Requiem for a Dream UHD - Errors
archer
Post by archer » Tue Oct 13, 2020 3:58 pm
First UHD disc I've seen with an enormous amount of multiple titles (216 for the 4K titles). Non-4K titles write fine, the rest give the same errors below. Tried this disc on 4 different drives (2 WH16NS60s and 2 WH16NS40s: all on MK 1.03)
Will probably chalk this up to a bad disc...
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00510.m2ts' at offset '15562727424'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '15562727424'
audit13
Re: Requiem for a Dream UHD - Errors
Post by audit13 » Wed Oct 14, 2020 5:09 am
Submitted a dump for the USA disc.
BossStatus
Post by BossStatus » Wed Oct 14, 2020 1:26 pm
Does anyone know the correct playlist (.mpls) number that we should be ripping?
audit13
Post by audit13 » Wed Oct 14, 2020 3:17 pm
Disc can now be decrypted.
Thank you!
archer
Post by archer » Thu Oct 15, 2020 1:35 pm
For a NA disc it is:
00155.mpls
Download the latest JRE for Java, and add the path to the "Custom Java executable location" in Preferences -> Protection, and it will usually tag which is the correct the playlist
Java JRE Download:
https://www.oracle.com/java/technologie ... loads.html
Cannikin
Post by Cannikin » Fri Oct 16, 2020 3:21 am
00155.mpls is not correct for my disc. :( I've got a standard retail UHD disc, UPC code 31398 30482
I'm pointing to my JRE install but it doesn't help with the identifying...I've still got 100 something playlists.
Any help would be appreciated!
audit13
Post by audit13 » Fri Oct 16, 2020 8:33 pm
I also installed Java to see if it would flag the correct playlist but it didn't work for me.
Try playlist 71 for the retail NA disc.
Cannikin
Post by Cannikin » Fri Oct 16, 2020 11:29 pm
I think that's it, thanks! I fast-forwarded through and everyone seemed to be looking worse and worse as it went on so I think it's in the right order. ;)
handcraftedbits
Post by handcraftedbits » Mon Oct 19, 2020 12:04 am
155 is definitely not right, and can quickly be confirmed. Not sure why the Java code is deciding it's correct.
071 on the other hand, is correct. I verified by comparing various timestamps with my Blu-Ray rip.
archer
Post by archer » Mon Oct 19, 2020 4:40 pm
For anyone curious, I resolved this by temporarily disabling unlimited speed for UHD media on the WH16NS60.
And yes, 071 is the correct playlist for the NA disc
Epedemic
Post by Epedemic » Sun Oct 25, 2020 2:36 pm
Can anyone confirm they actually succeded to make a .mkv with DV off this disc?
archer
Post by archer » Mon Oct 26, 2020 2:43 pm
Yup. Are you having issues?
flixman
Post by flixman » Sun Nov 29, 2020 2:22 pm
I'm not sure if there are different NA discs, but I can confirm the following for my UHD disc (NA disc, same UPC as mentioned above):
Playlist 71 is incorrect. Playlist 832 is correct. DVDFab also (incorrectly) selected 71 as the correct playlist.
On my disc, there are four "corrupted" streams (00505.m2ts, 00507.m2ts, 00512.m2ts, 00506.m2ts), where the video is garbled, and corresponding non-corrupted streams (00500.m2ts, 00502.m2ts, 00504.m2ts, 00508.m2ts).
Playlist 71 contains 2 of these corrupted streams (00512.m2ts, 00507.m2ts), while playlist 832 contains the correct ones (00504.m2ts, 00502.m2ts). The order is otherwise correct on playlist 71.
For those of you that have ripped playlist 71, will someone please check the following short sequences (~30 seconds and ~20 seconds) for video corruption?
0:03:50.521 - 0:04:19.216
0:07:04.006 - 0:07:23.692
What's stated above is definitely correct for my disc, but I'm curious to know if Lionsgate produced variations of this title.
Playlist 832 (good)
00511.m2ts
00504.m2ts
00501.m2ts
00500.m2ts
00503.m2ts
00502.m2ts
00509.m2ts
00508.m2ts
00510.m2ts
Playlist 71 (bad)
00511.M2TS
00512.M2TS
00501.M2TS
00500.M2TS
00503.M2TS
00507.M2TS
00509.M2TS
00508.M2TS
00510.M2TS
richhlo1021
Post by richhlo1021 » Wed Dec 02, 2020 3:49 pm
I confirm 4k mpls71 has at least the first garbled screen, didn't go beyond that. Glad I checked against my previous Bluray rip before running through Handbrake.
Trying mpls832 now
niteflyr
Post by niteflyr » Wed Dec 02, 2020 7:25 pm
I also can confirm garbled scenes on 71. 832 looks good at those times.
