yusesope
Post by yusesope »
ragico wrote: Sun Oct 18, 2020 7:38 pm
yusesope wrote: Sat Oct 17, 2020 11:19 am
#profile 7
Movie Title_________________________________________________________________________
#profile 8
I have done it Film title followed by 73 underscores.
Still, after MKV_Patcher only get Hdr as mediainfo confirms. This is mkv_patcher. Is there any error?
Yep, there is a problem with the patcher!
In the next few days I will ask you to send me a sample using a hex editor so I can correct the problem!
I'll explain what to do but not now because I'm going to sleep ...
I see "Premere un tasto per continuare" in the attached image.
Are you Italian too?
jlpsvk
Post by jlpsvk »
File Title metadata tag is not the same as filename.. :D
ragico
Post by ragico »
yusesope wrote: Sun Oct 18, 2020 7:53 pm
#profile 7
#profile 8
Yes I am Italian
ragico
Post by ragico »
jlpsvk wrote: Sun Oct 18, 2020 7:53 pm
Pls explain
yusesope
Post by yusesope »
ragico wrote: Sun Oct 18, 2020 7:58 pm Yes I am Italian
Weeeeeeeeeeeee Paesà. :lol: :lol: :lol: :lol:
Nei prossimi giorni vediamo di risolvere!
E' strano che non funzioni ma il mio patcher non trova il titolo assegnato da MkvToolNix!
Sicuro di aver scritto il titolo nel campo "titolo file" (tab "destinazione")?
Buonanotte!
jlpsvk
Post by jlpsvk »
ragico wrote: Sun Oct 18, 2020 8:00 pm
Pls explain
ragico
Post by ragico »
jlpsvk wrote: Sun Oct 18, 2020 8:07 pm
Pls explain
Thank you. It have no effect.
ray_007
Post by ray_007 »
I have tried the Skip HDR10+ method on Hobbs and Shaw and Harley Quinn which are both FEL titles and it worked wonderfully :D
thanks again @yusesope for your hard work
jlpsvk
Post by jlpsvk »
ray_007 wrote: Mon Oct 19, 2020 12:00 am I have tried the Skip HDR10+ method on Furious 7 and Harley Quinn which are both FEL titles and it worked wonderfully :D
I don't know what UHD's you have, but AFAIK, Furious 7 has no Dolby Vision or HDR10+ (only static HDR), and Birds of Prey has MEL.
ray_007
Post by ray_007 »
jlpsvk wrote: Mon Oct 19, 2020 8:26 am
edited my original post. Also, they are both HDR10+ and FEL titles, at least in my case.
jlpsvk
Post by jlpsvk »
ray_007 wrote: Mon Oct 19, 2020 3:32 pm
yeah... that's different.. :) Hobbs and Shaw has FEL, but I haven't seen Birds of Prey with FEL, only MEL.
ragico
Post by ragico »
@Yusesope
I did other tests and got your MKV_Patcher to work finally.
Because the film is Fel, I choose this "python-3.7.6.amd64\python.exe src\app.py -fel_to_mel -mux_exp" in MUX_Experimental
This is the mediainfo from patched file:
General
Unique ID : 233615448083088882690800691470456384375 (0xAFC0B2DD93337F34F8479E8D2E04EB77)
Complete name : I:\v0.0.4_BETA_TEST_FEL_TO_MEL_PLUS_UHDBD_TO_81__PLUS_SKIP_HDR10plus__PLUS_EXPERIM_MUXER_17102020\transporter.mkv
Format : Matroska
Format version : Version 4
File size : 674 MiB
Duration : 2 min 0 s
Overall bit rate : 47.0 Mb/s
Movie name : transporter_
Encoded date : UTC 2020-10-19 21:34:37
Writing application : mkvmerge v51.0.0 ('I Wish') 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 47.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.237
Stream size : 674 MiB (100%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 907 cd/m2
This file plays as HDR in firestick and as DV in Ugoos/shield.
ray_007
Post by ray_007 »
jlpsvk wrote: Mon Oct 19, 2020 7:26 pm
According to https://forum.blu-ray.com/showthread.php?t=276448 Birds of Prey is still unidentified (since there is no MEL or FEL) description unlike other titles. There could be a case that it was released through different sources e.g Robin Hood but who knows. All i know is that when I loaded the file in Makemkv, it showed as FEL and that is it :)
DaMacFunkin
Post by DaMacFunkin »
ray_007 wrote: Mon Oct 19, 2020 10:04 pm
Have there not been cases when Youscope has advised Mike that some files are being identified as FEL when they are actually MEL?
jlpsvk
Post by jlpsvk »
65kbps for DV EL LAYER is NOT FEL. :)
