lexyz
Post by lexyz »
Buzzie wrote: Wed Oct 21, 2020 7:49 am Ok Guys,
I have another question.
I have the full UHD rips of the BTTF Trilogy
Any idea why i dont see 2 video?
normally there are 2 video right?
Is it a good rip/remux?
I did not use any other tools.
Check Plex player and Plex Server versions.
Does Plex Server detect DoVi data? Check file info in Plex server.
mfraz74
Post by mfraz74 »
jlpsvk wrote: Tue Oct 20, 2020 11:01 am
ray_007 wrote: Tue Oct 20, 2020 8:33 am
jlpsvk wrote: Tue Oct 20, 2020 6:18 am
65kbps for DV EL LAYER is NOT FEL. :)
I think i will go with what the software is telling me, since its been made by people who know what they are doing and i trust their judgment. If anything changes in the future I might decided to re-rip it but for now I am happy with the results :)
I relly don't know, what you are talking about... info from MakeMKV on Birds of Prey
Track information
Type: Video
Codec: MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+MEL+RPU)
Resolution: 3840x2160
Aspect ratio: 16:9
Frame rate: 23.976 (24000/1001)
and info from DVDfab 12.0.0.3
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       59863 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10+ v1 Profile B / BT.2020
* MPEG-H HEVC Video     65 kbps (0.11%)     1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision MEL / BT.2020
mediainfo shows:
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
jlpsvk
Post by jlpsvk »
mfraz74 wrote: Wed Oct 21, 2020 6:02 pm mediainfo shows:
and??? mediainfo is not differencing between MEL and FEL... shows just EL
Buzzie
Post by Buzzie »
lexyz wrote: Wed Oct 21, 2020 2:49 pm
Thanks for the reply.
I checked the versions
Plex Player is latest version : 8.7.2.20952
Plex server is also latest version : 1.20.3.3437
After re-anilysing the file it showed the DoVi data. But playing the file was still in HDR :(
PlatypusW
Post by PlatypusW »
HongyuS wrote: Wed Oct 21, 2020 7:23 am
badrobot wrote: Wed Oct 14, 2020 1:03 am The new launched iPhone 12 can produce Dolby Vision Video. So we can have more DoVi videos created by official proven method.
The iPhone 12 spec says:
 HDR video recording with Dolby Vision up to 30 fps
Sample DoVi video shot on iPhone 12, it is profile 8.1, with HLG compatibility.
General
Complete name                            : /Users/hongyushi/Movies/iPhone 12 Pro 杜比视界样片.mov
Format profile                           : QuickTime
Codec ID                                 : qt   0000.00 (qt  )
File size                                : 238 MiB
Duration                                 : 47 s 147 ms
Overall bit rate                         : 42.3 Mb/s
Encoded date                             : UTC 2020-10-17 12:55:31
Tagged date                              : UTC 2020-10-17 12:56:19
Writing library                          : Apple QuickTime
com.apple.quicktime.location.accuracy.ho : 228.095906
com.apple.quicktime.location.ISO6709     : +23.1371+113.3256+025.978/
com.apple.quicktime.make                 : Apple
com.apple.quicktime.model                : iPhone 12 Pro
com.apple.quicktime.software             : 14.1
com.apple.quicktime.creationdate         : 2020-10-17T20:55:31+0800
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.0A, BL+RPU, HLG compatible
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 47 s 145 ms
Bit rate                                 : 42.0 Mb/s
Frame rate mode                          : Variable
Frame rate                               : 45.008 FPS
Minimum frame rate                       : 28.571 FPS
Maximum frame rate                       : 60.000 FPS
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.113
Stream size                              : 236 MiB (99%)
Title                                    : Core Media Video
Transfer characteristics                 : HLG
Codec configuration box                  : hvcC+dvvC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Source duration                          : 47 s 206 ms
Bit rate                                 : 181 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 SPF)
Stream size                              : 1.02 MiB (0%)
Source stream size                       : 1.02 MiB (0%)
Title                                    : Core Media Audio
Other #1
Type                                     : meta
Other #2
Type                                     : meta
Other #3
Type                                     : meta
I thought the Apple TV 4K only supported profile 5? Or can it also do profile 8.1? If it can’t do profile 8.1 now I’d expect it to come in an update very soon?
Looking at the specs, it does seem Apple TV is listed as profile 5 only, so ???? How is that going to work when airplaying etc? HDR only or do you think it will convert on the fly. :?
Pretty annoying if the video you shoot on your new phone can’t be played back in Dolby vision on the 4k ATV. Then again, there is suppose to be a new one coming in the next 5 months :roll:
Post by shawnc22 »
Buzzie wrote: Wed Oct 21, 2020 8:01 pm
You need the latest 8.8 version of plex. If you weren’t on the beta, i think the public releases just came out today.
badrobot
Post by badrobot »
General
File size                                : 238 MiB
Video
Codec ID                                 : hvc1
Audio
Format                                   : AAC LC
Bit rate                                 : 181 kb/s
Other #1
Type                                     : meta
Other #2
Type                                     : meta
Other #3
Type                                     : meta
The iPhone 12 review from Verge says DoVi type 8.4
https://www.theverge.com/21524288/apple ... pro-review
But the iPhone 12 shoots video in a newer version of Dolby Vision called Profile 8.4 that’s built on a standard called HLG, or hybrid log-gamma. HLG works differently than PQ systems; it was developed by broadcasters like the BBC and NHK to be backwards compatible with SDR displays so they would only have to broadcast one video stream.
Could you plz upload the sample video file to mega.nz or google drive, I want to test it on shield tv 2019.
One more thing, are you Chinese? Mr Hong? I am from Mainland of China.
I am not a native English speaker.
Sorry for my bad English.
HongyuS
Post by HongyuS »
badrobot wrote: Thu Oct 22, 2020 1:20 am The iPhone 12 review from Verge says DoVi type 8.4
Thanks a lot for the info!
Looks like this profile is pretty new, not even specified in the Dolby Vision profiles/levels doc (which updated last year).
Here is a link of the original file:
https://drive.google.com/file/d/1JsFd_K ... sp=sharing
The video is not shot by me. I got it from another group on Bilibili (see "BV1rv411k7GL").
badrobot wrote: Thu Oct 22, 2020 1:20 am One more thing, are you Chinese? Mr Hong? I am from Mainland of China.
Yes, I'm also from mainland China.
Buzzie
Post by Buzzie »
shawnc22 wrote: Wed Oct 21, 2020 10:14 pm
Thanks....gonna download that one tonight and see if it works.
EDIT: Update Plex app to 8.8 and worked indeed. Thanks!!
Buzzie
Post by Buzzie »
Later i am gonna update my Plex to version 8.8 on my shield to see if the MKV files are gonna play in DV instead of HDR.
In the meantime i have another question
Has anybody here converted other movie files (TS of MP4) to MKV with Dolby Vision remaining as well as HD audio ?
I am trying for instance the following :
General
Complete name : V:\Movie\Movie.ts
Format : MPEG-TS
File size : 52.9 GiB
Duration : 1 h 38 min
Overall bit rate mode : Variable
Overall bit rate : 76.5 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086
Codec ID : 6
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 906 cd/m2
Maximum Frame-Average Light Level : 824 cd/m2
Audio
Menu ID : 1 (0x1)
Format : DTS XLL X
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Muxing mode : Stream extension
Codec ID : 134
Bit rate mode : Variable
Channel(s) : Object Based
Channel layout : Object Based
Delay relative to video : -500 ms
Language : English
But no matter what i try, ffmpeg, makemkv or mkvtoolnix i keep getting a non Dolby Vision file according to Mediainfo.
Any Ideas?
yusesope
Post by yusesope »
ragico wrote: Mon Oct 19, 2020 9:58 pm @Yusesope
I did other tests and got your MKV_Patcher to work finally.
This file plays as HDR in firestick and as DV in Ugoos/shield.
Out of curiosity, what was the problem with the patcher?
It should also work on Fire Stick.
When you have time, try the files you find at the bottom of this post.
Let me know!
jlpsvk wrote: Tue Oct 20, 2020 7:39 pm i just realised....
when i mux hevc file from ys's tool with mkvtoolnix, makemkv recognizes this as dvhe.07.00, BL+RPU, but created mkv is dvhe.07.00, EL+RPU in mediainfo... this is known thing...
but when i ran THAT mkv through makemkv again, makemkv recognise the mkv correctly, as dvhe.07.06, BL+FEL+RPU, and outputted MKV is also correct... dvhe.07.06, BL+EL+RPU in mediainfo. so mkv_patcher is "not needed"... but requires more space and time.
If I were you, to be 100% sure, I'd pass the file to MakeMKV 15 more times ... you never know :lol: !
The main point is to save time and space ... that's what the patcher is for!
jlpsvk wrote: Wed Oct 21, 2020 12:35 am @yusesope
i was wondering more... :)
would it be possible to extract RPU metadata from the secondary HEVC stream on BD? that can be then used directly with x265 to encode directly to profile 5 or 8.1
I had already answered this question in the past (HERE).
blenky wrote: Fri Oct 16, 2020 7:02 pm @yusesope I followed your steps in the post above to the letter.
However the resultant files play back in HDR10 on my Zidoo Z9X.
I have updated the POST of the 0.0.4 GAMMA version.
I think I have made some steps forward.
THESE samples were obtained with the latter version.
Do they trigger DV on your devices?
The files contain an ATMOS audio track that could create some incompatibility with those devices without decoder, e.g. LG TVs.
DaMacFunkin
Post by DaMacFunkin »
Buzzie wrote: Thu Oct 22, 2020 12:33 pm I have another question.
General
Format : MPEG-TS
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 6
Color space : YUV
Bit depth : 10 bits
Audio
Menu ID : 1 (0x1)
Format : DTS XLL X
Codec ID : 134
Language : English
Any Ideas?
Drop your TS file into Tsmuxer, select output as ISO and mux.
Re-rip new ISO with latest Makemkv.
badrobot
Post by badrobot »
HongyuS wrote: Thu Oct 22, 2020 7:07 am
Good News, this video sample can be recognized by Plex Media Server, and trigger Dolby Vision on Shield TV 2019.
截屏2020-10-22 下午11.56.00.png (197.58 KiB) Viewed 62360 times
yusesope
Post by yusesope »
HongyuS wrote: Thu Oct 22, 2020 7:07 am Here is a link of the original file:
I took a look at the iPhone 12 video: the RPUs are structurally identical to the ones my algorithm (-mode 2) produces when choosing UHD-BD -> profile 8.1 conversion.
It doesn't mean they're perfect but I'm happy with the insight I got :mrgreen: !
This could be important for two categories of devices:
  • for the new LG CX which, according to various forums around the world, seems to have abandoned (with the new firmware) support for Dual Track Dual Layer MP4 profile 7 files.
  • for ATV4K. I assume (I hope) that the Cupertino people will update the current ATV4Ks so that they can play the latest iPhone videos (although Apple is always full of surprises).
badrobot wrote: Thu Oct 22, 2020 4:09 pm
OT:
Do you guys use a VPN to be able to write here or upload files to Gdrive?
ragico
Post by ragico »
@Yusesope
Tried your latest samples and all play in DV in shield/Ugoos
The Fel_to_Mel and Fel_to_8.1 play DV in Firestick with audio disabled (firestick do not support Atmos).
Also tried Fel_to_8.1 in ATV 4k and plays in HDR but, a quick conversion to profile 5 and it plays in DV.
Yusesope I have tried to use yr latest tool, but I am not brave enough.
I need yr instructions with a pratical example, for instance:
python-3.7.6.amd64\python.exe src\app.py -mux -exp \path\to\your\original\file.m2ts
can I write down D:\000125.m2ts? Is this example correct?
And Then:
src\Gpac\gpac.exe -i pipe://video:ext=hevc:audelim=true -o stdout:ext=ts:pes_pack=none | src\FFmpeg\ffmpeg_win_x64.exe -hide_banner -y -i - -i \path\to\your\original\file.m2ts -map 0:0 -map 1:2 -c copy -bsf:v hevc_metadata=aud=insert -metadata title="Movie Title_________________________________________________________________________" \path\to\your\output\file.mkv
Same as above? And I need "" for Movie Title?
