Buzzie
Post by Buzzie » Tue Oct 20, 2020 8:24 am
Since this past weekend i am also trying to convert Ultra HD movies to any format as long as Dolby Vision and HD audio stays intact.
I am trying to accomplish this with the Full Ultra Bluray of Back to The Future.
I have some questions.
I have no idea how to determine of this is FEL or MEL.
How can you check this??
With the script made by Yusesope i have succesfully made an BL.hevc and EL.hevc files
After that i made the BL_EL_RPU.hevc file with conversion MUX_AND_CONVERT_TO_MEL
But when i try to create a TS file with TSmuxer and the BL_EL_RPU.hevc i keep getting an error message "not enough buffer to parse video stream"
Did i do something wrong?
I also tried with mp4muxer to create an mp4 instead but this keeps stopping when the file is about 12 GB.
Last question is how to add the HD audio to the TS file if that one finally works?
Any help is really appreciated
Thanks in Advance!!
Walter
ray_007
Post by ray_007 » Tue Oct 20, 2020 8:33 am
jlpsvk wrote: Tue Oct 20, 2020 6:18 am
ray_007 wrote: Mon Oct 19, 2020 10:04 pm
jlpsvk wrote: Mon Oct 19, 2020 7:26 pm
yeah... that's different.. :) Hobbs and Shaw has FEL, but I haven't seen Birds of Prey with FEL, only MEL.
According to https://forum.blu-ray.com/showthread.php?t=276448 Birds of Prey is still unidentified (since there is no MEL or FEL) description unlike other titles. There could be a case that it was released through different sources e.g Robin Hood but who knows. All i know is that when I loaded the file in Makemkv, it showed as FEL and that is it :)
65kbps for DV EL LAYER is NOT FEL. :)
I think i will go with what the software is telling me, since its been made by people who know what they are doing and i trust their judgment. If anything changes in the future I might decided to re-rip it but for now I am happy with the results :)
bivoj
Post by bivoj » Tue Oct 20, 2020 8:35 am
My english is very bad, forgive me for that. :-)
jlpsvk
Post by jlpsvk » Tue Oct 20, 2020 11:01 am
ray_007 wrote: Tue Oct 20, 2020 8:33 am
I relly don't know, what you are talking about... info from MakeMKV on Birds of Prey
Track information
Type: Video
Codec: MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+MEL+RPU)
Resolution: 3840x2160
Aspect ratio: 16:9
Frame rate: 23.976 (24000/1001)
and info from DVDfab 12.0.0.3
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       59863 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10+ v1 Profile B / BT.2020
* MPEG-H HEVC Video     65 kbps (0.11%)     1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision MEL / BT.2020
kazuma
Post by kazuma » Tue Oct 20, 2020 12:12 pm
i have really don't have a idea what all this discussussion is about :D my only question is of this is relevant for me? i use profile 7 on my lg C9. there is no better solution than this for me i suppose?
jlpsvk
Post by jlpsvk » Tue Oct 20, 2020 7:04 pm
kazuma wrote: Tue Oct 20, 2020 12:12 pm i have really don't have a idea what all this discussussion is about :D my only question is of this is relevant for me? i use profile 7 on my lg C9. there is no better solution than this for me i suppose?
if it works, don't fix it. :)
jlpsvk
Post by jlpsvk » Tue Oct 20, 2020 7:39 pm
i just realised....
when i mux hevc file from ys's tool with mkvtoolnix, makemkv recognizes this as dvhe.07.00, BL+RPU, but created mkv is dvhe.07.00, EL+RPU in mediainfo... this is known thing...
but when i ran THAT mkv through makemkv again, makemkv recognise the mkv correctly, as dvhe.07.06, BL+FEL+RPU, and outputted MKV is also correct... dvhe.07.06, BL+EL+RPU in mediainfo. so mkv_patcher is "not needed"... but requires more space and time.
cuculain
Post by cuculain » Tue Oct 20, 2020 8:28 pm
Buzzie ..re adding atmos audio back in
heres my round about method
basicclly make the mkv from full uhd rip with makemkv
using mkvtoolnix gui ,add in that resultant mkv files then select what you want to keep...in this case the atmos tracks and maybe subs ,thatt will save as an mka files
go thru all the normal steps now with ys tool untill the very end when were back to making the final mkv
now just add the final makemkv file with the mka file ,back in mkvtoolnix gui and your back to full atmos and dv
ie did this fine FINALLY on terminator Dark genesis..changing the FEL down to a MEL 8 with atmos
but same with the mel 7s
after 4 -7 mins movie starts to stutter ,and audio goes out of synch by 2 secs
i beleive this is issue at chapter breaks
ie Alita mel 7 starts fine DV and atmos looks great...4 5 mins in movie goes out of synch and audio lags by at least 2 secs
If i slide the movie forward a bit it all resysnches for a few mins and then goes back out of synch ,and audio out by 2 secs again ...and happens each time i slide forward
and each time if i check theres a new chapter up
This is on Zidoo Z9X ,sony DN 1080 amp ,Panasonic Z1000 OLED
hope this helps some
jlpsvk
Post by jlpsvk » Wed Oct 21, 2020 12:35 am
yusesope wrote: Sun Oct 18, 2020 4:49 pm
@yusesope
i was wondering more... :)
would it be possible to extract RPU metadata from the secondary HEVC stream on BD? that can be then used directly with x265 to encode directly to profile 5 or 8.1
HongyuS
Post by HongyuS » Wed Oct 21, 2020 7:23 am
badrobot wrote: Wed Oct 14, 2020 1:03 am The new launched iPhone 12 can produce Dolby Vision Video. So we can have more DoVi videos created by official proven method.
The iPhone 12 spec says:
 HDR video recording with Dolby Vision up to 30 fps
Sample DoVi video shot on iPhone 12, it is profile 8.1, with HLG compatibility.
General
Complete name                            : /Users/hongyushi/Movies/iPhone 12 Pro 杜比视界样片.mov
Format profile                           : QuickTime
Codec ID                                 : qt   0000.00 (qt  )
File size                                : 238 MiB
Duration                                 : 47 s 147 ms
Overall bit rate                         : 42.3 Mb/s
Encoded date                             : UTC 2020-10-17 12:55:31
Tagged date                              : UTC 2020-10-17 12:56:19
Writing library                          : Apple QuickTime
com.apple.quicktime.location.accuracy.ho : 228.095906
com.apple.quicktime.location.ISO6709     : +23.1371+113.3256+025.978/
com.apple.quicktime.make                 : Apple
com.apple.quicktime.model                : iPhone 12 Pro
com.apple.quicktime.software             : 14.1
com.apple.quicktime.creationdate         : 2020-10-17T20:55:31+0800
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.0A, BL+RPU, HLG compatible
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 47 s 145 ms
Bit rate                                 : 42.0 Mb/s
Frame rate mode                          : Variable
Frame rate                               : 45.008 FPS
Minimum frame rate                       : 28.571 FPS
Maximum frame rate                       : 60.000 FPS
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.113
Stream size                              : 236 MiB (99%)
Title                                    : Core Media Video
Transfer characteristics                 : HLG
Codec configuration box                  : hvcC+dvvC
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Source duration                          : 47 s 206 ms
Bit rate                                 : 181 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 SPF)
Stream size                              : 1.02 MiB (0%)
Source stream size                       : 1.02 MiB (0%)
Title                                    : Core Media Audio
Other #1
Type                                     : meta
Other #2
Type                                     : meta
Other #3
Type                                     : meta
Buzzie
Post by Buzzie » Wed Oct 21, 2020 7:28 am
cuculain wrote: Tue Oct 20, 2020 8:28 pm Buzzie ..re adding atmos audio back in
Thanks for the reply.
I will look at it
Buzzie
Post by Buzzie » Wed Oct 21, 2020 7:49 am
Ok Guys,
I have another question.
I have the full UHD rips of the BTTF Trilogy
I decided to put it in MakeMKV (latest version) and made an MKV. I kept the video ofcourse (only showed the DV file) and the atmos/truehd and ac3 track with subs
When it was done i fired up Mediainfo and it showed the following :
General
Unique ID                                : 295946655838674587133456066759437926418 (0xDEA540AD2706E8C288536817A7FD4012)
Complete name                            : D:\BTFF2\Back to the Future Part II_t00.mkv
Format version                           : Version 2
File size                                : 67.7 GiB
Duration                                 : 1 h 48 min
Overall bit rate                         : 89.7 Mb/s
Movie name                               : Back to the Future Part II
Encoded date                             : UTC 2020-10-20 22:18:16
Writing application                      : MakeMKV v1.15.3 win(x64-release)
Writing library                          : libmakemkv v1.15.3 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 84.6 Mb/s
Bits/(Pixel*Frame)                       : 0.425
Stream size                              : 63.8 GiB (94%)
Maximum Frame-Average Light Level        : 606 cd/m2
Audio #1
Bit rate                                 : 4 602 kb/s
Maximum bit rate                         : 6 954 kb/s
Stream size                              : 3.47 GiB (5%)
Audio #2
Codec ID                                 : A_AC3
Stream size                              : 346 MiB (0%)
Text #1
ID in the original source medium         : 4768 (0x12A0)
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 1 h 42 min
Bit rate                                 : 46.8 kb/s
Count of elements                        : 3312
Stream size                              : 34.3 MiB (0%)
Text #2
ID in the original source medium         : 4771 (0x12A3)
Format                                   : PGS
Bit rate                                 : 985 b/s
Count of elements                        : 76
Stream size                              : 743 KiB (0%)
Language                                 : Spanish
Menu
00:00:00.000                             : en:Chapter 01
00:02:58.511                             : en:Chapter 02
00:04:18.216                             : en:Chapter 03
00:12:45.389                             : en:Chapter 04
00:17:10.112                             : en:Chapter 05
00:21:17.359                             : en:Chapter 06
00:27:00.660                             : en:Chapter 07
00:34:16.429                             : en:Chapter 08
00:38:33.311                             : en:Chapter 09
00:46:14.062                             : en:Chapter 10
00:50:36.450                             : en:Chapter 11
00:55:33.621                             : en:Chapter 12
01:01:30.770                             : en:Chapter 13
01:07:15.197                             : en:Chapter 14
01:14:46.940                             : en:Chapter 15
01:28:01.276                             : en:Chapter 16
01:34:44.261                             : en:Chapter 17
01:37:47.027                             : en:Chapter 18
01:40:38.240                             : en:Chapter 19
01:43:26.325                             : en:Chapter 20
I started the movie on my Shield 2019 Pro.
Plex showed HDR with Dolby Atmos
Kodi, with altered (i think) exoplayer as default player, played Dolby Vision with Dolby Atmos.
Plex on my LG C9 TV played only in HDR with AC3 sound. With TrueHD on i could not play it but that is my settings somewhere i think.
I only started the movie so i dont know if there are any OutOfSync issues.
Any idea why i dont see 2 video?
normally there are 2 video right?
Is it a good rip/remux?
I did not use any other tools.
lexyz
Post by lexyz » Wed Oct 21, 2020 2:49 pm
Buzzie wrote: Wed Oct 21, 2020 7:49 am Ok Guys,
Check Plex player and Plex Server versions.
Does Plex Server detect DoVi data? Check file info in Plex server.
mfraz74
Post by mfraz74 » Wed Oct 21, 2020 6:02 pm
jlpsvk wrote: Tue Oct 20, 2020 11:01 am
Track information
Type: Video
Aspect ratio: 16:9
VIDEO:
mediainfo shows:
jlpsvk
Post by jlpsvk » Wed Oct 21, 2020 7:56 pm
mfraz74 wrote: Wed Oct 21, 2020 6:02 pm mediainfo shows:
and??? mediainfo is not differencing between MEL and FEL... shows just EL
