!!!
Please share a Mac version of your tool, or just the source code, so I can test it on my machine!
yusesope wrote: Fri Oct 23, 2020 10:45 am The correct codec ID (for profile 8.1) should be "hvc1" in place of "hev1". But be careful, these boxes are not random: they indicate to the decoder how the information for the initialization of the latter is stored within the file. Changing the header with a hex editor isn't always enough!
Thanks for your reminding! You are right. I also double checked the iPhone 12 Pro sample, can confirm that profile 8 does not use "dv**" FourCC.
I also tried to change "dvh1" to "hvc1" of the MBox profile 8.1 sample. The resulting file can be played in QuickTime (contrast still wrong), but cannot be played on my iPad. This is what I could't understand. It should be at least backward compatible with HDR10, like your Terminator sample.
However, change FourCC in profile 5 file ("dvhe" -> "dvh1") works (for both HD and UHD samples)!
ragico
Post by ragico » Fri Oct 23, 2020 3:02 pm
D:\Transformers.mkv
Look HERE.
Thanks Yusesope again. Followed your advices and made an entire movie in prof 8.1 which plays DV in Firestick.
My remaining problem is how to choose the italian audio track from the m2ts. I know for you would be easy but for me is impossible to do.
Anyway you are simply an extraordinary man.
EDIT:
After many trials and hours I am capable to make the mkv with audio and subs chosen by me.
From scratch to the final mkv it takes less than 1 hour. Excellent, Master Yusesope, your Gamma version of the Tool works very well.
Buzzie
Post by Buzzie » Fri Oct 23, 2020 3:17 pm
Tomas wrote: Fri Oct 23, 2020 1:16 pm
Media info:
Video
Format: HEVC
Bit rate: 78.4 Mbps
Width: 3,840 pixels
Aspect ratio: 16: 9
Color space: YUV
Bit depth: 10 bits
Language: English
Default: No.
Forced: No.
Did you update the media server also to the latest version?? 1.20.xxx
Tomas
Post by Tomas » Fri Oct 23, 2020 4:17 pm
Buzzie wrote: Fri Oct 23, 2020 3:17 pm
Media info:
Video
Format: HEVC
Bit rate: 78.4 Mbps
Width: 3,840 pixels
Aspect ratio: 16: 9
Color space: YUV
Bit depth: 10 bits
Language: English
Default: No.
Forced: No.
Yes
dmartinvera00
Post by dmartinvera00 » Fri Oct 23, 2020 5:05 pm
Doing the first post, will that be enough to have the best version? Or was there some advance in the entire discussion. I already tried with matrix and transformers, and everything ok with the tv
Buzzie
Post by Buzzie » Fri Oct 23, 2020 7:13 pm
Tomas wrote: Fri Oct 23, 2020 4:17 pm
REMOVED earlier mediainfo
Yes
Do other DV movies play with DV?
Tomas
Post by Tomas » Fri Oct 23, 2020 8:17 pm
Buzzie wrote: Fri Oct 23, 2020 7:13 pm
Yes
Yes, the Dolby Vision movie works when I go over the modified Kodi.
