Dolby Vision and 1.15.1
Larrikin
Re: Dolby Vision and 1.15.1
Post by Larrikin » Fri Oct 16, 2020 3:14 am
OK then. So this goes back to Mike in that - can you please support as an input for the audio conversion DTS:X? I have an AC3 profile which works with all other variants of DTS other than DTS:X.
djbuddha
Post by djbuddha » Fri Oct 16, 2020 9:17 pm
Larrikin wrote: Tue Oct 13, 2020 2:36 am
MartyMcNuts wrote: Tue Oct 13, 2020 2:30 am Now open mkvtoolnix, add the mkv you created with MakeMKV, deselect the DTS-HD audio track, add the audio.ac3 file and mux to a new mkv file. This file should retain the DV (as you are using the MakeMKV generated mkv file) and now have only an ac3 audio track.
This is the bit where I'm going to get stuck. Everything else above that is straight forward (thanks to you). I only have macOS running in my environment and I don't think mkvtoolnix supports macOS. Also, installing mkvtoolnix looked like a nightmare with all these other things you have to install along with it. Anyhow, a mute point because I don't run Linux.
I have MKVToolnix on my Mac, works fine
Larrikin
Post by Larrikin » Fri Oct 16, 2020 9:21 pm
djbuddha wrote: Fri Oct 16, 2020 9:17 pm
Yes, I have since worked that out and have used it. However, what would be more ideal is that the AC3 profile in MakeMKV supports the conversion of DTS:X. It converts all other variants of DTS, just not DTS:X. Avoids then having to use ffmpeg to extract audio, and remux it with MKVToolnix. A massive time saving. Just hope Mike adds support for DTS:X.
Alldu
Post by Alldu » Fri Oct 16, 2020 11:16 pm
Ok guys, so does anyone who uses Sony x700 to play Dobly VIsion m2ts files (created by nightly tsMuxer), run in the following problem: if a movie is long - over two hours (like Schindler's List or Braveheart), the resulting m2ts file has limited options. And by that I mean - you can play it and you can pause it on Sony x700 just fine, but you can't fast forward it or rewind. Like, when you press the button it gives the "this function is not available" message. Which is not really convinient if you don't watch the movie in one go, or want to check some scenes. So what could that be? The weird limitation of time in a m2ts container? Or limitation of file size? Anybody know?
gabi.gegea@gmail.com
Post by gabi.gegea@gmail.com » Tue Oct 20, 2020 1:35 pm
Anyone managed to find ExoPlayer v2.12.0 (2020-09-11) the .apk file?
Post by shawnc22 » Thu Oct 22, 2020 2:47 am
gabi.gegea@gmail.com wrote: Tue Oct 20, 2020 1:35 pm Anyone managed to find ExoPlayer v2.12.0 (2020-09-11) the .apk file?
If you are referring to the latest release build of exoplayer on github, then you are not going to find one. The project on github is an API used by other applications. The only apk that you can build out of it is a demo that can be used to the view the supplied demo files. If you have the knowhow, you can modify it to read custom files (like yusecope has done with his modified version) and then build the demo apk out of that.
Post by gabi.gegea@gmail.com » Thu Oct 22, 2020 4:00 pm
shawnc22 wrote: Thu Oct 22, 2020 2:47 am
Thank you for your reply!
chrisandy
Post by chrisandy » Sun Oct 25, 2020 4:53 pm
I'm sorry for drudging this up again but I am drawing a complete mental blank.
Should this be triggering DV on a Shield Pro?
Screenshot 2020-10-25 095249.png (71.37 KiB) Viewed 48968 times
Dinst
Post by Dinst » Sun Oct 25, 2020 5:59 pm
chrisandy wrote: Sun Oct 25, 2020 4:53 pm I'm sorry for drudging this up again but I am drawing a complete mental blank.
No, it looks like a dual layer remux but it won't work on anything as the EL doesn't have Dolby Vision.
chrisandy
Post by chrisandy » Sun Oct 25, 2020 6:00 pm
Dinst wrote: Sun Oct 25, 2020 5:59 pm
That's what I thought - thanks for confirming. So theoretically would work on HDR10+ but not DV?
Larrikin
Post by Larrikin » Mon Oct 26, 2020 2:03 am
I have just purchased the UHD 4K of Terminator Dark Fate which supports Dolby Vision and indeed works on my UHD Panasonic Bluray player. However, when using MakeMKV to backup my disc, it refuses to copy across Dolby Vision. Plex will only ever play it in HDR.
Is there something particular with this movie / disc?
Post by shawnc22 » Mon Oct 26, 2020 5:59 am
Larrikin wrote: Mon Oct 26, 2020 2:03 am I have just purchased the UHD 4K of Terminator Dark Fate which supports Dolby Vision and indeed works on my UHD Panasonic Bluray player. However, when using MakeMKV to backup my disc, it refuses to copy across Dolby Vision. Plex will only ever play it in HDR.
No, there shouldn't be. You have to be a bit more specific than just "refuses to copy across Dolby Vision". Does makemkv not show BL+FEL+RPU when opening the disk? Does the new mediainfo not detect dolby vision?
Larrikin
Post by Larrikin » Mon Oct 26, 2020 6:01 am
shawnc22 wrote: Mon Oct 26, 2020 5:59 am Does makemkv not show BL+FEL+RPU when opening the disk? Does the new mediainfo not detect dolby vision?
No and no. And to doubly test it, I downloaded a full complete UHD copy and tried it with MKV and same result. I also tried on multiple computers all with the latest (registered) version of MakeMKV.
Sparky101
Post by Sparky101 » Mon Oct 26, 2020 12:42 pm
Larrikin wrote: Mon Oct 26, 2020 6:01 am
What version of MakeMKV are you running?
Post by shawnc22 » Mon Oct 26, 2020 3:44 pm
Not sure what you're doing wrong, but my copy is showing up as BL+FEL+RPU just fine. Are you sure you're opening the title that's labeled as "Terminator: Dark Fate - 20 chapter(s), 58.3 GB". Otherwise, double check the version of your makemkv.
